Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 06-23-2014, 10:52 AM
  #176
willig10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice work Tony. Can't wait to see it complete.
Glenn
willig10 is offline
Old 06-23-2014, 12:24 PM
  #177
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony, I see you are up to you're usual quality on this build. Watching carefully for the next nugget of knowledge you will treat us to!
FlyerInOKC is offline
Old 06-23-2014, 02:43 PM
  #178
r_adical
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which Struts did you order by Robart code#? They seem to have several struts... Would the Struts they have for the dynaflite 89 inch chipmunk work?
r_adical is offline
Old 06-23-2014, 04:39 PM
  #179
TonyBuilder
TonyBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the 5/8" strait struts. You can find them at Tower, http://www3.towerhobbies.com/cgi-bin...?&I=LXWZB6&P=7 that's where I got mine. On the first build I used the 1/2" struts, they work fine.
TB
TonyBuilder is offline
Old 06-23-2014, 04:46 PM
  #180
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glade your onboard.
TB
Old 06-23-2014, 05:04 PM
  #181
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The canopy frame is looking really good. I pulled it off the fuselage and it is drying.
I will use the first frame attempt as a template to cut the frame on the new one.
I glued the firewall in so I can mount the cowl and the engine. Two 2/8" birch ply, one in and one out.
I will glass the inside when I have time.
I started to cut my templates for the baffle / cowl ring, and the mounting cowl ring.
The front ring will act as a baffle and as a structural ring for when I cut the doors.
The back ring will hold the cowl and bolt to the firewall.
I have a piece of 1/8" G-10 I have been wondering what I would use it for. I will make the cowl rings out of the G-10. I will laminate it to 1/8" birch ply then glue and pine them in.
On the first build I added 32oz of lead to the noes to balance. After I installed the DLE55 I ended up with 16oz of weight still so all the weight I can build into the front will be less lead to balance.
I primed the ruder I need to prime the stab and get it ready to finish before I glue it in, lots to do
TB
ID:	2008181   Click image for larger version
ID:	2008182   Click image for larger version
ID:	2008183   Click image for larger version
ID:	2008184   Click image for larger version
ID:	2008185   Click image for larger version
ID:	2008186   Click image for larger version
ID:	2008187   Click image for larger version
ID:	2008189   Click image for larger version
ID:	2008190   Click image for larger version
ID:	2008191   Click image for larger version
ID:	2008192   Click image for larger version
ID:	2008193   Click image for larger version
ID:	2008194   Click image for larger version
ID:	2008195   Click image for larger version
ID:	2008197   Click image for larger version
ID:	2008198   Click image for larger version
ID:	2008199   Click image for larger version
ID:	2008200   Click image for larger version
ID:	2008201   Click image for larger version
ID:	2008202   Click image for larger version
ID:	2008203   Click image for larger version
Old 06-23-2014, 07:57 PM
  #182
r_adical
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info on the struts
r_adical is offline
Old 06-24-2014, 02:16 AM
  #183
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the bench for today will be mounting the cowl and the engine. I like to first mount the cowl and get it all centered on the fuselage. Then I stand the fuselage on its tail and place the engine on the firewall. Then I place the cowl over the engine and in place on the fuselage. I center the engine to the cowl opening and mark it.
This gives me a perfect centering with the cowl.
TB
Old 06-24-2014, 11:34 AM
  #184
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Progress on the engine and cowl is coming along. I'm in the design and engineering stage.
The hardest part is getting the engine mounted in the right location and the cowl fitted. The rest is easy.
Should have the engine and the cowl ring mounted today, taking a short break.
TB
Old 06-24-2014, 01:10 PM
  #185
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Engine is mounted.
I stand the fuselage up on its tail and from there I can adjust the engine and the cowl.
Once I get it looking good I tack the cowl with tape and move the engine into place.
I use a template of the spinner to center the engine on the cowl.
Some temp screws to holed the cowl in place.
I am moving the engine forward as I fit the cowl
I am fiting the cowl ring next once I am happy with the engine distance. You kind of have to do them all at the same time to see how it all comes together, no hurry here
TB
Name:	cowle ring 001.JPG
ID:	2008518   Click image for larger version
Name:	cowle ring 002.JPG
ID:	2008519   Click image for larger version
Name:	cowle ring 003.JPG
ID:	2008520   Click image for larger version
Name:	cowle ring 004.JPG
ID:	2008521   Click image for larger version
Name:	cowle ring 005.JPG
ID:	2008522   Click image for larger version
Name:	cowle ring 006.JPG
ID:	2008523   Click image for larger version
Name:	cowle ring 007.JPG
ID:	2008524   Click image for larger version
Name:	cowle ring 008.JPG
Name:	cowle ring 009.JPG
ID:	2008526   Click image for larger version
Name:	cowle ring 010.JPG
ID:	2008527   Click image for larger version
Name:	cowle ring 011.JPG
ID:	2008528   Click image for larger version
Name:	cowle ring 012.JPG
ID:	2008529   Click image for larger version
Name:	cowle ring 013.JPG
ID:	2008530   Click image for larger version
Name:	cowle ring 014.JPG
ID:	2008531   Click image for larger version
Name:	cowle ring 015.JPG
ID:	2008532   Click image for larger version
Name:	cowle ring 016.JPG
Name:	cowle ring 017.JPG
ID:	2008537   Click image for larger version
Name:	cowle ring 018.JPG
ID:	2008538   Click image for larger version
Name:	cowle ring 019.JPG
ID:	2008539   Click image for larger version
Name:	cowle ring 020.JPG
Old 06-24-2014, 05:24 PM
  #186
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I moved the engine forward 3/4" and that will help with fitting the cowl.
I installed the center top rail support for the front of the cowl. This will help stabilize the front portion of the cowl. The rail will run threw the cowl ring. I drilled a hole threw the top portion of the firewall for the rail to seat into.
The rail is bolted to the front baffle with a 10-32 stainless steel button head screw.
I laid up the cowl doors and I will start to work on the cowl tomorrow, let the fun begin.
TB
ID:	2008583   Click image for larger version
ID:	2008584   Click image for larger version
ID:	2008585   Click image for larger version
ID:	2008586   Click image for larger version
Old 06-25-2014, 02:03 AM
  #187
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One the bench for today will be the cowl.
My gear came yesterday. It is beefy, that will be good because I will be flying off pavement and grass with this plane.
It fit my mount like a glove, so stoked The gear comes with a pedestal mount that you can mount to a plywood base mounting block.
TB
ID:	2008634   Click image for larger version
ID:	2008635   Click image for larger version
ID:	2008636   Click image for larger version
ID:	2008637   Click image for larger version
Old 06-25-2014, 06:17 AM
  #188
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cowl Progress
Cowl Progress.
The cowl mounting ring is final fitted before I attach it to the firewall.
It is not a perfect fit but the points that it needs to hit it does. At the top only 7/8" is attached to the cowl ring and at the bottom just the pan of the cowl will be attached.
3/4" x 1" plywood blocks are used to hold the cowl ring off of the firewall the same distance as the engine standoffs.
They are epoxied to the firewall.
Once the blocks have dryed I will drill the cowl ring in.
I drilled threw the cowl ring and blocks into the firewall. I am using 4-5x50mm bolts with T-nuts on the inside.
A temp accsess hole was cut into the cowl so I could remove the cowl during construction.
This will have easy access once the doors are cut in.
Onward.
TB
Name:	cowl progress 001.JPG
ID:	2008688   Click image for larger version
Name:	cowl progress 002.JPG
ID:	2008689   Click image for larger version
Name:	cowl progress 003.JPG
ID:	2008690   Click image for larger version
Name:	cowl progress 013.JPG
ID:	2008691   Click image for larger version
Name:	cowl progress 014.JPG
ID:	2008692   Click image for larger version
Name:	cowl progress 015.JPG
ID:	2008693   Click image for larger version
Name:	cowl progress 016.JPG
ID:	2008694   Click image for larger version
Name:	cowl progress 017.JPG
Name:	cowl progress 018.JPG
ID:	2008696   Click image for larger version
Name:	cowl progress 019.JPG
ID:	2008697   Click image for larger version
Name:	cowl progress 020.JPG
ID:	2008698   Click image for larger version
Name:	cowl progress 021.JPG
ID:	2008699   Click image for larger version
Name:	cowl progress 023.JPG
ID:	2008701   Click image for larger version
Name:	cowl progress 024.JPG
ID:	2008702   Click image for larger version
Name:	cowl progress 026.JPG
ID:	2008703   Click image for larger version
Name:	cowl progress 027.JPG
Old 06-25-2014, 06:53 AM
  #189
r_adical
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TB
Where did you get your LG Blocks?
r_adical is offline
Old 06-25-2014, 06:59 AM
  #190
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the cowl ring mounted I put the cowl on and secured it to the fuselage checking the alignment with the spinner jig.
I need to layout the cowl doors before I go any further.
First I level the fuselage to the building board. Using a laser I marked the bottom cut (cowl pan).
Once I like the laser I check using paper templates to insure both sides are equal. Then I mark with a sharpie.
At the top where ther is only a 7/8" strip of the top of the cowl attached to the ring I drilled and taped two button head #72 screws into the G-10.
At the bottom pan of the cowl three more screws taped into the ring.
four temp screws in the sides to hold it in place wile the glue dries.
The attachment points as you can see are just the pan and the top. The rest will be the doors.
The fuselage tapers a bit at the front for the super chipmunk cowl. I want a nice smooth transition so you can see I will need to fill that in once I have the cowl doors done.
The doors are next.
TB
Name:	cowl progress 004.JPG
ID:	2008719   Click image for larger version
Name:	cowl progress 005.JPG
ID:	2008721   Click image for larger version
Name:	cowl progress 006.JPG
ID:	2008722   Click image for larger version
Name:	cowl progress 007.JPG
ID:	2008723   Click image for larger version
Name:	cowl progress 008.JPG
ID:	2008730   Click image for larger version
Name:	cowl progress 009.JPG
ID:	2008731   Click image for larger version
Name:	cowl progress 010.JPG
ID:	2008732   Click image for larger version
Name:	cowl progress 011.JPG
Name:	cowl progress 022.JPG
ID:	2008738   Click image for larger version
Name:	cowl progress 025.JPG
ID:	2008740   Click image for larger version
ID:	2008741   Click image for larger version
Name:	cowl progress 028.JPG
ID:	2008742   Click image for larger version
Name:	cowl progress 029.JPG
ID:	2008743   Click image for larger version
Name:	cowl progress 030.JPG
ID:	2008744   Click image for larger version
Name:	cowl progress 031.JPG
ID:	2008745   Click image for larger version
Name:	cowl progress 032.JPG
Name:	cowl progress 033.JPG
ID:	2008747   Click image for larger version
Name:	cowl progress 034.JPG
Old 06-25-2014, 10:17 AM
  #191
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are the trunnions from the YA P-47 gear from Seiarra, the angles are from HD.
TB
Old 06-25-2014, 12:12 PM
  #192
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The cowl is coming along, it gets better with every step I get threw. There was a moment I thought " this is a big mistake" but it is coming along. The cowl is securely mounted, doors are all cut. I need to do some work on the doors, then cut the openings, hinge them and that will do it. Should have them done by tomorrow, then onto the canopy.
TB
Old 06-25-2014, 04:39 PM
  #193
Melchizedek
Melchizedek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the road of any very cool endeavor with risk and uncertainty. There usually is a moment where one stops and thinks "this is a big mistake".
For the sane anyway. The insane plow ahead unabated.
This is a very cool endeavor, indeed. Kudos.
Melchizedek is offline
Old 06-26-2014, 04:05 AM
  #194
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the words of wisdom, it helps when one is going down a wormhole
TB
Old 06-26-2014, 04:47 AM
  #195
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cowl doors
The engine doors are first rough cut and matched for equal sizing.
Some test fitting of the doors to mark for the cowl cut out.
Before I cut the door opening I glued a 1/32" ply backer to the center section.
I rough cut the opening leaving a good 1/2" all the way around with exception to the center rail. I need to hinge the door before I cut the rest.
Now begins the hinging proses. Offset hinges would be the best choice but there are limitations to the area to hinge to. The center section is only 7/8" wide and with the center support rod there is not a lot of room, plus there is the engine to consider.
The offset hinges will not work and the small plastic hinges are too weak for this application. I have larger aluminum offset hinges but they are too big.
So the best hinge for this door will be the piano hinge. It is strong and solid all the way threw the hinge line.
The hinge is first tacked with thin CA then threw bolted with 8 # 80 button head screws.
On this model most if not all structural screws will be used as visuals details so they will be exposed unlike the countersunk screws used on my P-47. The top portion of the fuselage is black so I will swap out the stainless steel for black during final setup.
The top of the cowl has a slight curve to it and the hinge works because the rear section of the center rail floats, it straitens as the doors open then in the closed position it goes back to its shape.
Now that the door is hinged I can start to fine tune the opening / door and install the lip that the door rest on in the closed position. The door will fit snug when it is closed and secured with the two pins that will hold it closed.
I get some leeway being the full scale in some pics show the door gap off in a few areas, but I will do my best to get it tight.
So far it looks good and I have a good solid foundation to work with, it was rough going for a while
The pan section of the cowl is strong and with the cowl ring it does not move at all. I will add some support to the front baffle for good measure.
The center support rod is over engineered but I don't want to take any chances with vibration and all.
I am playing with some air cylinders for the kickstand. I want to have a way of holding the doors open without having to jump threw a bunch of hoops and have external objects, I can also just have a kickstand from wire that pops down manually, but lets see how the air goes first.
Having the doors removable is key and with the piano hinge you just simply pull the pin and the door is off. This will come in handy for initial run-ups, and even the first few flights to ensure there is cooling and smooth operation.
Tuning will be a breeze too
TB
Name:	cowl doors 001.JPG
ID:	2008844   Click image for larger version
Name:	cowl doors 002.JPG
ID:	2008845   Click image for larger version
Name:	cowl doors 003.JPG
ID:	2008846   Click image for larger version
Name:	cowl doors 005.JPG
ID:	2008847   Click image for larger version
Name:	cowl doors 006.JPG
ID:	2008848   Click image for larger version
Name:	cowl doors 007.JPG
ID:	2008849   Click image for larger version
Name:	cowl doors 008.JPG
ID:	2008850   Click image for larger version
Name:	cowl doors 010.JPG
Name:	cowl doors 011.JPG
ID:	2008852   Click image for larger version
Name:	cowl doors 012.JPG
ID:	2008853   Click image for larger version
Name:	cowl doors 013.JPG
ID:	2008854   Click image for larger version
Name:	cowl doors 017.JPG
ID:	2008855   Click image for larger version
Name:	cowl doors 018.JPG
ID:	2008856   Click image for larger version
Name:	cowl doors 019.JPG
ID:	2008857   Click image for larger version
Name:	cowl doors 020.JPG
ID:	2008858   Click image for larger version
Name:	cowl doors 021.JPG
Name:	cowl doors 022.JPG
ID:	2008862   Click image for larger version
Name:	cowl doors 023.JPG
ID:	2008863   Click image for larger version
Name:	cowl doors 024.JPG
ID:	2008864   Click image for larger version
Name:	cowl doors 025.JPG
ID:	2008865   Click image for larger version
Name:	cowl doors 026.JPG
ID:	2008866   Click image for larger version
Name:	cowl doors 027.JPG
ID:	2008867   Click image for larger version
Name:	cowl doors 028.JPG
ID:	2008868   Click image for larger version
Name:	cowl doors 029.JPG
Name:	cowl doors 030.JPG
ID:	2008871   Click image for larger version
Name:	cowl doors 031.JPG
ID:	2008872   Click image for larger version
Name:	cowl doors 032.JPG
ID:	2008873   Click image for larger version
Name:	cowl doors 033.JPG
ID:	2008875   Click image for larger version
Name:	cowl doors 034.JPG
ID:	2008876   Click image for larger version
Name:	cowl doors 035.JPG
ID:	2008877   Click image for larger version
Name:	cowl doors 036.JPG
ID:	2008879   Click image for larger version
Name:	cowl doors 037.JPG
Name:	cowl doors 038.JPG
ID:	2008881   Click image for larger version
Name:	cowl doors 039.JPG
ID:	2008882   Click image for larger version
Name:	cowl doors 040.JPG
ID:	2008883   Click image for larger version
Old 06-26-2014, 05:38 AM
  #196
Mako17
Mako17's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet!!
Mako17 is offline
Old 06-26-2014, 05:45 AM
  #197
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great job TB! I have been meaning to ask where do you get your carbon fiber, you seem to have an endless supply? How much carbon fiber do you allow for each airplane at the start?
Old 06-26-2014, 06:34 AM
  #198
Melchizedek
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At the start of there trek up the mountain. The men felt excitement in there hearts. At the half way point the sense of dread and mistake came over them, but they pressed on.
Now only yards from the precipice, the sense of dread was replaced with jubilation and a feeling of great accomplishment.
Well done, Tony
Kevin
Old 06-26-2014, 07:16 AM
  #199
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on what Kevin said!
Old 06-26-2014, 08:14 AM
  #200
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys.
TB
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
