Making large holes in Lite Ply
Reply
Old 09-04-2017, 10:20 AM
thailazer
thailazer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Making large holes in Lite Ply
Just starting a project and was going to use the hole cutter to make some lightening holes in a some lite ply fuselage sides. Even using the hole cutter, the lite ply will splinter and not leave a finished look. What methods are good for making 1 inch to 2 inch holes in light ply that leave a nice sharp edge with no splinters?
thailazer is offline
Old 09-04-2017, 10:32 AM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think your best bet is to find a fine tooth holecutter.. or maybe they make one with more of a grit? than teeth... Also I have had the same kind of issues and often use a sanding drum to go in and clean up the edges after the hole saw.
I never mentioned also this is probably easier on a drill press, than a hand held. I hope you get it perfected and keep building !
foodstick is offline
Old 09-04-2017, 10:38 AM
3dorbust
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Large holes
A router with a flush cut bit make a round template first that the router will run inside mount it with clamps or wood screws
3dorbust is offline
Old 09-04-2017, 11:18 AM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A hole saw run part way through on both sides normally cuts a clean hole. Another option is to use a hole saw one size smaller and drum sand to finished size as Foodstick recommended. I've done both with good results though, when it comes to the sanding, I use this drum/horizontal belt sander to finish the holes:
Hydro Junkie is online now
Old 09-04-2017, 01:00 PM
flyboy2610
flyboy2610's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use a drill press, use a backer block for the lite ply, use a hole cutter, and when the teeth are a bout halfway through the ply, flip it over and finish the hole from the other side. It still may need a little sanding to clean up, but it will look a lot better.
flyboy2610 is offline
Old 09-04-2017, 01:22 PM
thailazer
thailazer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey, Thanks all for the suggestions! I think I am going to grind down my hole cutter as it is indeed way to aggressive. Backing plate is a good idea too, and I do usually cut in from both sides. Appreciate the help.
Old 09-04-2017, 06:37 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I uase a forstner bit. Dan.
All Day Dan is online now
Old 09-04-2017, 08:55 PM
rrembert
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1
rrembert is offline
Old 09-05-2017, 07:25 AM
Hemikiller
My Feedback: (125)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A good sharp Forstner bit should give you a reasonable finish. The cylindrical hole saws have too low a tooth count.
Hemikiller is offline
Old 09-05-2017, 08:54 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wonder if one of these would work?
Hobbico Circle Cutter
FlyerInOKC is offline
Old 10-02-2017, 04:26 AM
thailazer
thailazer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you have hit on the best way to cut those holes! A bit more time and equipment involved but those router bits do indeed produce a clean cut. Do you have a source for 1/8 inch shank router bits with the ball bearing for use with a Dremel tool? Been looking and have not found one yet. That would be handier than a bulky router with the larger shank.
For now, I have found that my Milwaukee hole cutter does a decent job if I run the drill backwards. Thanks again for all the inputs.
Old 10-06-2017, 01:27 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Large Forstner bits will make perfect clean cut holes that look like they were cut with laser precision. The bits are a bit expensive but well worth it if you are cutting quite a few holes. I have bits from below 1/4" to over 1.5".
For relatively soft woods like Lite Ply or balsa, you can also make a hole cutter from a piece of thin wall SS tubing of the correct size. You sharpen one end of the tubing from the inside and afix the other end to some kind of handle. Rotate the tubing against the wood using light pressure and it will cut like a die. You can get very clean cut holes using this method. Brass tubing works well for smaller holes.
Truckracer is offline
Old 10-07-2017, 02:57 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Forstners here too. I found that cutting from both sides gives the cleanest cut, very little sanding needed.
acdii is offline
Old 10-07-2017, 08:38 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I forgot about cutting the holes from both sides. Good call! Otherwise the bit may catch on the thin ply and tear it.
