Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 08-19-2014, 09:33 AM
  #501
Leroy Gardner
Tony the prep to paint is like a never ending project, when you think your done you find there is still more to get it right. All the pannel lines and rivets and other small details seem to take longer than the building of it. Dupli-Color is a fine product, espacially the primers when it comes to the pannel lines, I use High Build for that, it sands to a glass like finish, I also use the 3-M fine and micro fine foam pads, never use a hard faced block when doing this, always have a light foam pad under the sand paper and don't wet sand the gray primers, you can the white, it's a different kind of primer that will allow the use of any paints. Because there is some intrest here on color I might add, with the transparenency of todays paints best results of top coats are achieved useing light primers under light colors and dark primers under dark colors, it is also true that primer color effects the depth or lack of it on top coats and can cause the use of more top coats to eliminate what can look blotchie because of the wrong color of primers and thin top coats. Done right will save weight also.
Plane is looking very nice at this stage. Tony, Dupli-Color in the quart can will produce a better top coat than the thinness of the paint in the rattle cans and the only fuel proof paints today are catalized acrylic urethanes and clear coats of the same product, other words automotive paints.
Leroy
Old 08-19-2014, 10:01 AM
  #502
TonyBuilder
TonyBuilder's Avatar
Thank you Leroy for the info. Yes prep is most of the work and the results are based on the prep. I'm just plugging away and hopping I don't screw things up. I have klass Koat paint but this would require day trips to my friends shop, and cooler weather, it is just easier to do the rattle can and do it at my pace and leisure. I know it wont be the best finish but it will be abdicate.
My first chippie was rattle can and it came out good and lasted, my buddy is refinishing the plane and the paint did not come off easily.
TB
Old 08-19-2014, 07:06 PM
  #503
rt3232
T/B tried to send you a PM about paint, but don't know if it went, not a big deal if you did not get it
Cheers Bob T
Old 08-19-2014, 09:08 PM
  #504
Leroy Gardner
Tony if you did one already then you are one step ahead. Follow the steps I laid out in my PM, you'll be happy with the results and get the right sand paper for the job and allow time for the primer to dry before sanding. You'll do fine.
Leroy
Old 08-20-2014, 02:52 AM
  #505
TonyBuilder
Thanks Leroy, I am learning
TB
  #506
TonyBuilder
Bob, yes I did get your PM, thank you.
TB
Old 08-20-2014, 03:02 AM
  #507
TonyBuilder
Progress.
So yesterday I got the fuselage all prepped for panel lines.
I still had a bunch of pinholes to fill so I hit them, then ones I could see with the bondo glazing.
Then I mix up my homer soup and sand the frame. I wet sand because the dust is everywhere with dry sanding.
The foam blocks get clogged up so the wet sanding has worked for me. I use 60-80- and 120 grit.
Once the frame is dry I hit it with dry sandpaper to prep the surface for the primer.
She is ready for panel lines, I got 90% of the imperfections but don't want it perfect.
There is still the panel line priming and the white so that should get the rest.
Leroy has helped me as I learn about finishing. This is one of the reasons I wanted to do this plane before I finished Angie.
I ordered my paint stencils, also I am doing dry ink transfers for the flag and the nomenclatures.
TB
Name:	daily progress 003.JPG
ID:	2023790   Click image for larger version
Name:	daily progress 004.JPG
ID:	2023791   Click image for larger version
Name:	daily progress 005.JPG
ID:	2023792   Click image for larger version
Name:	daily progress 006.JPG
ID:	2023793   Click image for larger version
Name:	daily progress 007.JPG
ID:	2023794   Click image for larger version
Name:	daily progress 008.JPG
ID:	2023795   Click image for larger version
Name:	daily progress 009.JPG
ID:	2023796   Click image for larger version
Name:	daily progress 010.JPG
Name:	daily progress 011.JPG
ID:	2023798   Click image for larger version
Name:	daily progress 012.JPG
ID:	2023799   Click image for larger version
Name:	daily progress 013.JPG
ID:	2023800   Click image for larger version
Name:	daily progress 014.JPG
Old 08-20-2014, 03:24 AM
  #508
TonyBuilder
Panel lines.
I got the panel lines done this morning.
I am doing it free hand and taking some liberties as to the correct placement.
The chart tape is 1/64 and not has hard to work with as I thought it would be.
I am surprised as to how much I used, one roll to do the fuselage.
She is ready for primer and I hope to get her all primed today. I need to go and get some more primer and some cleaner.
I am going to hit the lines with the high build gray then hit the entire frame with the white.
Then more sanding to release the chart tape and rivets to fallow.
My plan as of now is to get the fuselage ready for paint, paint it and let it cure for a week before I do the overlay colors.
In the meantime I will work on the wing while the fuselage cures.
I know that rattle can paint is not the best but it is my only option right now. I think it will be fine for this everyday sports scale plane
TB
Name:	panel lines fuse 001.JPG
ID:	2023802   Click image for larger version
Name:	panel lines fuse 002.JPG
ID:	2023803   Click image for larger version
Name:	panel lines fuse 003.JPG
ID:	2023804   Click image for larger version
Name:	panel lines fuse 004.JPG
ID:	2023805   Click image for larger version
Name:	panel lines fuse 005.JPG
ID:	2023807   Click image for larger version
Name:	panel lines fuse 006.JPG
ID:	2023808   Click image for larger version
Name:	panel lines fuse 007.JPG
ID:	2023809   Click image for larger version
Name:	panel lines fuse 008.JPG
Name:	panel lines fuse 009.JPG
ID:	2023811   Click image for larger version
Name:	panel lines fuse 010.JPG
ID:	2023812   Click image for larger version
Name:	panel lines fuse 011.JPG
ID:	2023813   Click image for larger version
Name:	panel lines fuse 012.JPG
ID:	2023814   Click image for larger version
Name:	panel lines fuse 013.JPG
ID:	2023815   Click image for larger version
Name:	panel lines fuse 014.JPG
ID:	2023816   Click image for larger version
Name:	panel lines fuse 015.JPG
Old 08-20-2014, 03:32 AM
  #509
TonyBuilder
On the bench for today.
Prime the fuselage, maybe get the cowl done, and work on the canopy.
The elevator is ready to sand and then do the panel lines as is the ruder so lots to do.
TB
Old 08-20-2014, 09:42 AM
  #510
Leroy Gardner
From what I see you could have a paint job that looks like my Mustang, it sure would jet some attention.
Leroy
Old 08-20-2014, 11:07 AM
  #511
TonyBuilder
Very nice Leroy, your plane is showroom quality, mine is going to be a bit more rough, still in action and seeing a lot of air time. To be completely honest I don't want my plane to look as good as yours, I would not want to fly it
TB
Old 08-20-2014, 11:28 AM
  #512
TonyBuilder
The morning progress.
Ok so I primed the cowl, canopy and fuselage this morning.
On the cowl and fuselage I did a three coats of high build grey primer.
Then after that dried I hit it with two coats of white. It takes a bit to cover the grey.
Then after a couple of hours I wet sanded the panel lines down to the tape on the cowl only.
At first I thought that the tape was not completely covered. When it is painted it is high and looks like it is on the surface.
So I got good coverage and a nice even panel line. But I sanded the white off at all the panel lines.
I will hit the areas that are gray with white again, just like Leroy told me to do in the first place, but how is a guy going to learn without sticking his hand in the fire to feel the burn
So this was test number one, heavy primer, good coverage. Leroy suggested that I only hit it with the grey then sand the tape free then do the white.
This is the method that will be used from here on. If I did not need the white primer then I would be good to go but it is very necessary.
The second test was on the canopy frame. This is a much lighter piece so I did not hit it as hard with the filler as the cowl and fuselage.
The tape was not berried and was easily exposed without burning threw the white, but not as deep of a line.
This is fine for more delicate parts.
So for the fuselage I will sand it down exposing the tape not worrying if I burn threw the white. Then once the tape is out I will hit it with the white to cover the exposed areas.
I'm learning, I'm learning, by the time I get to Angie I will know what I am doing.
Meanwhile I am doing some tests with the rivets, glue drops and vinyl. Plus more paint tests.
TB
Name:	morning progress 001.JPG
ID:	2023990   Click image for larger version
Name:	morning progress 002.JPG
ID:	2023991   Click image for larger version
Name:	morning progress 003.JPG
ID:	2023992   Click image for larger version
Name:	morning progress 004.JPG
ID:	2023993   Click image for larger version
Name:	morning progress 005.JPG
ID:	2023994   Click image for larger version
Name:	morning progress 006.JPG
ID:	2023995   Click image for larger version
Name:	morning progress 007.JPG
ID:	2023996   Click image for larger version
Name:	morning progress 008.JPG
Name:	morning progress 009.JPG
ID:	2023998   Click image for larger version
Name:	morning progress 010.JPG
ID:	2023999   Click image for larger version
Name:	morning progress 011.JPG
ID:	2024000   Click image for larger version
Name:	morning progress 012.JPG
ID:	2024001   Click image for larger version
Name:	morning progress 013.JPG
ID:	2024002   Click image for larger version
Name:	morning progress 014.JPG
Old 08-20-2014, 03:59 PM
  #513
willig10
Tony;
Looking nice. Leroy I sent you a PM.
Tony what paint colors do you have from Klasscote? Are you going to use them?
Glenn
Old 08-20-2014, 04:10 PM
  #514
TonyBuilder
Originally Posted by willig10
Tony;
Glenn
Glenn I have a boat load of Klass Koat paints, red, insignia yellow, blue black white aluminum, olive drab, trainer yellow, maybe more, what do you need?
TB
Old 08-20-2014, 04:29 PM
  #515
TonyBuilder
Daily Progress
So today was a good day, stressful at times but all in all very satisfying and a big relief.
The panel lines came out great.
At first look, and the deceiving part is as you prime it looks like the tape is siting on the surface and your not putting enough primer on.
Three coats of rattle can primmer, and three coats of rattle can whit is what was put on this frame.
I was siding on the be safe and have more then enough primer then, **** I wish I put more primer.
I started sanding with a fresh foam 180 grit sanding block, wet.
First I would see gray, the white still around the line, then black as the whit started to fade....perfect
There are some spots that had more primer then the body but that was expected and was not an issue.
The good thing is most of the white is still intact. I think a light coat of white and she is done.
Pulling the tape out was not to bad, a #11 blade and some tweezers worked fine. You have to make sure you get the black out, the top is clear and will peal off.
The other thing is start at one end and keep track of what you have pulled out, it can be hared to see what has tape and what does not.
Lastly it is wise to overlap when you can and to leave a piece in areas that don't get seen so you can pull it up easily.
The hardest areas are in tight corners and where there is no dead end.
I am very pleased and relived, thanks to Leroy for his advice and support.
There are a dozen ways to do the same thing with the same results, but until you have done it and can touch it and feel it, you just got to figure out what works for you.
I will hit the cowl and the fuselage in the morning and ready them for rivet detailing.
So stoked
TB
ID:	2024105   Click image for larger version
ID:	2024106   Click image for larger version
ID:	2024107   Click image for larger version
ID:	2024108   Click image for larger version
ID:	2024109   Click image for larger version
ID:	2024110   Click image for larger version
ID:	2024111   Click image for larger version
ID:	2024113   Click image for larger version
ID:	2024114   Click image for larger version
ID:	2024115   Click image for larger version
ID:	2024116   Click image for larger version
ID:	2024117   Click image for larger version
ID:	2024118   Click image for larger version
ID:	2024119   Click image for larger version
ID:	2024121   Click image for larger version
Old 08-21-2014, 02:18 AM
  #516
TonyBuilder
I will do touch up priming of the cowl and the fuselage. Then I will start rivet detailing. I have been testing glue drop rivets and I just don't like the results so I'm just doing all vinyl rivets.
This is a quick build....right
So onto the rivets we go.
TB
Old 08-21-2014, 04:31 AM
  #517
FlyerInOKC
FlyerInOKC's Avatar
What does the frog say? Rivet, rivet, rivet!
Old 08-21-2014, 06:52 AM
  #518
TonyBuilder
Got a start on the rivets.
The canopy frame is ready to go.
I am using Chad Veich vinyl rivet sets.
They are easier to use then the Meirce set. Plus I can get custom sizes and shapes.
I will paint this in the morning. I don't want parts sitting around once they are ready, they get painted.
On some parts some rivets will be applied after paint and then clear coated.
Onto the cowl.
TB
Name:	canopy rivets 001.JPG
ID:	2024435   Click image for larger version
Name:	canopy rivets 002.JPG
ID:	2024436   Click image for larger version
Name:	canopy rivets 003.JPG
ID:	2024437   Click image for larger version
Name:	canopy rivets 004.JPG
ID:	2024438   Click image for larger version
Name:	canopy rivets 005.JPG
ID:	2024439   Click image for larger version
Name:	canopy rivets 006.JPG
ID:	2024440   Click image for larger version
Name:	canopy rivets 007.JPG
Old 08-21-2014, 08:35 AM
  #519
FlyerInOKC
FlyerInOKC's Avatar
Looks great!
Old 08-21-2014, 08:55 AM
  #520
Zor
Banned
TB
T B
Hope you are wearing ear plugs when riveting . . . The noise warrants it . . . L O L
A quick build ? _ _ _ Looks to me like a full time job.
Your last posted pictures of the canopy are superb. Watch for the factory to copy your craftsmanship if they ever build more full size Chipmunk.
I remember when earlier you mentioned that you did not try to match the full scale details.
You are doing very good at it.
You can only be very proud of your work.
Zor.
Old 08-21-2014, 11:33 AM
  #521
willig10
Tony:
I am doing the "Big Ass Bird II" paint scheme. I see Yellow, Red, Black,Olive drab green and Silver (metal). Not sure what type of red and yellow are needed.
Old 08-21-2014, 11:35 AM
  #522
TonyBuilder
Thanks Zor, I am not trying to do one plane in particular and match it to a T, I am taking bits and pieces and taking liberties as I feel, yes a quick build it is so not going to deep in the details
TB
Old 08-21-2014, 11:41 AM
  #523
TonyBuilder
Cowl rivets
Well the cowl is done and ready for paint.
The vinyl rivets go fast, you just get a system and go at it.
I have a variety of sizes, and spacing's, plus you can also remove every other for farther spaced rivets.
I have some ideas for Chad to add to his arsenal of vinyl rivet sets.
I am kind of free handing the rivets and taking liberties as to the full scale.
Should be good for sports scale
Weather permitting I will paint this in the morning.
I need to layup the cowl door popsicles so I can finish those pieces.
TB
Name:	cowl rivets 001.JPG
ID:	2024518   Click image for larger version
Name:	cowl rivets 002.JPG
ID:	2024519   Click image for larger version
Name:	cowl rivets 003.JPG
ID:	2024520   Click image for larger version
Name:	cowl rivets 005.JPG
ID:	2024521   Click image for larger version
Name:	cowl rivets 006.JPG
ID:	2024522   Click image for larger version
Name:	cowl rivets 007.JPG
ID:	2024523   Click image for larger version
Name:	cowl rivets 008.JPG
Old 08-21-2014, 11:44 AM
  #524
FlyerInOKC
FlyerInOKC's Avatar
I was impressed by your cowling to begin with and now that it has rivets all I can say is: WOW!!!!!
Old 08-22-2014, 03:17 AM
  #525
TonyBuilder
Morning progress
Well I got a start on the fuselage last night, very addicting this rivet laying!
I am free handing it, no high tech lasers or levels, just eying it.
I am using the larger rivets to represent the domed rivets, there is no way I am putting glue on every one of these
The intermediate rivets that are flush rivets on the full scale are the smaller rivets.
They lay pretty good and I can do a whole run at a time. I may drop one or loos one here and there but I just go back and add it later.
The screws are the hardest because there are two components and it is hard to get them both down and staying in tight areas.
This kind of work requires lots of small breaks.
TB
Name:	daily progress 001.JPG
ID:	2024618   Click image for larger version
Name:	daily progress 002.JPG
ID:	2024619   Click image for larger version
ID:	2024620   Click image for larger version
ID:	2024621   Click image for larger version
ID:	2024622   Click image for larger version
