Reload this Page >
Sig 1/4 Scale J3 Cub w/floats build thread
Old 04-15-2015, 03:52 PM
JHays
Default Sig 1/4 Scale J3 Cub w/floats build thread
Here we go again, new project with an old stick build kit. What can I say, I love the smell of balsa and CA in the evening
Yes this will be a Sig 1/4 J3 Cub (again? ) and it will be set up for land and water with Sig floats.
I like to post a lot of pics, comment and questions are welcome.
Let's start!
ID:	2089370   Click image for larger version
ID:	2089371   Click image for larger version
ID:	2089372   Click image for larger version
ID:	2089373   Click image for larger version
ID:	2089374   Click image for larger version
ID:	2089375   Click image for larger version
ID:	2089376   Click image for larger version
ID:	2089378   Click image for larger version
ID:	2089379   Click image for larger version
ID:	2089380   Click image for larger version
ID:	2089381   Click image for larger version
Old 04-15-2015, 06:32 PM
RagwingFan
My Feedback: (31)
Great kit. I have built a few in the past. Even modified on to a E-2 Taylor Cub. Lot of sticks but builds a great plane. we will be watching this build
Old 04-16-2015, 11:02 AM
cubcrasher
Cool beans. This is the best Cub on the planet.
Old 04-16-2015, 11:06 AM
cubcrasher
Here's a little appetizer.
ID:	2089615   Click image for larger version
Old 05-06-2015, 08:04 AM
JHays
Working on the fuse.
- Build both fuse sides
- Joining sides with bulkheads and cross members
- Build and added forward fuse with firewall.
ID:	2094293   Click image for larger version
ID:	2094294   Click image for larger version
ID:	2094295   Click image for larger version
ID:	2094296   Click image for larger version
ID:	2094297   Click image for larger version
Old 05-06-2015, 08:05 AM
JHays
Fuse build
ID:	2094299   Click image for larger version
ID:	2094300   Click image for larger version
ID:	2094301   Click image for larger version
ID:	2094302   Click image for larger version
ID:	2094303   Click image for larger version
Old 05-06-2015, 08:07 AM
JHays
Fuse build, cont
ID:	2094305   Click image for larger version
ID:	2094306   Click image for larger version
ID:	2094307   Click image for larger version
ID:	2094308   Click image for larger version
ID:	2094309   Click image for larger version
Old 05-06-2015, 08:08 AM
JHays
Fuse buld, cont
ID:	2094311   Click image for larger version
ID:	2094312   Click image for larger version
Old 05-06-2015, 11:47 AM
cubcrasher
Good idea putting a little glass on the nose joiner. I'll have
to remember that on my next build. You know this is not a hard
plane to build, just a lot of it. The end results are well worth
the effort.
Old 05-28-2015, 12:15 PM
JHays
Worked on the wing attach point and fuel tank instalation.
ID:	2099220   Click image for larger version
ID:	2099221   Click image for larger version
ID:	2099222   Click image for larger version
ID:	2099223   Click image for larger version
ID:	2099224   Click image for larger version
ID:	2099225   Click image for larger version
ID:	2099226   Click image for larger version
Old 05-28-2015, 02:35 PM
cubcrasher
I see you got some blind nuts in the firewall. What power plant you gonna
use in this baby?
Old 05-28-2015, 02:38 PM
JHays
Saito 120.
Old 05-28-2015, 09:33 PM
cubcrasher
Excellent choice.
Old 12-10-2015, 12:09 PM
JHays
Back at it, here are the latest pics from the build.
ID:	2135225   Click image for larger version
ID:	2135226   Click image for larger version
ID:	2135227   Click image for larger version
Old 12-10-2015, 12:11 PM
JHays
ID:	2135229   Click image for larger version
ID:	2135230   Click image for larger version
ID:	2135231   Click image for larger version
ID:	2135232   Click image for larger version
ID:	2135233   Click image for larger version
Old 12-10-2015, 12:14 PM
JHays
Engine and cowl instalation
ID:	2135235   Click image for larger version
ID:	2135236   Click image for larger version
ID:	2135237   Click image for larger version
ID:	2135238   Click image for larger version
ID:	2135239   Click image for larger version
ID:	2135240   Click image for larger version
ID:	2135241   Click image for larger version
Old 12-10-2015, 12:16 PM
JHays
Landing gear build
ID:	2135244   Click image for larger version
ID:	2135245   Click image for larger version
ID:	2135246   Click image for larger version
ID:	2135247   Click image for larger version
Old 12-10-2015, 12:25 PM
RagwingFan
My Feedback: (31)
Looking good. Brings back good memories. Great stick kit that makes a fantastic flyer.
quick thought to share. My last one, I made a 3 piece wing vs 2 like the plans show. Not sure if you have considered. Pretty easy modification by replicating plans 2 pc attachment system.
Old 12-10-2015, 12:52 PM
JHays
Great idea, I think that is what I will do!
Old 12-11-2015, 10:00 PM
Leroy Gardner
Surprised you cut the whole bottom out of the cowl, it could have been more enclosed seeing how the engine head doesn't stick out the bottom. Good Idea on the wing tube, you will find out why when you put it together at the field, it's a PITA and need two or three guys to do it.
My plane is a 1/4 scale balsa kit made into a super cub, wings on using the tube as it's only support making it easy to put the struts on by one guy. You might even like making this tail wheel assembly.
Leroy
ID:	2135476   Click image for larger version
Old 01-10-2016, 01:54 PM
JHays
Continuing on the build
- finished the tail feathers
- Working on the wings strating with the center section.
- Going to be a three peace wing with a little modification.
Name:	100_5405 - Copy.JPG
ID:	2140728   Click image for larger version
Name:	100_5407 - Copy.JPG
ID:	2140729   Click image for larger version
Name:	100_5393 - Copy.JPG
ID:	2140730   Click image for larger version
Name:	100_5394 - Copy.JPG
ID:	2140731   Click image for larger version
Name:	100_5395 - Copy.JPG
ID:	2140732   Click image for larger version
Name:	100_5397 - Copy.JPG
ID:	2140733   Click image for larger version
Name:	100_5398 - Copy.JPG
ID:	2140734   Click image for larger version
Name:	100_5399 - Copy.JPG
Name:	100_5401 - Copy.JPG
ID:	2140736   Click image for larger version
Name:	100_5404 - Copy.JPG
Old 01-10-2016, 04:31 PM
RagwingFan
My Feedback: (31)
Nice work
keep it up
Old 01-02-2019, 05:35 PM
JHays
Default Back at it
Trial fit
Trial fit
Trial fit
Old 01-02-2019, 05:39 PM
JHays
Default Still at it
Old 01-02-2019, 05:43 PM
JHays
