Is Balsa like a fine Wine?
Reply
Old 09-02-2018, 08:30 AM
Electriceddie
Electriceddie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Is Balsa like a fine Wine?
Hi Guys,
I was wondering does anyone know what the lifespan of Balsa is if it is kept well over the years? It all looks good No warps, not brittle etc.
Ed
Electriceddie is offline
Old 09-02-2018, 11:13 AM
aymodeler
aymodeler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd say you kind of answered your own question ... If it not warped or brittle, or has any obvious signs of mold or insect damage, it is probably OK.
aymodeler is offline
Old 09-02-2018, 11:20 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I acquired a huge stock of balsa over the years that I pick from when building and supplement with new wood as required. The only problem I have ever found with my old stock is that exposed surfaces seem to oxidize a bit over the years. Glue doesn't stick to this dusty, oxidized surface but a quick pass or two with a sanding block resolves the issue.
I can't say that balsa improves with age but I can't see that it degrades much either.
Truckracer is offline
Old 09-03-2018, 04:10 AM
Appowner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The key is moisture content. As long as it's moisture is maintained, it should last as long as any wood will.
Appowner is offline
Old 09-03-2018, 05:30 AM
r ward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Appowner is correct.
balsa is like any other wood, the conditions of it's storage will be the determining factor for the condition of it's usefulness and lifespan. it is very a porous wood, it absorbs moisture like a sponge. like any other wood,.... if stored for long periods,...storing in a cool dry place out of direct sunlight and sealing the ends of a board with shellac or fingernail polish will do a lot to keep it dry and light. be sure it is laid flat and/or if stacked straight up, leaning as little as possible.
r ward is offline
Old 09-03-2018, 06:56 AM
Lee Taylor
Lee Taylor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Food for thought: I saw a claim a while back, that stated, by weight, balsa costs more than gold....
Lee Taylor is offline
