Sig Hog Bipe - Glow or Electric
Reply
Old 08-28-2017, 04:35 AM
_brad_
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Hog Bipe - Glow or Electric
Hi,
I am in the process of building a Sig Hog Bipe from a kit. I fell in love with this plane when I saw it at the field and I just "had" to have one.
I am deciding on maybe going towards my first electric plane with the Hog Bipe.
Does anyone have any input on this matter? Should I make the conversion, or just keep it as a glow plane? I do not have the glow engine, so I will be needing to purchase with the glow or electric motor.
Thanks in advance for any help regarding this.
Brad
_brad_ is offline
Old 08-28-2017, 06:33 AM
aymodeler
aymodeler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I only fly electric and at mid to small sizes (say glow 60 equivalent and below), you can't beat the power to weight ratio. The Hog Bipe, like most Sig kits is a good platform for electric conversion. I am in the process of building one as an electric right now, and it has been a fairly easy conversion. That said, if you are not currently flying electric, it does represent a fairly significant commitment to batteries, a good charger and various odds and ends that do tend to add up. You will be on your own to select motor/battery/ESC/prop combo (you will be able to find plenty of help here or from others who have done it, but Sig does not offer any specific advice).
If this is truly your first electric, I would recommend starting with a project that is designed specifically for an electric option. That will take a bunch of variables out of the equation allow you to start accumulating the hardware bits and the knowledge with confidence. Of course, if you have a good resource at your club that can help point you in the right direction, that could change the equation too.
aymodeler is offline
Old 08-29-2017, 03:42 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have several electric powered models, so I have nothing against them. I do know that the 4 stroke powered Hog Bipes, that I have seen, are among the best flying models at any flying field.
I suggest that you take a long look at placing a suitably sized four stroke in your hog Bipe.
TomCrump is offline
Old 08-29-2017, 04:27 AM
_brad_
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks so much for the input on this - much appreciated.
I will keep the glow suggestions and not go electric. I fell in love with this plane when I saw it at the field.
Looking forward to having it built.
_brad_ is offline
