TF Beechcraft Bonanza F33A Build
Reply
Old 09-12-2019, 02:02 AM
  #251
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Servo bracket after glass beading. Wasn't really necessary to do this step, but it sure does make it look purdy!!!
VincentJ is offline
Old 09-12-2019, 04:34 AM
  #252
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now you are just showing off! I like it, I like it!!!!
FlyerInOKC is offline
Old 09-12-2019, 06:44 AM
  #253
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL, Thanks Mike!
VincentJ is offline
Old 09-15-2019, 03:02 AM
  #254
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The aileron's servo wire is far too short to to reach its exit point at the top of the wing. This is a common problem that is easily rectified by adding in an extension to lengthen the lead. I want to make sure that the electrical connection never separates so I use heat shrink tubing to solve this problem. Here I've slipped a length of heat shrink over the extension wire.
Simply slide the connector somewhere beneath the center point of the heat shrink.
Using a heat gun, shrink the tubing. Some builders use a lighter for this purpose, but I prefer not to use that method, as it can apply too much heat melting the insulation wires beneath.
This is how it should look like completed. Trust me in that this connection worn't separate and it will also be protected from moisture. In the future, should this connection need to be separated, simply slice the heat shrink off...
VincentJ is offline
Old 09-15-2019, 05:01 PM
  #255
mkjohnston
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Vincent, I did exactly the same thing with my dual Ailerons on my A-Ray. Do you a Y adapter where the leads come together in the center of the wing? I did this but I also bought a reverser that i got a swap meet and I was talking to a fellow modeler who told me that I didn't need this because i could just put the link on the opposite side that rotates the other direction. I have not finished construction yet on this wing but i have two other wings that will need the same set up! I hope to get this done this year but I have working very long hours lately and don't have much free time except on weekends
Thank You
Michael
mkjohnston is offline
Old 09-15-2019, 06:07 PM
  #256
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As cheap as servos are now days it doesn't make sense NOT to have dual servos for the ailerons and the flaps. In some cases I have added a separate servo for a nose and/or tail wheel.
Old 09-15-2019, 11:19 PM
  #257
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank You
Michael
Michael, I'm not using a "Y" harness because I dedicate separate channels for each servo. I prefer this method, as I can adjust each servo independently. If you've got the channels in your transmitter why not use them!
I hear you on the long hours. After a long day at work, I head to the gym for 1-1/2 hours, then home to cook dinner and eat. By that time I'm beat and too tired to make it into my workshop.
VincentJ is offline
Old 09-15-2019, 11:25 PM
  #258
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[QUOTE=FlyerInOKC;12550551]As cheap as servos are now days it doesn't make sense NOT to have dual servos for the ailerons and the flaps. In some cases I have added a separate servo for a nose and/or tail wheel.[/QUOTE
Mike I agree with you. Any time I'm building and the plans call for a single servo to actuate two ailerons, that is the first thing that gets that gets changed using two servos...
VincentJ is offline
Old 09-16-2019, 03:26 AM
  #259
EF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The shrink over the servo-extension connection is obviously a good thing, but why do you bother with this connection instead of simply cutting off the plug and receptacle, and making a soldered connection between servo and extension?
I always extend the servo leads that way, and have found it to also be economical (I buy servo wire by lengths of several meters, very cheap). If you need to replace a servo (a rare occasion) you can always cut the wires and re-solder a new one.
EF is offline
Old 09-16-2019, 04:23 AM
  #260
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is absolutely nothing wrong with your logic here EF. I know many modelers that do exactly that. With virgin connectors on both ends, the chance of having a electrical failure is pretty slim so I can trust it to do its job. So for me it's just easier to plug and play sort to speak. If, on the other hand I were using a used servo or extension lead, then your method would prove more reliable. Thanks for your thoughts!
VincentJ is offline
Old 09-16-2019, 06:56 AM
  #261
GameEngineer
GameEngineer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree. I've even seen separate servos for each gear door. I started a TF P-51 years ago and its still sitting in a half-built state. It has single servo with bellcranks for the ailerons but I plan on modifying it to dual servos. In my recent work I've opted for Y-cables but I see the value in using separate channels for ailerons (aileron and Aux in my case).
GameEngineer is offline
Old 09-16-2019, 10:33 AM
  #262
mkjohnston
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Vincent, I just happend to have Futaba 8JA and I think there is mod in the set up where i can do that I just havent got that far into the programming end yet! I work night M-F and the last two I came in at 5:30 pm. I didnt get off until 8 am the next day and this happened almost every day that week and to the middle of last week when it started to trend down. Mondays are always the worst day. so we shall see thanks
Michael
