Reload this Page >
Sig 4 * 120 Mods........
Old 02-14-2015, 09:06 AM
flygilmore
flygilmore's Avatar
Default Sig 4 * 120 Mods........
I've debated one for a long time now but if I did build it, there would def. have to be changes.
First, IMHO, this plane has to have wheel pants. What size a d where to get? Also, I'd want a cowling of some sort as I hate the "cheeks" on these. Again, what do you suggest that have done this before?
I would want to get rid of at least 2 bays on the wings and round the tips. There are other things I'd do but I wanted to know where and what sizes on the cowl and pants first.
Thanks for any insight you can give!!
Old 02-14-2015, 11:35 AM
aymodeler
aymodeler's Avatar
Fiberglass Specialties has an assortment of generic wheel pants listed on their site, sorted by shape (profile) and wheel size. I would just pick a set in shape that looks good to you and that is sized to fit whatever wheel size is recommended for your plane.
Old 02-14-2015, 11:40 AM
aymodeler
aymodeler's Avatar
BTW, Fiberglass Specialties also lists a "Cap-21" style cowl for a Sig 4* 120. Their website is a bit clunky, but if you look under "Cowls for Kits", then under Sig, you will see it listed.
Old 02-14-2015, 01:11 PM
flygilmore
flygilmore's Avatar
Thanks for the help. Anybody else care to chime in with anything?
If I did one of these, I was thinking of:
-doing a symmetrical airfoil
-sheeting leading edge of wing w/capstrips
-sheeting turtledeck
-changing canopy somehow
-taller gear for better handling
-maybe some slight tail mods
Basically, I want to make it more aerobatic and look like a Dragon Lady somewhat.
Thoughts??????
BTW, I built one of the 40 size back almost 20 years ago....... my first kit build ever. Now, here I am with 150+ kits under my belt I'm wanting to do another for an XYZ 20cc I got from VVRC.
Old 02-14-2015, 01:38 PM
flygilmore
flygilmore's Avatar
I was looking at Sigs site and I absolutely love the canopy and cowl on the 64" 4Star ARF........why don't they include those in the kits? I hate the canopy in the 4Star kits.......
If I could get a cowl and canopy like those for the 1.20, I'd be all in for it!
Old 02-14-2015, 05:36 PM
repirazz
repirazz's Avatar
What alot of us have done is cut the front part of the canopy off at the windshield line & flip it around and mount it backwards with some creative trimming for a little smoother look. This is a 60 size one but i would think it'd work for the 120 size as well.
Old 02-14-2015, 09:42 PM
foodstick
foodstick's Avatar
You can kit bash the 4 star into lots of planes .. I have built an me 109, and a Spitfire. I always liked to install the landing gear in the wing as well.
Old 02-15-2015, 07:26 AM
cordell staker
cordell staker's Avatar
Default Mello Yello
My 4 star 1.20…. Clipped two bays out of each wing side, put on a saito 1.80, enlarged the tail and rudder areas, set the wing up for "crow" and flaps. I am in a re-make now going to cut the rudder size back down, removed the crow option, trying to get lighter. The gear is soft and too low, Graph tech makes a carbon fibre one I may use. This is a Sunday Flyer. The 1.80 sucks up the fuel. Fun to fly, but…. just Fun to Fly.
Name:	mello yello.jpg
Old 02-15-2015, 08:03 AM
loopdeeloop
Here is a picture of my 4-Star 60 with a cowl. I wish I could tell you where it came from but it was included with the kit that I bought out-of state. Never thought to ask where it came from. The cheeks had to be cut back to utilize this cowl and it had to be split horizontally for installation and removal. I added tabs with blind nuts to accommodate the mounting screws at the split.
Name:	2015-02-15 07.44.40.jpg
Old 02-15-2015, 09:43 AM
flygilmore
flygilmore's Avatar
I think I read that you can get a Cap 21 cowl from Fiberglass Specialties for the 1.20 4Star so I may go that route.
You guys think with about a 72" span that this bird could do a Lomcevak? Of course, it would need a bit more elevator/rudder area.
Thanks for the pics guys!
Old 02-15-2015, 03:02 PM
acdii
I built mine with the last bay removed and rounded tips. Also moved the elevator servo to the rear, and used pull/pull for the rudder. As a profile mine looks like a Corsair, so a rounded cowl would be perfect for it, maybe round the tail feathers too for a more Corsair like look. I found mine to be too nose heavy and set it up with flaperons, to help slow it down, so my gear is a bit squashed from too many hard landings, so need a different gear now. I got the balance right now, so my landings are much more gentle.
Old 02-16-2015, 04:12 PM
RVator
A guy in my old club had one with a g23 and a Cap cowling on it with wheel pants.
Old 02-16-2015, 04:19 PM
acdii
If I do anything different to mine it would be a FG-30 Saito upgrade, and cowl.
Old 02-16-2015, 07:57 PM
Redtail_Customs
I just started my 4 star 60. I have the FG cowl and wheel pants from FIberglass specialty. Going for a squint scale cap 21. The plan enlage the rudder witha air balancer same with the elevator . Move the rudder back so the hinge line even with the back of the stab .
cut off one bay dle 20 R for the engine servos in the tail pull pull ruder sheet the turtle deck and th sheet the leading edge with contest grade balsa
Jim
Old 04-20-2015, 07:49 AM
Constrictor
My Feedback: (46)
Constrictor's Avatar
Ys 160dz
Old 04-24-2015, 05:37 PM
DMehalko
My Feedback: (42)
DMehalko's Avatar
DLE40cc
