Building original curare kit
Reply
Old 11-11-2017, 11:48 PM
hendrik-brink
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Building original curare kit
Hi everyone
i am building an original curare kit from the seventies. Anyone have build tips for me? I have built balsa kits before (middle stick, sky tiger, hi-fly) but not sure how I should finish the curare - cover or paint? I am using an vintage rossi .60 wih pipe
thanks!
hendrik brink
south africa
hendrik-brink is offline
Old 11-12-2017, 08:41 AM
mgnostic
mgnostic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The downloads page at the Outerzone includes a magazine article with a brief description of how that particular model was finished.
mgnostic is offline
Old 11-12-2017, 09:32 AM
442dave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow those are awesome planes. Congrats on such a find. I'll be watching your build thread.
442dave is offline
Old 11-12-2017, 11:43 AM
hendrik-brink
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks dave I will keep you posted!
Old 11-12-2017, 11:45 AM
hendrik-brink
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Matt
Old 01-11-2018, 11:12 PM
hendrik-brink
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default help on building the curare kit
Hi everyone. Im progressing on building the curare kit, but I have a question : the plans state that the engine should have 0 to 3 degrees of down thrust. I will be using a rossi .60 motor so im thinking 2 to 3 degrees of thrust should ne enough? Also, from where do I measure the degree? (Please see attached on the plan) from the back of the engine or the middle of the engine?
Regards
hendrik brink
south africa
ID:	2250747   Click image for larger version
Old 01-12-2018, 06:02 AM
RICKSTUBBZ
RICKSTUBBZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Technically you set the 3 from the spinner back plate.
However, best I can tell, you can shape the cowl area after the engine is mounted.
So, set the 3 in such a way that everything fits. Make sure all four mounting screws have enough wood under them to mount properly.
RICKSTUBBZ is offline
Old 01-12-2018, 09:34 PM
hendrik-brink
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the reply Rick, does that mean I should measure the 3 degrees from the spinner backplate as in the attached picture?
regards
Old 01-13-2018, 04:53 AM
ETpilot
ETpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The attached picture should help. You want the engine angled down 2-3* in your case. The bottom side view shows bulkhead #1 mounted vertically and the engine angled down from that point. The upper top view shows the engine mounts angled to the right. Picture that as a side view and the engine would be angled up. You would want the opposite with engine angled down. Hope this is clear. I measure the angle at the firewall. Measuring from the spinner as you have it, the engine would sit higher in the cowl area and may not fit properly. If the plan shows a thrust line thru the firewall, I would measure there. Just the way I would do it.
ETpilot is offline
Old 01-14-2018, 05:21 AM
hendrik-brink
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks very much for your help! I will measure the angle feom just behind the engine then, that should give enough space and provide ample clearance
regards
Old 01-17-2018, 07:52 AM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by hendrik-brink View Post
Hi everyone
thanks!
hendrik brink
south africa
Lots of help in the Classic Pattern forum. Classic RC Pattern Flying - RCU Forums
Or on RCU in the Classic Pattern forums.
dhal22 is offline
