1/6 clipped wing cub questions
When installing an os48 surpass, how far back do i need to move the firewall. Any info on installing servos in each wing, instead of using the bellcrank
My Feedback: (9)
CA
I usually mount the engine on the engine mount first then lay it over the plan to see where things fall. This gives a rough idea but usually pretty accurate of what you need to allow for to move the firewall back. The dimensions could vary depending on the engine mount you are using and how you are mounting the engine.
I am not sure what you need to know specifically about using servos in the wings instead of bell cranks.
Sam
Sam
