G&L 1/5 DHC chipmunk - diary of a build.
Reply
Old 06-30-2014, 04:34 PM
  #251
TonyBuilder
TonyBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Break time for a few days, I'm out of town on business for a few day . This will give me time to think about what is next.
I do know I need to finish the wing and mount it to the fuselage before I go any further. This needs to be done before I mount the stab and do the cockpit and canopy. This will also give me a chance to do some pre- CG checking before I do the canopy.
TB
TonyBuilder is offline
Old 07-01-2014, 05:28 AM
  #252
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice article TB! I don't know why but when I read the name "Wsiewolod Jan Jakimiuk" I thought of "Yakima Canutt" the famous cowboy and stuntman.
FlyerInOKC is offline
Old 07-02-2014, 03:32 AM
  #253
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Airborne Media products
Has anyone tried or used the Airborne Media Products Aero-Pac scale documentation CDRom?
Haven't heard anything about them.
http://www.airbornemedia.com/store/c...cye)/index.htm
thanks
TB
Old 07-02-2014, 07:03 AM
  #254
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks
TB
Try this link: http://www.airbornemedia.com/
Old 07-06-2014, 02:26 AM
  #255
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zor, Thank you for the drawings, yes they will help. I am going to print out a scale ruder and use that as a template. I need to do some work on the fine too, it is a strait LE for the super chipmunk and that has been throwing me.
TB
Old 07-06-2014, 02:43 AM
  #256
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by FlyerInOKC View Post
TB I think the line you drew is too rounded.
I agree, I just marked it to start getting an idea of the shape. I take the image and blow it up to the right size on my computer screen then I place the ruder next to it. I will print this and go from there. I have a bit of reshaping to do being the ruder is one of the signature looks I need to get it right.
My ruder is way to big and I will reshape it when I get back to the fuselage.
The ruder has changed from the first design and there are a few to chose from so I will find the best fit that matches up with the scheme I am doing and the fine I have to work with. Both these are really small so I will play with this.
TB
Name:	ruder templeate 004.JPG
ID:	2012060   Click image for larger version
Name:	ruder templeate 005.JPG
ID:	2012061   Click image for larger version
Name:	ruder templeate 006.JPG
ID:	2012073   Click image for larger version
Name:	ruder templeate 007.JPG
ID:	2012074   Click image for larger version
Old 07-06-2014, 02:54 AM
  #257
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back from my week off, on the board for today will be finishing the right wing........ after some morning flying
TB
Old 07-06-2014, 09:28 PM
  #258
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Airfoil information
Hi guys,
This is for information only.
The Chipmunk is using two airfoils starting at the root with NACA 2415 and ending at the tip with USA 35B.
The USA 35B is nearly a Clark-Y airfoil.
The t/c ratio at the root is 14.75% and at the tip is 11.0%.
The center section incidence is +2 degrees to thrust line.
I will attempt to attach drawings of these airfoils.
NOTE ... the USA 35B is a huge pdf file. All anyone has to do is to keep clicking the minus ( - ) icon to bring it to full view on the monitor.
Zor
Zor is offline
Old 07-07-2014, 02:32 AM
  #259
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Todays task is to finish the right wing, or at least bring it up to speed with the left wing. I will be trying a combination of finishes on this build. Vinyl rivets and glue drops along with fasteners, and after paint vinyl fasteners. I have never done either so this will be a learning proses, one reason for doing this build before I get to finishing my P-47!
So I got a glue drop kit from R/C Scale Products. I got the 1/5th scale rivet templates but they seam big. So I will get some 1/6th templates too. I see different size rivets on the full scale so having both sizes wont hurt.
1/64 chart tape for panel lines, templates, and dropper bottle.
Here is an example of the rivet look I am going for.
I have zero experience with glue drop rivets so my need some advice on them.
TB
ID:	2012277   Click image for larger version
ID:	2012278   Click image for larger version
ID:	2012279   Click image for larger version
Name:	DHC 1 Chipmunk 673.JPG
ID:	2012281   Click image for larger version
Name:	DHC 1 Chipmunk 671.JPG
ID:	2012282   Click image for larger version
Name:	DHC 1 Chipmunk 563.JPG
Old 07-07-2014, 11:52 AM
  #260
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Made good progress on the right wing. Aileron hinges are made, hinge blocks are in, CF hinge shields are in, and the flap pocket is being formed with gorilla glue. Break time till that dries then on to the aileron pocket.
TB
Old 07-08-2014, 03:37 AM
  #261
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Right Wing
So the right wing is coming along.
On making the aileron hinges I came up with a new trick. It is hard to get them all the same size and shape doing them one by one or in pairs. So I used thin CA and hit all the rough ends with CA and made one block out of all 9 pieces. Then I sanded it and when it was good I trimmed the ends and separated the hinges, came out good and was much faster then doing them in pairs of three like the first ones.
Hinge blocks are in.
Hinge pocket shields are in.
Gorilla glue added to shame the pocket and to strengthen the shields.
I forgot to mask off the area so a little sanding is needed to remove the excess, getting back into the rhythm
TB
Name:	right wing 001.JPG
ID:	2012540   Click image for larger version
Name:	right wing 002.JPG
ID:	2012541   Click image for larger version
Name:	right wing 003.JPG
ID:	2012542   Click image for larger version
Name:	right wing 004.JPG
ID:	2012543   Click image for larger version
Name:	right wing 005.JPG
ID:	2012544   Click image for larger version
Name:	right wing 006.JPG
ID:	2012545   Click image for larger version
Name:	right wing 007.JPG
ID:	2012546   Click image for larger version
Name:	right wing 008.JPG
Name:	right wing 009.JPG
Old 07-08-2014, 03:50 AM
  #262
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the bench for today will be the aileron pocket. I will also mount my DLE55ra to my Sbach for break in. I need a good 40 flights before I put that engine in the chipmunk.
TB
Old 07-09-2014, 02:39 AM
  #263
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Took me most of the day to get the DLE55 mounted to the Sbach for break in. I also did some long overdue building of transport and building stands from 5/8" birch plywood. Used almost 2/3 of a sheet.
I am planning on flying this morning so not much work going on in the shop.
The aileron pocket came out really nice. I tried wetting the area with water first and it really kicks the gorilla glue off. It works much better doing that.
You can see the flap pocket did nit fill in as well as the aileron, that's cool most of the flap pocket gets sanded and just enough remains to support the shield.
Next I will hinge the aileron and flap.
TB
Name:	aileron pocket 001.JPG
ID:	2012773   Click image for larger version
Name:	aileron pocket 002.JPG
ID:	2012774   Click image for larger version
Name:	aileron pocket 003.JPG
Old 07-09-2014, 11:40 AM
  #264
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dle55ra
I took the DLE out for a first run. I mounted it to my 100 CC PilotRC Sbach. I have it mounted on a 3/4 ply bulk head that is mounted to where the EME120 standoffs are mounted. Setup was easy, I used the same throttle and choke servos and routed nyrod to them. I stuck a 2.5 weight to the top of the fier box and she is good to go. I am flying with no cowl for good cooling and easy access to the engine.
I primed the engine till I saw fuel to the card, with the choke on it took but 3-4 flips to get the pop, then 3 more flips to start. She ran great right out of the box (DLE's rock). 6400 rpms on a 22x8 Xoar for break in.
The Bowman ring makes a difference!
Takeoff was long and gradual, once up she climbed at a good rate. I flew a 10min flight, landed and gave the engine a go over. All looked good. Fuel consumption was about 10oz on a ten min flight. Moderate throttle use.
Second and third flight was routine, I did bump up to a 15min flight to get more fuel and time on the engine. Fuel consumption on a 15 min average 5000rpm flight was about 18oz. Once the engine is broken in a will do a race track 10min flight at full to determine tank sizing, but it looks like two 14oz tanks will do, I want good reserve.
Restarts where very DLE like, choke with two or three flips and a pop, then two or three flips and a start.
the 55 pulled my 27lb Sbach around pretty good so she should do great on a 24-25 lb mores sleek frame.
Back to building, going to hit it hard tomorrow.
Old 07-09-2014, 01:29 PM
  #265
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.rcgroups.com/forums/showthread.php?t=2173165
Any interest ?
Zor
Zor is offline
Old 07-09-2014, 05:26 PM
  #266
willig10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony:
Got a question. I just hooked up the mains on my P-47. They both work and cycle well at 100 psi. However when the air pressure get to 80 psi only one main is cycling. I can hear the uplock disengaging on the retract that does not move and you can place your hand under the tire, then it will extend. What do you think?
Glenn
willig10 is offline
Old 07-09-2014, 05:30 PM
  #267
willig10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony:
Glenn
willig10 is offline
Old 07-10-2014, 02:10 AM
  #268
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by willig10 View Post
Tony:
Glenn
Try loosening the mounting screws and see if this helps. If the mount is warping the gear it will hang up. You are using Robart correct? I don't have experience with Robart but most retracts in general if not mounted completely flat to the gear blocks can bind in motion.
TB
Old 07-10-2014, 02:12 AM
  #269
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zor, thanks for the link
TB
Old 07-10-2014, 02:17 AM
  #270
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the board for today will be to hinge the aileron and flap on the right wing, install servos and get it caught up to the left wing.
I laid up the servo hatch covers last night so I am ready to cut the bays open.
TB
ID:	2012984   Click image for larger version
Old 07-10-2014, 08:54 AM
  #271
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Right Wing
Getting some progress on the right wing.
I hit the pockets with easy sand to clean them up.
They came out great. I will clean up the ends and the joint between the aileron and the flap once I glue in the hinges on the aileron, the flap doesn't get glued in until after painting.
Hinges are cut in and I am adjusting them as we go forward.
Right now the aileron is getting 20degress of up and 30 degrees of down. The flap is getting 50 degrees. This is the throw before it binds on both. I don't need 50 degrees on the flap.
Next I will install the servos and linkages. Then the right wing will almost be caught up to the left. Still need to fit the hatches.
TB
ID:	2013099   Click image for larger version
ID:	2013100   Click image for larger version
ID:	2013101   Click image for larger version
ID:	2013102   Click image for larger version
ID:	2013103   Click image for larger version
ID:	2013104   Click image for larger version
ID:	2013105   Click image for larger version
ID:	2013107   Click image for larger version
Name:	right wing 010.JPG
ID:	2013108   Click image for larger version
Name:	right wing 011.JPG
ID:	2013109   Click image for larger version
Name:	right wing 012.JPG
ID:	2013110   Click image for larger version
Name:	right wing 013.JPG
ID:	2013111   Click image for larger version
Name:	right wing 014.JPG
Old 07-10-2014, 10:13 AM
  #272
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TB I'm a little brain dead today, how did you make your aileron pockets? I was thinking you did it differently then you do on your P-47.
Old 07-10-2014, 11:29 AM
  #273
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OKC, yes I did them differently then the jug. I used gorilla glue. First I warped the aileron/flap with wax paper then I applied glue to the pocket, set the hinge blocks in and taped the aileron/ flap into the pocket. The foaming of the gorilla glue forms the pocket, when dried you just sand the excess, then hit it with a thin coat of easy sand and you got nice clean light hinge pockets.
The he easy sand will eat the wing core foam but not the gorilla glue foam so be carful on raw foam.
The the flap pocket will never see the light of day once the flap is glued in but I still like it to be clean.
The aileron pocket will be visible and have rivets, panel lines and access hatches so it gets the works
TB
Old 07-10-2014, 11:50 AM
  #274
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well stealing inspiration from your builds I was considering making pockets for my TF 182 I'm not crazy about the way the instructions have you do them. I think I'll do some weighing of the systems and pick one.
Old 07-10-2014, 02:17 PM
  #275
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right Wing progress
I am gluing in the aileron hinges.
First I glue the hinge into the aileron using blocks to get them all at the same plane.
Then after that dries I glue the hinge into the wing. This is different then I normally do. I would glass the aileron then install the hinge but this time I want to get the aileron hinged and working before I glass. This way if I need to sand I can do that. It is impossible to know how the hinge is working without gluing the hinges in.
The Robart hinges are tight with a dry fit so it is easy to see how they work without gluing them in.
Once the flap is glassed I will glue the hinge into it and wait till the finishing to glue the hinge/flap into the wing.
Onward.
TB
ID:	2013154   Click image for larger version
ID:	2013155   Click image for larger version
ID:	2013156   Click image for larger version
ID:	2013157   Click image for larger version
ID:	2013158   Click image for larger version
ID:	2013159   Click image for larger version
Reply
Display Modes
