Looking for 60 size Royal Spitfire pics - esp engine placement
I have not been able to find a build thread for a Royall Spitfire. I'm wondering is there an engine/muffler configuration that would fit inside the cowl? Pics of your engine placement would be appreciated. Also, does the Royal 60 size have any gull wing features?
My Feedback: (13)
knowing what I do about Royal planes the front end cowl area is a bunch of wood blocks that need to be shaped into a nose, I built a FW190A8 and did several mods to resemble the construction techniques used by Top Flite rather than the wood block structures that Royal has for there models.
I ended up making a plug for the cowl area and casting a fiberglass cowl so I could have better airflow and a more modern airplane this isn't a Spitfire but here is my build thread and what I did as far as modifications.
I cant speak to the Spitfire but my FW190 had a note on the plans for a scale empennage if one would like to build that with a note that the plane was allot harder to fly with the smaller tail section I opted to make the regular larger control surfaces http://www.rcuniverse.com/forum/rc-w...l-fw190a8.html
My Feedback: (13)
