American Eaglet-Spirit of Yesteryear
Reply
Old 01-07-2018, 02:09 PM
TLC416
TLC416's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default American Eaglet-Spirit of Yesteryear
This is my first kit build, so as suggested by another member, Iím posting the build as I go so as to get help along the way. If you see something that donít look right or can be improved upon, please give your advise.
Hereís a few pics as I start.
ID:	2250305   Click image for larger version
ID:	2250306   Click image for larger version
ID:	2250307   Click image for larger version
ID:	2250308   Click image for larger version
ID:	2250309   Click image for larger version
TLC416 is offline
Old 01-07-2018, 02:16 PM
TLC416
TLC416's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After building the first side, I build over the top of is, as per the plans.
Iíve already hit something I need help with. Take a look at the instructions, paragraph where it talks about vertical cross pieces at C D N. Not sure what itís talking about and donít see anywhere on the plans ďNĒ location.
ID:	2250312   Click image for larger version
ID:	2250313   Click image for larger version
TLC416 is offline
Old 01-07-2018, 02:19 PM
TLC416
TLC416's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, it tells you to bevel the inside edges so both are equal to rudder of 3/16”. What’s a good way to do this? I would think sanding would be the easiest but not while pined to the board.
TLC416 is offline
Old 01-08-2018, 08:19 PM
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sanding is what I do, when I've got the main formers in and I'm pulling the two sides together, then a thin piece of ply with sandpaper glued to both sides...stick in between and slide back and forth. I do not worry about getting it the same thickness as the rudder. No one will notice it, and it will have no effect on flight.
buzzard bait is offline
Old 01-12-2018, 03:52 PM
TLC416
TLC416's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Man, what a learning curve. After studying the plans over several more times, I found the references the instructions were talking about. It was on another part of the plans. So the build is back under way. The sheeting was way more tough than I had imagined it would be. Not only is it curved and tapered, it also was at two angles, so it had to be done in two stages. It turned out fair. I ended up using windex to soften the sheet of balsa, worked well.
ID:	2250872   Click image for larger version
ID:	2250873   Click image for larger version
ID:	2250874   Click image for larger version
TLC416 is offline
