Balsa USA Brotherhood
#176
List above edited, welcome new brothers.
Mike, are you any relation to dirty Harry?
Karp, nice selection you have there, how does the taube fly, it looks like it would need to be fairly still to be able to fly that.
#177
TX
Real airplanes don't have a tailwheel, only a skid.
#179
Please put me on the BUSA brotherhood list, thanks for holding No.20 for me. my planes are Phaeton,Phaeton II,Phaeton 90,Aeronca C3,Sopwith Pup and Flaybaby Bipe
Waldo HI8W
Mangolo
Waco brotherhood # 22
Waldo HI8W
Mangolo
#180
My Feedback: (9)
Please add me to the list!
My first plane, early 80's, was a Swizzle Stick 40 and the second was a Tempo II. I've found both kits and they are in my build que.
Mike
Mike
#184
We'll need to see pics of your planes.
#185
BUSA brothers
#1 3136 Victoria, Australia
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#6 surmovik60 VA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#10 balsa brain FL USA
#11 jwrich OK USA
#12 wwoneguy MD USA
#13 vertical grimmace CO USA
#14 rcmiket TX USA
#15 bpoates25 FL USA
#16 PiperDriver IL USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#21 Steve Percifield IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#26 LonnieMcc MS USA
#27 eindecer3 TN USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#34 bobbailey VA USA
#35 Vampire PA USA
#36 zemkes_wolfpack IN USA
#37 triumphman49 AL USA
#38 SRQFlyer FL USA
#39 Daniel-EL OH USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#49 Luxuswaffe FL USA
#50 dryverman VT USA
#51 otterrc FL USA
#52 cooper998 DE USA
#53 lazyace NY USA
#54 wings2an3 NY USA
#55 the pamster TX USA
#56 lucasar15 PA USA
#57 AMA74894 MN USA
#58 squidman TX USA
#59 M_Callahan OH USA
#60 Karp050555 PA USA
#61 optech CA USA
#62 pending NSW Australia
Welcome optech, I would love to see more detail on that discontinued tempo kit, can you post some pics?
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#11 jwrich OK USA
#12 wwoneguy MD USA
#14 rcmiket TX USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#35 Vampire PA USA
#38 SRQFlyer FL USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#51 otterrc FL USA
#53 lazyace NY USA
#57 AMA74894 MN USA
#58 squidman TX USA
#61 optech CA USA
#187
My Feedback: (9)
But for those that are unfamiliar with this kit. The Tempo II (have no idea what the Tempo I was) is a 3ch parasol design that used the Swizzle stick wing. Unlike the Swizzle stick, the fuse is a full build up. Basically a Parasol Phaeton but the nose uses standard slab sides fared into the spinner instead of a cowl. Sort of like a GP Sporster. Upright engine of .35-.45 size. a hatch on the bottom provides access to the radio gear. It was touted as a second trainer if I recall.
When I built mine I modified the wing for ailerons and used a piped Enya .45 . This was before the Super Swizzle stick so when I build my new one I'm thinking I'll use the Super wing. I also saw a pic one time of a Tempo with wheel pants and I really liked the look so I'm going to do that as well.
Thanks for adding me to the list.
Mike
#188
Ok I'm in for the brotherhood with a current on the bench building an Eindecker 90, with a Citabria Pro next in line and an SE5a sitting on the topshelf. Just need to find another few more hours in the day to make some decent progress
#189
Hi ashby, welcome to RCU, your first post!
As with any other request to the brotherhood, if you are not a regular contributer to the kitbuilding forum I would like a pic or two.
All BUSA kit owners are welcome, we'd love to see your Eindecker.
BTW where are you from?
#190
G'day 3136 good to hear from you.
I live in Northern NSW so a short drive from your place
Will post photos of the part built Eindecker when I get home at the end of the month, so please be patient as unfortunately work gets in the way of my hobby!
#191
You're probably only 12 hour drive away
I actually had a bloke buy a Se5 from me once, he told me he was coming from north NSW and I never expected him to turn up, but he did.
#192
3136, no worries always happy to abide by the rules and will post photos when I am back home.
Yes been known to haggle $50 dollars over a plane then spend a few hundred to drive and collect. You don't have to be crazy but is sure helps
#195
08 you can still buy the plans and manual for that one, just not the kit. http://shop.balsausa.com/product_p/a437.htm
Did you want a #?
Did you want a #?
#198
I built a Stick many moons ago. It had wing tip and rudder nav lights, pull-pull rudder, different foil and wing tip extensions for thermaling. I'd take it up, shut the engine down then hunt for lift. I flew 45 minutes without power once. I just laid down on the ground and flew around. Unfortunately I folded the 'extended' wing version doing stupid stuff. It sounded like a shotgun blast when the wing did fold!
#200
G'day Granpooba, I had a look at Fiberglass Specialties web site and they do not mention a dummy engine, cowl and cheeks was all I could find?
