Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 06-26-2014, 08:25 AM
  #201
TonyBuilder
TonyBuilder's Avatar
Progress is moving along. took a fraction of the time to do the second door
Both doors look good and I am adjusting them as I go.
I added the second of three rails to secure the cowl baffle the act as the front cowl ring. The three should do it. I will reinforce the pane when I am all done messing with the doors.
She is starting to look like a true chipmunk
TB
Name:	engine doors 001.JPG
ID:	2008902   Click image for larger version
Name:	engine doors 002.JPG
ID:	2008903   Click image for larger version
Name:	engine doors 003.JPG
ID:	2008904   Click image for larger version
Name:	engine doors 004.JPG
ID:	2008905   Click image for larger version
Name:	engine doors 005.JPG
ID:	2008906   Click image for larger version
Name:	engine doors 006.JPG
ID:	2008907   Click image for larger version
Name:	engine doors 007.JPG
ID:	2008908   Click image for larger version
Name:	engine doors 008.JPG
Name:	engine doors 009.JPG
ID:	2008910   Click image for larger version
Name:	engine doors 010.JPG
Old 06-26-2014, 09:34 AM
  #202
Zor
Banned
Default Followin along with admiration
This is the best 'build thread' I have ever seen.
I am still trying to figure out what is all the carbon fiber ( the black cloth ) doing on the fuselage and the canopy.
Congrat on your nice work and all the pictures.
Zor
Old 06-26-2014, 10:27 AM
  #203
FlyerInOKC
FlyerInOKC's Avatar
Zor, TB likes to reinforce everything with carbon fiber for extra strength. My theory is he has dirt on the local supplier and is taking carbon fiber in lieu of cash for the blackmail.
Old 06-26-2014, 11:08 AM
  #204
TonyBuilder
Zor
Thanks Zor, The carbon fiber on the canopy is the layup of the frame for the sliding canopy. I haven't cut it yet. The blue one over the frame is a template. The carbon fiber on the fuselage is the extensions from when I cut the fiberglass super chipmunk canopy off so I could convert to the trainer and have a clear sliding canopy.
On my first build of this kit the fuselage suffered some stress bruising where the fiberglass flexed and cracked the paint during some of the mishaps (cartwheeling, hard landings, dead sticks). I am using scraps to reinforce the inside of the fuselage being I will only have two formers, one at the wing dowels, and one at the back of the wing.
TB
Old 06-26-2014, 11:28 AM
  #205
TonyBuilder
So I found where I will attach the air cylinders to open and close the doors, this is the prototype.
I put it at the front being this is where I have the most room. Also I want it to such the door closed at this area.
The cylinder is a one way spring loaded closed cylinder so it only has one air line to rout threw the cowl.
Plus I have no other use for it so why not. The only times I need to open these doors is at a show and to tune the engine, otherwise it will remain closed.
Next I need to fit the door and do all the lips and the fasteners.
Post video
http://youtu.be/3onQkkhGfR8
TB
Name:	video doors 002.JPG
ID:	2008937   Click image for larger version
Name:	video doors 003.JPG
ID:	2008938   Click image for larger version
Name:	video doors 004.JPG
ID:	2008939   Click image for larger version
Name:	video doors 005.JPG
ID:	2008940   Click image for larger version
Name:	video doors 006.JPG
ID:	2008941   Click image for larger version
Name:	video doors 007.JPG
Old 06-26-2014, 11:36 AM
  #206
TonyBuilder
Originally Posted by FlyerInOKC
Great job TB! I have been meaning to ask where do you get your carbon fiber, you seem to have an endless supply? How much carbon fiber do you allow for each airplane at the start?
ACP is where I get the carbon fiber from. No I don't have an endless supply. I have used every bit I have. I just figure what I want to do on a build, gear doors, hatches and other details and go from there.
http://www.acpsales.com/5.6-oz-Carbo...ain-Weave.html
TB
Old 06-26-2014, 12:09 PM
  #207
Melchizedek
Melchizedek's Avatar
Wow, I was thinking door props. You go all out and have automated openers. Slick
Is there a way to slow the door opening ?
Kevin
Old 06-26-2014, 12:11 PM
  #208
FlyerInOKC
FlyerInOKC's Avatar
Looking at the size and the price you can get a lot of pieces from one sheet. Thanks for the information!
Old 06-26-2014, 12:21 PM
  #209
TonyBuilder
Kevin
Yes, this is just the prototype, I will slow it way down. I may try the air up and air down cylinder too.
TB
Old 06-26-2014, 12:23 PM
  #210
TonyBuilder
I used one roll on this build so far, only have some hatches to do.
TB
Old 06-26-2014, 12:28 PM
  #211
FlyerInOKC
FlyerInOKC's Avatar
Tony, since you probably have more experience with CF of anyone I talk to what areas do you recommend reinforcing with CF besides doors and moving canopies? What does carbon fiber provide as far as strength when applied of sheeting or balsa planking?
Old 06-26-2014, 01:09 PM
  #212
TonyBuilder
I don't have much experience with glassing in general. The main reason I use carbon fiber is for it usability. It lays down much better then regular fiberglass cloth. Anything above 2oz on regular cloth wont do compound radiuses, or right angles. Carbon fiber will do curves really good and stay down, that's why I use it on canopies and other items that have sharp curves. For gear doors and hatches it holds the shape better. Yes it is stronger but that is just a one of the reasons. The smaller the weave the more expensive it is. I thought about trying some .75oz and 2oz but it is crazy expensive compared to the 5.6oz.
As for structurally I use it anywhere I need strength whether I layup or use rod and stick, even laminates are great.
TB
Old 06-26-2014, 04:57 PM
  #213
TonyBuilder
Today was a good day. I feel like I am over the hump and the rest is all down hill from here.
My spinner came today, looks and fits great, thanks Amanda
All the backing for the doors is in and she is ready for the easy sand.
Trying to get the door and the opening perfect was and is not easy. The easy sand will fill in any gaps and frame the opening. I will hit the doors and the front of the cowl tomorrow morning and then I will install the latches.
I may try the two way cylinders to get better control of the speed. Anyways I should be able to wrap the cowl up by Friday and move onto the canopy this weekend, not sure we will have a good flyable weekend so building is just fine by me.
TB
Name:	progress cowl 001.JPG
ID:	2009060   Click image for larger version
Name:	progress cowl 003.JPG
ID:	2009061   Click image for larger version
Name:	progress cowl 004.JPG
ID:	2009062   Click image for larger version
Name:	progress cowl 005.JPG
ID:	2009063   Click image for larger version
Name:	progress cowl 006.JPG
Old 06-26-2014, 06:11 PM
  #214
stevegauth30
stevegauth30's Avatar
Boy your really trucking! You'll be flying it in no time.
Old 06-26-2014, 06:36 PM
  #215
TonyBuilder
sometime in august
TB
Old 06-27-2014, 01:50 AM
  #216
TonyBuilder
On the board for today will be final fitting of the cowl, latches, and air cylinders. I will do all the interior finishes and reinforcements too.
TB
Old 06-27-2014, 05:03 AM
  #217
FlyerInOKC
FlyerInOKC's Avatar
TB I look at you quality of work and the details and can't help but wonder why you aren't winning Top Gun every year! You are that good!
Old 06-27-2014, 05:17 AM
  #218
TonyBuilder
Thanks, I never thought about competing with the big boys, maybe someday when I get more experience.
TB
Old 06-27-2014, 05:31 AM
  #219
TonyBuilder
The mornings progress.
I hit the engine doors with the EverCote easy sand.
You can see how easy it goes on. I use an old CC to spread it on. It dries very fast so I was barley able to get one door covered before it dried. It will sand in 15-20 min.
After the first sanding I apply a second coat in the low spots, this should do it.
All the facing and door lips are installed on the cowl. I left them oversized until final fitting of the doors is complete, then I will cut them back.
I have some J-B Weld I have never used so I thought I would try it. I hit all the joints inside of the cowl. Once this dries I will glass the bottom pan.
While I wait on things to dry I am working on the engine door latches.
e
I am using some 2-56 threaded couplers and #2 washers.
I cut them down to size and cut a grove for the washer, this gets soldered.
Two washers, a spring and a nut complete the latch.
I cut down these spring I had laying around.
Here is the prototype.
This should work
TB
Name:	cowl latches 019.JPG
ID:	2009230   Click image for larger version
Name:	cowl latches 018.JPG
ID:	2009231   Click image for larger version
Name:	cowl latches 017.JPG
ID:	2009232   Click image for larger version
Name:	cowl latches 016.JPG
ID:	2009233   Click image for larger version
Name:	cowl latches 015.JPG
ID:	2009234   Click image for larger version
Name:	cowl latches 014.JPG
ID:	2009235   Click image for larger version
Name:	cowl latches 013.JPG
ID:	2009236   Click image for larger version
Name:	cowl latches 012.JPG
Name:	cowl latches 010.JPG
ID:	2009238   Click image for larger version
Name:	cowl latches 009.JPG
ID:	2009239   Click image for larger version
Name:	cowl latches 008.JPG
ID:	2009240   Click image for larger version
Name:	cowl latches 007.JPG
ID:	2009241   Click image for larger version
Name:	cowl latches 006.JPG
ID:	2009242   Click image for larger version
Name:	cowl latches 005.JPG
ID:	2009243   Click image for larger version
Name:	cowl latches 004.JPG
ID:	2009244   Click image for larger version
Name:	cowl latches 003.JPG
Name:	cowl latches 002.JPG
ID:	2009246   Click image for larger version
Name:	cowl latches 001.JPG
ID:	2009247   Click image for larger version
ID:	2009248   Click image for larger version
ID:	2009249   Click image for larger version
Name:	cowl latches 020.JPG
Old 06-27-2014, 07:27 AM
  #220
Zor
Banned
Default I hate to ask .... but ....
TonyBuilder,
It keeps bothering my mind while I closely follow your nice progress.
I understood the fuselage is made of cloth and fiberglass resin.
The carbon fiber material we see I have to guess is on the inside and eventally the painting of the outside will hide its view.
Am I guessing correctly ?
I also wonder how you will remove the carbon fibers from the canopy so the canopy is clear between the frame.
Thanks for your response and my apologies to disturb you. I just cannot chase these questions out of my mind.
Zor
Old 06-27-2014, 07:47 AM
  #221
TonyBuilder
TonyBuilder,
Zor
Zor, these build threads are here for you to ask questions!
Yes the carbon fiber you see mostly on the fuselage is inside and when I prime all you will see is the primer.
The carbon fiber frame is laid up over the plastic canopy. I use mold release by Evercoat.
The template frame is also been laid up over the plastic canopy.
I don't cut the plastic canopy, I just lay the cut out frame over the plastic and glue and bolt it to the canopy.
Hope this helps
TB
ID:	2009269   Click image for larger version
ID:	2009270   Click image for larger version
Old 06-27-2014, 07:52 AM
  #222
FlyerInOKC
FlyerInOKC's Avatar
TB
TB you should already be competing at least on a local and regional level. Your level of detail and skill already puts some of the past Top Gun winners to shame.
Old 06-27-2014, 08:16 AM
  #223
Zor
Banned
Thanks again TonyBuilder.
I can strongly support FlyerinOKC suggestion in post #222.
Zor
Old 06-27-2014, 08:30 AM
  #224
TonyBuilder
Well thank you guys. I build everyday flyers. I would think the guys building "Top Gun" planes build them specifically for competition. I may take my fleet out to a reginal scale competition and see how they do. But I don't build competition planes, just well made good looking everyday go to flyers.
TB
Old 06-27-2014, 08:52 AM
  #225
FlyerInOKC
FlyerInOKC's Avatar
For some reason my "everyday fliers" don't even come close to looking like yours!
