Reload this Page >
Glenn Torrance 1/4 scale DR1
Old 01-21-2016, 05:12 AM
barzini
Default Glenn Torrance 1/4 scale DR1
Hello,
Has anyone built the 1/4 scale Glenn Terrance DR 1?If so I would like to know how the build went,how it flies,engine used? Any help is appreciated.
Old 01-22-2016, 08:09 AM
vertical grimmace
vertical grimmace's Avatar
Do you have a kit? Those have not been available for a long time. Glenn focused on the 1/3rd scale stuff later on and now it would seem he is just not producing anything anymore other than fabric (thankfully).
I have built a couple of his DR1 cowlings, and many of his detail items. A guy here built the 1/3rd DR1. The build is a little built different than what RCer's are used to, but they are very scale. That being said, I will bet it is a handful on the ground. I have a BUSA 1/4 tripe, and have built 2. Even with the cheats to scale that they did, my DR1 is not easy on the ground. It really likes a headwind to keep it pointing straight. As for engine, The Saito FG 30 would be good, or a 150 glow. I had a 180 in my first tripe. I am using a DLE 35 RE in my current one. I have my engine buried in the fuselage to keep it hidden. I had to box it back to achieve this, as the scale nose is so short. A lot of work, but it looks so much better.
Good luck with the build, Triplanes are a blast!
Old 01-23-2016, 01:32 PM
barzini
I have the kit and I'm trying to decide if it will be my next build or the Mick Reeves 1/4 Camel.
Old 01-24-2016, 02:28 AM
jeffo
My Feedback: (68)
Barzini,are you still flying your Jeep,I'm building one now.What would be the best size engine?jeffo
Old 01-24-2016, 10:38 AM
barzini
Mine flies great with a zdz 60
Old 01-24-2016, 02:04 PM
jeffo
My Feedback: (68)
I'm putting a 3W70 in mine,should I put a prop with more pitch (24/10) or less pitch (26/6).jeffo
Old 01-24-2016, 02:19 PM
barzini
I use a 24x10 on my zdz 60
Old 01-25-2016, 01:50 PM
jeffo
My Feedback: (68)
Did you put any right thrust and down thrust in your jeep?
Old 01-27-2016, 08:01 AM
barzini
Jeffo,
Email me
[email protected]
