Reload this Page >
Oh man, I think I messed up my Balsa USA 1/4 Neiuport, I musta took a detour !
Old 08-13-2014, 08:58 PM
foodstick
foodstick's Avatar
Default Oh man, I think I messed up my Balsa USA 1/4 Neiuport, I musta took a detour !
All I wanted was my Neiuport 11 1/4 scale to fit in my Corolla.. Suddenly I have all kinds of things that are conflicting with my plans and instructions !
ID:	2022271   Click image for larger version
ID:	2022272   Click image for larger version
Old 08-13-2014, 09:02 PM
foodstick
foodstick's Avatar
I wasn't so worried until I noticed the gaping error in the fuse .....
ID:	2022275   Click image for larger version
ID:	2022276   Click image for larger version
ID:	2022277   Click image for larger version
Old 08-13-2014, 11:40 PM
jeffo
My Feedback: (68)
If your worried about the fuse gap,mask off one side(scotch tape or wax paper) put JB weld on the other, bolt together wipe off excess with alcohol,perfect fit.jeffo
JB weld is epoxy
Old 08-14-2014, 02:08 AM
TomCrump
TomCrump's Avatar
We'll have to teach you how to read instructions.
I can fix your mistakes. Just sent the entire kit, with all accessories, to me.
Old 08-14-2014, 05:59 AM
foodstick
foodstick's Avatar
Its good to see helpful advice and charity so early after ASKING FOR HELP ! hahahahhhah
Old 08-14-2014, 10:03 AM
jeffEE
jeffEE's Avatar
I have an easy fix. Get a bigger car.
Old 08-14-2014, 06:18 PM
foodstick
foodstick's Avatar
There is no fun in that !
It sure has added a lot of part fabrication...
Old 08-16-2014, 08:23 AM
foodstick
foodstick's Avatar
I wanted the landing gear to be more shock absorbing.....
ID:	2022795   Click image for larger version
ID:	2022796   Click image for larger version
ID:	2022797   Click image for larger version
Old 08-16-2014, 08:26 AM
foodstick
foodstick's Avatar
I also worked on my scratch built gun mount/wing joiner...
ID:	2022903   Click image for larger version
ID:	2022904   Click image for larger version
Old 08-16-2014, 09:25 AM
vertical grimmace
vertical grimmace's Avatar
Why not fill you gaps with thick balsa. Like having a thick center rib on the wings, and then a thick former glued to one side of the fuselage half. No body would ever know. I think it would be better to use would over glue to fill those gaps. Really, it should be no biggie.
Old 08-16-2014, 06:56 PM
foodstick
foodstick's Avatar
I am just kidding on the gap issue.... It is close enough for me. I just thought I would make a joke about building so many parts of this plane in halves...
Its been a lot of extra work... I wonder how far over weight it will be? All of my Balsa USA stuff has flown well when built heavy anyhow
Old 08-29-2014, 05:59 PM
foodstick
foodstick's Avatar
Well I don't claim it to be scale, but I am going to make it look interesting. I have some smaller button head screws to finish it with, I usually just put it together with servo screws first....
Old 08-30-2014, 04:23 AM
TomCrump
TomCrump's Avatar
If it's "interesting", people will think it is scale.
Since I'm not a WWI afficienado, I certainly wouldn't know the difference.
Old 08-30-2014, 06:03 AM
foodstick
foodstick's Avatar
I have so many conflicting images from old pics,models,replicas,etc. I am not really sure what is right.. I can't quite figure out the way the hood and sides are stitched up front as well...
Old 09-14-2014, 04:17 PM
foodstick
foodstick's Avatar
Ive been busy .....
ID:	2031923   Click image for larger version
ID:	2031924   Click image for larger version
Old 09-14-2014, 04:19 PM
foodstick
foodstick's Avatar
Very very busy ......
[attach=config]2031926[/attach][attach=config]2031927[/attach][attach=config]2031929[/attach][attach=config]2031930[/attach]
ID:	2031926   Click image for larger version
ID:	2031927   Click image for larger version
ID:	2031929   Click image for larger version
Old 09-15-2014, 12:53 AM
TomCrump
TomCrump's Avatar
Now, that's something to crow about !
Old 09-15-2014, 05:20 PM
foodstick
foodstick's Avatar
Its definitely the most airplane I have ever built in a month !
Old 09-16-2014, 03:03 AM
TomCrump
TomCrump's Avatar
I'm sure that she'll fly well. Please keep us informed.
Old 09-17-2014, 01:55 AM
stevegauth30
stevegauth30's Avatar
Yaaaay! Found me another build to follow. Looking good man.
Old 09-20-2014, 05:21 AM
foodstick
foodstick's Avatar
ID:	2033673   Click image for larger version
Old 09-20-2014, 05:30 AM
stevegauth30
Jeez, I find a good build to follow, and it's done. Whaaaa?
Old 09-20-2014, 05:31 AM
stevegauth30
Looks awesome by the way!
Old 09-20-2014, 08:22 PM
foodstick
foodstick's Avatar
Well its not much of a video.. but it HAS flown ! I REALLY need to add down thrust in the motor, wow it wanted to point straight up under high power...at first I thought I was a little tail heavy, but it behaved very well on low throttle landing approach.. I am happy
Dusk patrol 1 for the Nieuport 11...
https://www.youtube.com/watch?v=xdpFs9rd1pU
Old 09-21-2014, 03:08 AM
stevegauth30
A Hugh congrats from me to you!
