G&L 1/5 DHC chipmunk - diary of a build.
Reply
Old 07-29-2014, 01:51 PM
  #401
TonyBuilder
TonyBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today was a slow day, yesterday kicked my butt
I fitted the removable rear section. This will allow access to the elevator and visual inspection of the pull-pulls.
It also helps in the installation so it is not a blind install. I laid I piece of CF on the bottom of the stab to lock it into the fuselage. I have one more brace to put in.
I pined the Fin post with a 1/8" CF dowel. The LE of the stab got a 4" CF dowel threw the LE and into the fin post, couple pins at the front and some in the fin post at the ruder.
I will make the fillets and fairing from Evercoat light weight filler.
The bottom ruder section that is part of the stab is glued in. I will finish this out with easy sand.
It will be in two parts, the very end will be on the removable end piece.
I am designing the canopy slides. For the fin rail I will use two bras rectangular tubes. I soldered a post at each end to glue into the fuselage. This is all just rough as I figure it out.
The sides will get 1/32" birch ply and glassed, then easy sand.
I will work on the canopy tomorrow in earnest.
TB
Name:	canopy slid 002.JPG
ID:	2018385   Click image for larger version
Name:	canopy slid 003.JPG
ID:	2018386   Click image for larger version
Name:	canopy slid 004.JPG
ID:	2018387   Click image for larger version
Name:	canopy slid 005.JPG
ID:	2018388   Click image for larger version
Name:	canopy slid 006.JPG
ID:	2018389   Click image for larger version
Name:	canopy slid 007.JPG
ID:	2018390   Click image for larger version
Name:	canopy slid 008.JPG
ID:	2018391   Click image for larger version
Name:	canopy slid 009.JPG
Name:	canopy slid 010.JPG
ID:	2018393   Click image for larger version
Name:	canopy slid 011.JPG
ID:	2018394   Click image for larger version
Name:	canopy slid 012.JPG
ID:	2018395   Click image for larger version
Name:	canopy slid 013.JPG
ID:	2018396   Click image for larger version
Name:	canopy slid 014.JPG
ID:	2018397   Click image for larger version
Name:	canopy slid 015.JPG
ID:	2018398   Click image for larger version
Name:	canopy slid 016.JPG
ID:	2018399   Click image for larger version
Name:	canopy slid 017.JPG
ID:	2018401   Click image for larger version
ID:	2018402   Click image for larger version
Name:	canopy slide fin.jpg
ID:	2018403   Click image for larger version
ID:	2018404   Click image for larger version
TonyBuilder is offline
Old 07-30-2014, 01:18 AM
  #402
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the bench for today, cut and fit the canopy frame. I may have to order a new canopy. The one I used for a mold is really beat up. I will clean it to see if it is salvageable. There are some creases from pulling it out off of the frame.
One thing I will try today is to make a sanding plug from spray can foam. Once the frame is glued on there will be lots of sanding and support is necessary. I may try lining the inside with an old t-shirt and plastic wrap then fill it with foam and let it expand and dry.
TB
Old 07-30-2014, 02:29 AM
  #403
stevegauth30
stevegauth30's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like it could work. Question, do you have to take any extra precautions when using so much carbon fiber? as far as avoiding radio interference.
stevegauth30 is offline
Old 07-30-2014, 03:22 AM
  #404
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Yes, Futaba recommends the tips of the antennas on your receivers to be outside of the fuselage. My plan is to have the antennas come out of the floor of my cockpit being the floor will be just below the instrument panel and maybe have the other receivers antennas come out the bottom just behind the wing belly.
TB
Old 07-30-2014, 03:45 AM
  #405
stevegauth30
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 07-30-2014, 05:50 AM
  #406
ron12901
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am really enjoying your build thread. Really fine craftmanship. I was wondering if you could provide more details about the access to
the elevator and rudder control connections. Where are placing the hatch? How are securing it? Thanks for time.
Ron
ron12901 is offline
Old 07-30-2014, 07:50 AM
  #407
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ron, the assess hatch is the rear part of the stab between the elevators. It has two dowels that hold the front and two screws at the rear that will hold it in place.
TB
ID:	2018591   Click image for larger version
Old 07-30-2014, 07:54 AM
  #408
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So my DLE 55ra is all broken in, got about 4 gal threw and about 25 flights it has performed flawless. Fuel consumption as fallows; a 20min flight at full throttle is about 28oz, so two 14oz tanks will give me a strong 15min flight.
TB
Old 07-30-2014, 12:42 PM
  #409
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Canopy frame.
So my experiment on the pray can foam mold did not work, just a big stick blob.
I emptied the whole can into the mold, the top got hard but the rest was a mess.
My canopy is toast, I tried cleaning it and it simply is not going to clean up.
Two frame layups was to much for it.
I will use this one as a sanding plug. I will try the foam again this time I will spray it right into the inside of the canopy in layers. I will let the first layer dry then hit it again until it is full.
The frame came out really good. Just some fine tuning and I will sand it smooth once the canopy plug is dry.
Then it will be ready for the NEW canopy, yes I will have to order a new one, that will set my back a week on the canopy
Meantime I got a lot to work on, plus I can get the canopy rails done, and install the actuator.
TB
Name:	canopy frame 001.JPG
ID:	2018635   Click image for larger version
Name:	canopy frame 002.JPG
ID:	2018636   Click image for larger version
Name:	canopy frame 003.JPG
ID:	2018637   Click image for larger version
Name:	canopy frame 004.JPG
ID:	2018638   Click image for larger version
Name:	canopy frame 005.JPG
ID:	2018639   Click image for larger version
Name:	canopy frame 006.JPG
ID:	2018640   Click image for larger version
Name:	canopy frame 007.JPG
ID:	2018641   Click image for larger version
Name:	canopy frame 008.JPG
Old 07-30-2014, 04:04 PM
  #410
stevegauth30
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Live and learn my friend.
Old 07-31-2014, 02:01 AM
  #411
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The second foam plug came out better. I used the red can instead of the blue. This will be a good sanding plug for the frame.
On the bench for today will be to design the canopy slides and actuator mechanism. I want to use a single actuator so this will be a challenge with the long fin and the rise it has as it goes to the tail.
TB
Old 07-31-2014, 04:38 AM
  #412
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Canopy sled bracket.
So this is what I came up with. A similar system as my P-47 but a little change.
The bracket that attaches to the canopy is the same, the actuator will be the same but the slide rails are different and the method of attaching to the actuator is with a ball link.
The ball link will allow me to attach the actuator without any screws. I can simply snap it on or off.
Next I will fabricate the attaching bracket that will be part of the canopy.
My canopy will only open to the first and second position (single pilot) being I only get 100mm on the actuator and a full slide would be around 8"
I will be able to slide the canopy all the way for setup purposes.
TB
Name:	canopy sled 004.JPG
ID:	2018795   Click image for larger version
Name:	canopy sled 005.JPG
ID:	2018796   Click image for larger version
Name:	canopy sled 006.JPG
ID:	2018797   Click image for larger version
Name:	canopy sled 007.JPG
ID:	2018798   Click image for larger version
Name:	canopy sled 008.JPG
ID:	2018799   Click image for larger version
Name:	canopy sled 009.JPG
ID:	2018800   Click image for larger version
Name:	canopy sled 010.JPG
ID:	2018801   Click image for larger version
Name:	canopy sled 011.JPG
Name:	canopy sled 012.JPG
Old 07-31-2014, 07:40 AM
  #413
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actuator.
The canopy actuator is installed and the mock up of the bracket that will be bolted to the canopy once I put the glass into the frame.
The liner servo is bolted to the inside top of the fuselage. It is accessible but no fun to get too. Install was ok because there is nothing in the way. If I ever need to change it I will have to strip a lot of stuff down.
I did not want to do a hatch so this is it.
This is a nice installation. One option is to do a side hatch for access to the mount, we will see.
The ball link snaps right on.
The mounting bracket is made from G-10 and will bolt to the canopy. The brass bracket will bolt to the G-10.
I will tap thread it with two 2/56 screws.
The two position operation is the best thing with this liner servo, I don't know if you can do that with air.
I will build the sides to the fin and then its waiting on my new canopy. I do have some hatches to do.
The mounting bracket will help to hold the shape of the rear canopy.
I laid up the main rear brace, I laminated a piece of 1/32" ply and carbon fiber on a piece of glass with a piece of glass on top with weight.
Looks good so fare, not as nice as vacuumed formed.
This will keep the shape of the rear canopy.
TB
Name:	canopy actuator 001.JPG
ID:	2018843   Click image for larger version
Name:	canopy actuator 002.JPG
ID:	2018844   Click image for larger version
Name:	canopy actuator 004.JPG
ID:	2018845   Click image for larger version
Name:	canopy actuator 005.JPG
ID:	2018846   Click image for larger version
Name:	canopy actuator 006.JPG
ID:	2018847   Click image for larger version
Name:	canopy actuator 008.JPG
ID:	2018848   Click image for larger version
Name:	canopy actuator 009.JPG
ID:	2018849   Click image for larger version
Name:	canopy actuator 010.JPG
Name:	canopy actuator 011.JPG
ID:	2018854   Click image for larger version
Name:	canopy actuator 012.JPG
ID:	2018855   Click image for larger version
Name:	canopy actuator 013.JPG
ID:	2018856   Click image for larger version
Name:	canopy actuator 014.JPG
ID:	2018857   Click image for larger version
Name:	canopy actuator 015.JPG
ID:	2018858   Click image for larger version
Name:	canopy actuator 016.JPG
ID:	2018859   Click image for larger version
Name:	canopy actuator 017.JPG
ID:	2018860   Click image for larger version
Name:	canopy actuator 018.JPG
Name:	canopy actuator 019.JPG
Old 07-31-2014, 07:49 AM
  #414
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Canopy sled video.
http://youtu.be/uBDoHhQPJKI
TB
Old 07-31-2014, 01:04 PM
  #415
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a little done on the canopy today.
I put a scrap piece of CF laminate at the end of the fin cut out to clean it up.
The fin canopy rail gets glued in with epoxy.
I faced the sides of the fin rail with two pieces od 1/32" ply, epoxied in and then I glasses the fin with 3/4oz weave.
This will get easy sand when it cures and I sand it down.
My laminate came out great, this will be the back support for the rear part of the canopy.
Moving along.
TB
ID:	2018959   Click image for larger version
ID:	2018960   Click image for larger version
ID:	2018961   Click image for larger version
ID:	2018962   Click image for larger version
ID:	2018963   Click image for larger version
ID:	2018964   Click image for larger version
ID:	2018965   Click image for larger version
ID:	2018967   Click image for larger version
ID:	2018968   Click image for larger version
Old 07-31-2014, 03:55 PM
  #416
RCKen
RCU Forum Manager/Admin
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony,
Once again, GREAT work!!!! Where did you get the linear servo from ???
Ken
RCKen is offline
Old 07-31-2014, 05:30 PM
  #417
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by RCKen View Post
Tony,
Ken
Thanks Ken, I am using a Firgelli liner actuator. I get them from Trossen robotics.
http://www.trossenrobotics.com/p/fig...-Actuator.aspx
TB
Old 08-01-2014, 02:38 AM
  #418
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the bench for today will be hatch layups, easy sand on the fin and stab filets.
I cant do much more on the canopy until my glass gets here. I did cut my side rails. I am using K&S SQ brass tube #8153 for the rails and #8152 for the inner slide.
I use a dermal cut off fiber wheel and double up on the heavy wheels, then I use my drill press with a rail jig to cut the grove.
So I am ready just waiting on glass. I can work on the tail, still need to reshape my ruder. I will start to work on the front compartment that will house my fuel tanks and batteries.
Might even get to the cockpit deck and servo trays. so lots that can be done in preparation to the canopy. Ultimately the canopy deeds to go in before I finalize the center section.
If I need to I can go back to the wing and prime that.
really need to look into a vacuum former fore canopy's, I would much rather make my own in the future being I am such a stickler for details, this canopy is average and not to scale.
Got a quote for the paint stencils, pretty pricy so may have to save up for this.
Onward.
TB
Old 08-01-2014, 09:45 AM
  #419
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some of the mornings progress.
Some easy sand on the fin canopy rail.
Stab filets are getting done.
So the first thing I need to do on the canopy is center it on the fuselage.
I do this by using two carbon fiber strips (strait edge). I find that taking measurements off a round fuselage is not easy so I came up with a way to do it.
I use a piece of blue tape folded in sticky side to sticky side leaving a little on one end.
Then I cut the other end square. I pick a natural reference point like the wing saddle. I place the sticky end to the fuselage and mark the reference point on the tape and the fuselage. Then I mark the other end, maybe center top!
Then I just move to the other side and do the same thing until I get equal measurements on both sides. I will move down the fuselage then take the CF strips and tape them to the fuselage.
This gives me a strait reference line on both sides. I mark this with a sharpie.
The reference line is the bottom of the canopy, this centers the canopy on the fuselage. I mark it and now I can install the side rails.
Bit by bit
TB
ID:	2019155   Click image for larger version
ID:	2019156   Click image for larger version
ID:	2019157   Click image for larger version
ID:	2019158   Click image for larger version
ID:	2019159   Click image for larger version
ID:	2019160   Click image for larger version
ID:	2019161   Click image for larger version
ID:	2019163   Click image for larger version
ID:	2019164   Click image for larger version
Old 08-01-2014, 11:27 AM
  #420
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sliding canopy side tracks.
I am doing to access hatches. One will be for switches, 4 total and the other is access to the mount for the canopy actuator.
There is only two hatches that I can find on the full scale. Both are at the spine and right behind the canopy.
They are access panels for the accumulators.
It is hard to see but it is right over the circle insignia.
The hatches are small, so I may have to out one switch in one hatch and the other in the rear hatch, we will see.
For my fuel fill I will put it in the cowl being I have two engine doors
My canopy slide tracks are done and ready to install.
I am doing them a little different the I did on my P-47.
I soldered tabs on the ends and one in the middle being they are almost 10" long.
This will allow me to shim them and flush them out with the outer skin surface of the fuselage.
I still have to cut the fuselage down to the control lines I marked earlier.
The tabs will either get drilled and tap threaded or just threw bolted with two counter sunk #72 screws in each tab.
The slid inside the track will get a 2/56 or #72 button head screw threw the canopy.
TB
Name:	canopy rails 001.JPG
ID:	2019179   Click image for larger version
Name:	canopy rails 002.JPG
ID:	2019180   Click image for larger version
Name:	canopy rails 015.JPG
ID:	2019181   Click image for larger version
Name:	canopy rails 003.JPG
ID:	2019182   Click image for larger version
Name:	canopy rails 004.JPG
ID:	2019183   Click image for larger version
Name:	canopy rails 005.JPG
ID:	2019184   Click image for larger version
Name:	canopy rails 006.JPG
ID:	2019185   Click image for larger version
Name:	canopy rails 007.JPG
Name:	canopy rails 008.JPG
ID:	2019187   Click image for larger version
Name:	canopy rails 009.JPG
ID:	2019188   Click image for larger version
Name:	canopy rails 010.JPG
ID:	2019189   Click image for larger version
Name:	canopy rails 011.JPG
ID:	2019190   Click image for larger version
Name:	canopy rails 012.JPG
ID:	2019191   Click image for larger version
Name:	canopy rails 013.JPG
ID:	2019192   Click image for larger version
Name:	canopy rails 014.JPG
ID:	2019193   Click image for larger version
Old 08-02-2014, 01:26 AM
  #421
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I have this idea of doing the canopy glass in sections instead of just gluing the frame over the plastic canopy. I want more detail and sometimes gluing the canopy can be a mess with something this big, getting it all lined up and a clean install. So my thought is to finish the frame and then install the individual glass sections one by one. This will give me more control on the individual installation of each pain of glass. I want the bubble glass in the two rear windows. The canopy that I have is very plane and the glass is flat. It will look much better with the bubble glass in the rear section.
The interior will get similar detailing like this.
The bubble is in the rear two windows.
Also I can paint and detail the canopy then install the glass without masking and all that mess. Might be the best way to preserve the glass too.
So that is the plan for now, build the frame, install it and have it working then install the glass.
TB
ID:	2019309   Click image for larger version
ID:	2019310   Click image for larger version
ID:	2019311   Click image for larger version
ID:	2019312   Click image for larger version
ID:	2019313   Click image for larger version
ID:	2019314   Click image for larger version
ID:	2019315   Click image for larger version
ID:	2019317   Click image for larger version
Name:	DHC 1 Chipmunk 614.JPG
Old 08-02-2014, 01:41 AM
  #422
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the bench for today, more canopy work, hatches and stab filets.
But first some AM flying
TB
Old 08-02-2014, 01:34 PM
  #423
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TB
I thought that may be you had a full size Chipmunk nearby that you took pictures of.
I now think I found where you got the pictures of the full size that you occasionally post ...... L O L.
I am still following with great interest in your work but admit that some pictures are not clear to me as to what you are illustrating.
Still it is fascinating to follow along your postings.
Nice work _ _ _ anticipating the end results _ _ _
Zor
Zor is offline
Old 08-03-2014, 02:00 AM
  #424
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I had some time to think about my canopy. I did some mock ups with the old (ugly) canopy glass. It looks like it will work well to cut the individual pains out and glue them in.
One of the reasons for doing the canopy as a whole (gluing the frame over the canopy) is for strength. With all the work I will do on mine it will be very strong stand alone. This frame is really thin with all the vertical post and bolting it is not really an option so I will go forward and build the frame, sand it and prime it.
On the bench for today will be the canopy frame, canopy side track and hatches.
TB
Old 08-03-2014, 01:28 PM
  #425
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Canopy.
I started the day by fine tuning the canopy. Sanding each vertical and horizontal rail to the same uniform size.
I used a 1/4" stick of brass tubing clamped to each rail to gage the sizing as I sanded.
Easy sand was applied after rough sanding was done.
I also cut the access hatch for the canopy servo. It just makes sense to be able to remove it. plus this is a good inspection hatch.
For the side canopy tracks I cut the fuselage to accommodate the brass rails.
The tracks are bolted with 6 #72 stainless steel counter sunk screws.
The tracks are drilled and tap threaded so no nuts are required.
I added 2 layers of 1/32 birch ply as shims to flush the track out with the fuselages outer skin.
Right now the track is flush with the outer fuselages skin. Once I get it all installed I will see if I need to recess or shim the track for optimal performance.
The frame is reinforced with carbon fiber rods and carbon fiber strips.
The rear brace really helps to hold the shape as the canopy slides back and forth.
The basic supports are in defining the glass panels that will be cut to fit and glued in. This frame is solid as a rock
I still need to detail the roof of the canopy, but that will happen as I move forward.
The track is in and ready for the canopy.
TB
Name:	canopy slid 001.JPG
ID:	2019587   Click image for larger version
ID:	2019588   Click image for larger version
ID:	2019589   Click image for larger version
ID:	2019590   Click image for larger version
ID:	2019591   Click image for larger version
ID:	2019592   Click image for larger version
ID:	2019593   Click image for larger version
ID:	2019595   Click image for larger version
ID:	2019596   Click image for larger version
ID:	2019597   Click image for larger version
ID:	2019598   Click image for larger version
ID:	2019599   Click image for larger version
ID:	2019600   Click image for larger version
ID:	2019601   Click image for larger version
ID:	2019603   Click image for larger version
Name:	canopy slid 018.JPG
ID:	2019604   Click image for larger version
Name:	canopy slid 019.JPG
ID:	2019605   Click image for larger version
Name:	canopy slid 020.JPG
ID:	2019606   Click image for larger version
Name:	canopy slid 021.JPG
ID:	2019609   Click image for larger version
Name:	canopy slid 022.JPG
ID:	2019610   Click image for larger version
Name:	canopy slid 023.JPG
ID:	2019611   Click image for larger version
Name:	canopy slid 024.JPG
Reply
Display Modes
