Balsa USA Brotherhood
#2052
I know there are many of you that have built and flown the BUSA 1/4 scale cub. My question is about fuel tanks. I'm planning on using a RCGF 26cc engine. I'm guessing I need about a 16-18 oz tank to get me close to a 15 minute flight. How close am I? What have you guys used in your cub?
Thanks for your help
#2054
My Feedback: (17)
Jay, a 12 oz. Dubro square fuel tank is plenty large enough for a 26 cc engine. I have a 16 oz. tank in my 1/4 scale Cub (mounted crosswise behind the fire wall), I get 15 min. flying time on 8 to 10 oz. of fuel. The I use is 5/32 or 1/8" ID Tygon fuel line for gas engines and make sure you get a gas conversion stopper. These items can be found on Tower Hobbies web page. By mounting the tank crosswise, it can be completely hidden from the cockpit. The #2030 post on this page, is my Cub, Cub II is still flying.
Post some pictures of your Cub build, we all would like to see them.
Fair Winds & Happy Flyin'
Rich
Rich
#2055
Rich, thanks for your help. Gas engines must not drink the fuel like a nitro engine. In my small planes if the manufacturer recommended a 6 oz tank I always put in a 8 oz. That extra 2 oz would give me my 15 minute flights.
This will be my first large plane and gas engine. I might be picking your brain for info. You've built more than one BUSA cub, did you ever modify your wing mounting like Tom Crump did or just go through the door? I like what Tom did and I might incorporate that in my plane.
Thanks for the information.
#2056
#2058
Guess I should add mine to the list , 1/3 Stearman Valach 250 radial . sorry nothing too exciting as it was the maiden flight , just checking the ground handling and the trim in the air . super nice flying aircraft .
#2062
You are coming in to that size of airplane where the gasoline engines start to pay off over glow fuel. The four strokes aren't so bad but when you get into the larger two stroke nitro engines they can be a bit thirsty. I run a 25 cc engine in my BUSA N-17 . It has a 16 oz tank but I only used about 16 oz total during two flights yesterday. With a Cub you will likely spend less time at full throttle than I do with the fighter plane although as the saying goes, your mileage may vary. As Rich points out, a 16 oz tank is more than enough.
1) My engine tops out at 28K, the aircraft engine maybe 12K
2) My engine runs 50% nitro, 18% lubricant and 32% alcohol fuel, unlike an standard aircraft engine that runs 5-10% nitro, 18% lubricant and 72-77% alcohol fuel.
3) My engine is driving a 2.36" prop, a comparable aircraft engine drives a 12-16" prop, the goal being to get a proper load on the engine and to prevent over-revving(or should I day detonating) the engine.
As I said, apples to oranges but, that being said, application will affect how much fuel you can carry and how long you can fly with that load of fuel. Just be glad you're not using a ducted fan engine as they go through fuel faster than my boat engines do.
#2064
#2067
#2068
I know this is comparing apples to oranges but in my 1/8 scale unlimited hydroplanes, I carry around 20 ounces of fuel for a marine .67 sized engine. That lasts me for a bit over 5 minutes. There are a couple of differences in how a marine .67 and aircraft .60-65 run:
As power goes you would obviously be aware of nitro is where it's at. You are probably far more experienced at getting racing levels of power out of an engine than I am. For ordinary flying it is more about matching matching up the right fuel to the right size of engine. This is a broad generalization but generally speaking methanol is generally friendlier to use in two strokes under one cubic inch. Once you start getting into bigger engines the much greater fuel consumption of glow engines starts to become an issue. Given the appropriate carb and tuning a 50cc engine will happily burn 15% nitro glow fuel but you end up blowing through $25 worth of fuel in a flying session. It's just my experience but it seems like after you get over about 20cc of displacement it is just more economical to get your power from displacement as opposed to hot fuel. I'm sure there are a of exceptions to this, certainly racing is one.
Are the converted Homelites still a thing in boat racing? It would be interesting to see the fuel consumption of a hopped up fuel burning Homelite versus the converted 25cc that I have pulling my Nieuport around.
#2069
My Feedback: (17)
The Balsa USA Brotherhood is a group of modelers who have built and fly Balsa USA airplanes. You must have built, or owned a BUSA airplane, of any size. In post #2012 you will see a list of members from around the world. Canada is well represented. I maintain this forum page, if would like to become a member, just ask. Check out how the members are listed in #post 2012. If you look at many of the posts, you will see just about all of BUSA airplanes list, with pictures, videos, ideas of construction and mods made to the construction. Please try to keep on topic with Balsa USA information and planes. It helps me if you would list your membership number in your signature at the bottom of the post. Your recent post with the video and pictures of the 1/3 scale Stearman is what we like to see. Hope you become member, I am sure you can pass on a lot of valuable information for the Brotherhood.
Rich
Rich
#2070
Rich
Rich
#2072
My Feedback: (17)
Hi Roger, Welcome to the Hood. Your number will be #163, Welcome to the Brotherhood. I hope you share more pictures of your planes and building ideas. If you have questions just ask, someone in the hood can help you . If you do a construction thread on this forum or RCSB we would like to follow along.
It would be helpful for me if all BUSA Brothers would post their BUSA Brotherhood number in their signature. If I have missed anyone please let me know.
Balsa USA Brothers
#1 jwrich, (Rich), Enid, OK, USA
#2 Jeffo New Baltimore, MI, USA
#3 ARUP KY USA
#4 RCKen Lawton, OK, USA (RCU Forum Manager/Admin)
#5 mattnew, Haverhill, MA, USA
#6 surmovik60 VA USA
#7 GerKonig, Levittown, PA, USA
#8 Granpooba, Queensbury, NY, USA
#9 radfordc (Charlie), Lansing, KS, USA
#10 balsa brain, Jacksonville, FL, USA
#11 3136 Victoria Austrialia **
#12 wwoneguy, Beltsville, MD, USA
#13 vertical grimmace, Ft. Collins, CO, USA
#14 rcmiket, El Paso, TX, USA
#15 bpoates25, Riverview, FL, USA
#16 PiperDriver, Rolling Meadows, IL, USA
#17 68goat Alabaster, AL, USA
#18 jlsimon, Long Valley, NJ, USA
#19 pat s, Candor, NC, USA
#20 pending IN USA
#21 Steve Percifield, Noblesville, IN, USA (Sir Percy)
#22 opol, Two Harbors, MN, USA
#23 Zero, Houston, TX, USA
#24 tonyos, Madison Heights, VA, USA
#25 b206, Opdyke, IL, USA
#26 LonnieMcc, Carriere, MS, USA
#27 eindecer3, McMinnville, TN, USA
#28 flyer35, Ilion, NY, USA
#29 jeffEE, Farnington, NM, USA
#30 s3nfo, San Diego, CA, USA
#31 Kwikfli, Winfield, KS, USA
#32 JDHammer, Slippery Rock, PA, USA
#33 Ikruse, Lawton, OK, USA
#34 bobbailey, Chesapeake, VA, USA
#35 Vampire, Bath, PA, USA
#36 zemkes_wolfpack, Winamac, IN, USA
#37 triumphman49, Decatur, AL, USA
#38 SRQFlyer, Sarasota, FL, USA
#39 Daniel-EL, Maumee, OH, USA
#40 hairy46, Sinclair, WY' USA
#41 pettit, Durham, NC, USA
#42 Hrannar, Patrekfjordur, Iceland **
#43 lowbubba, Miamisburg, OH, USA
#45 FokkerD7, Cable, OH, USA
#44 FireBee, Chesapeake, VA, USA
#46 iampilot2, Middletown, OH, USA
#47 Wagon1,Penscola, FL, USA
#48 darren 4, Eau Claire, WI, USA
#49 Luxuswaffe, Hialeah, FL, USA
#50 dryverman, West Rutland, VT, USA
#51 otterrc FL USA
#52 cooper998, Newark, DE, USA
#53 lazyace, Buffalo, NY, USA
#54 wings2an3 Monroe, NY, USA
#55 The Pamster, Dallas, TX, USA
#56 lucasar15, Pottsville, PA, USA
#57 AMA74894, Spicer, MN, USA (Moderator Jim Buzzeo)
#58 squidman, Waco, TX, USA
#59 M_Callahan, South Lebanon, OH, USA
#60 Karp050555, Philadelphia, PA, USA
#61 optech, San Diego, CA, USA
#62 ashby NSW Australia **
#63 R/C Art, Shelbyville, IN, USA
#64 on_your_six MD USA
#65 Highflyer2, Alpharetta, GA, USA
#66 dddaviddean NJ USA
#67 Quagmire, Costa Mesa, CA, USA
#68 pending CA USA
#69 ratshooter, Burleson, TX, USA
#70 TXAG96, Augusta, MI, USA
#71 R/C Ray, Valley Cottage, NY, USA
#72 feep, Pelham, NH, USA
#73 sdcranford, Willard, MO, USA
#74 buzzard bait, Ithaca, NY, USA
#75 chadasmus, Freedom WI, USA, (BUSA Team Pilot, Builder and Designer)
#76 fokv25, Westfield, IN, USA
#77 Dynamic, Stratford, WI, USA
#78 WinterHawke, Waukesha, WI, USA
#79 t6racer NSW Australia **
#80 NM2K, Ringgold, GA, USA
#81 rcjunky67, Belleview, FL, USA
#82 AndyF Ft. Wayne, IN, USA
#83 freefall2907, Ottumwa, IA, USA
#84 a65l, Virginia Beach, VA, USA
#85 Grimracer, Urbana, IL, USA
#86 Corsair2013, Granytsville, UT, USA
#87 Chevelle NY USA
#88 eagledancer, Orlando, FL, USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09, Southbend, IN, USA
#92 PSB, Malven, OH, USA
#93 bradpaul, Apopka, FL, USA
#94 MRadu, Los Gatos, CA, USA
#95 HorsePowerAviation, Cincinnati, OH, USA
#96 Shoestring, Granite, MN, USA
#97 David Gladwin, CookhamBerkshire, United Kingdom **
#98 Rich6170, Springfield, OH, USA
#99 Wildbills21, Menominee, MI, USA, (Team BUSA, pilot, builder,& chief mechanic)
#100 Rickj, Akron, OH, USA
#101 Geezeraviation (Doc), Houston, TX, USA
#102 Flyboy077, Uniontown, OH, USA
#103 Shelstrm. The other Doc), Lancaster, WI, USA
#104 Drude, North Port, FL, USA
#105 bschatz, West Hills, CA, USA
#106 RCDuffer, Valley Center, CA, USA
#107 capnpaul, Orillia, ON, Canada **
#108 p38nut, Indianapolis, IN, USA
#109 yoda64, Bloxon, VA, USA
#110 Jaybird, Hallowell, ME, USA
#111 mbnt, IL, USA
#112 Foodstick (Lance), Ankeny, IA, USA
#113 adec, Perthaustralra, Australia **
#114 Navy, Orange Park, FL, USA
#115 RD Jeff, Anchorage, AK, USA
#116 Mistral 12, Granbury, TX, USA
117 JKEpps, Greenbelt, MD, USA
#118 FlyerInOKC, Okla, City, OK, USA
#119 PT19, Buna, TX, USA
#120 Jim Scott, ?
#121 Srecker, Erie, PA, USA
#122 bigbird3, Williamstown, VT, USA
#123 Monsour, Fisherville, KY, USA
#124 Marksp (Mark), Redmond, WA, USA
#125 Quidleywins , Kyneton Victoria, Australia**
#126 M.Casper (Michael), Perry, IO, USA
#127 Twin_Flyer (Bill), Westhampton Beach, NY, USA
#128 Big Stikflyer (Jay), Machesney, IL, USA
#129 SkinnyBob (Bob), Park Falls, WI, USA
#130 Jetset, (Myles), Picton, ON, Canada**
#131 John Taylor, Macedon, NY, USA
#132 dwreel (Dick), Southern Pines, NC, USA
#133 jimbrock (Jim), Houston. TX, USA
#134 Bandit59, Irmo, SC, USA
#135 Check6, (Fred), N.Scituate, RI, USA
#136 OldScaleGuy, (Steve), Seymour, IN, USA
#137 N1EDM, (Bob), Brockton, MA, USA
#138 Str8aero, (Lee), Sheridan, WY, USA
#139 SAProbuster, (Bob), San Antonio, TX, USA
#140 TomCrump, (Tom), Traverse City, MI, USA
#141 spaceworm, (Richard), Guilford, CT, USA
#142 a8ter, (Larry), Dickinson, TX, USA
#143 NC state, (Tom), Albuquerque, NM, USA
#144 mac2286, (Jimmy), Commiskey, IN, USA
#145 crawler tech, Cocoa, FL, USA
#146 RobMason, (Rob), Henderdsonville, NC, USA
#148 Redtail (Chic), Alexandria, VA, USA
#149 golf4two, (Rick), South, GA, USA
#150 Bcool831, (Barry), Macomb, MI, USA
#151 mariok, (Mario), Valinhos, Brazil**(Director of COBRA (Brazilian equivalent of AMA)
#152 Lucky Do, (Mike), Columbus, IN, USA
#153 dogs4dux, (?), Fronhna, MO
#154 mgnostic, (Matt), Kamay, TX,USA
#155 Yank II, (Jim), Salom, AZ
#156 Jerry-RCU, (Jerry), Siler City, NC, USA
#157 Deanz406, (Dean), Latrobe, PA, USA
#158 smkrcflyer, (Steve), Hamburg, PA, USA
#159 PaulD, (Paul), Coquitlam. B.C., Canada**
#160 Modeltronic, (Pete), Cross Plains, TX, USA
#161 Michael wood, (Michael) Linden, TN, USA
# 162, (Paul), Santee, CA, USA
# 163 RAMMJETT, (Roger), Nobel ON. Canada **
Happy Flyin'
Rich
__________________
Balsa USA Brothers
#3 ARUP KY USA
#20 pending IN USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
Happy Flyin'
Rich
__________________
