Reload this Page >
TF Beechcraft Bonanza F33A Build
Old 10-17-2019, 01:57 AM
  #326
VincentJ
VincentJ's Avatar
Originally Posted by EF
You might want to consider capping the wing cutout and surface edges with 1/64 ply.
I do it on most of my builds because it gives a super sharp edge that stands up to wear and tear over the years.
Yes I agree! I'm sure the 1/64" was just a typo, but your idea is spot on. The entire plane EF will be clad in half ounce glass as well giving the entire skin added strength and durability...
Old 10-17-2019, 02:29 AM
  #327
EF
Actually, the 1/64” wasn’t a typo, that’s 0.4 mm thick.
My LHS stocks it, and it’s all you need for a crisp end.
The f/g covering should suffice though.
Old 10-17-2019, 03:00 AM
  #328
VincentJ
VincentJ's Avatar
Wow, that's pretty thin stuff!
Old 10-17-2019, 05:27 AM
  #329
FlyerInOKC
FlyerInOKC's Avatar
My LHS stocked too before going under. The downside is the cost when you get that thin.
Old 10-17-2019, 05:43 AM
  #330
EF
Yes, it doesn’t come cheap, but then you don’t really need too much for such applications.
I first came across this technique while scratch building scale models designed by the British scale master builder David Vaughan, and after trying it I decided to utilize it often.
Waiting to see a video of the RDS in operation...
Old 10-17-2019, 09:43 AM
  #331
VincentJ
VincentJ's Avatar
You and me both EF! lol
Old 10-17-2019, 07:21 PM
  #332
Hydro Junkie
Hydro Junkie's Avatar
Guys, you're just looking in the wrong places. I can get a square 61" sheet of .4mm(1/64") 3 ply plywood for $104(plus sales tax of course) from a shop in Tacoma WA, just have to drive down to get it.
Old 10-18-2019, 04:56 AM
  #333
FlyerInOKC
FlyerInOKC's Avatar
The problem here is there aren't places carrying 1/64" like you have in Tacoma. I can get it from Aircraft Spruce but a 48" square sheet ends up at $189 with freight with the freight being 2/3 of the cost. A half sheet 24" X 48" works out to be ^4.50. I can go to Balsa USA and order a 12" X 48" sheet but with shipping and handling I'm still looking at $47.65.
Old 10-18-2019, 04:58 AM
  #334
VincentJ
VincentJ's Avatar
Ouch!!!
Old 10-18-2019, 05:09 AM
  #335
FlyerInOKC
FlyerInOKC's Avatar
!/32" plywood is half the cost of 1/64". The freight is so high because the cost of packing it to get it here in one piece and being oversized.
Old 10-18-2019, 05:42 AM
  #336
EF
Well, if we’re comparing costs of ply... my LHS is only a 10 minute drive for me and sells a 48” square of 1/64” for about 130 US, but this is useless information for most of you guys since you are on the opposite side of the Atlantic and the Mediterranean
Old 10-18-2019, 06:22 AM
  #337
FlyerInOKC
FlyerInOKC's Avatar
What does 1/8" X 4" X 48" Balsa go for in Israel now days?
Old 10-18-2019, 06:35 AM
  #338
EF
At the risk of getting too off topic here...
About 4 USD for a 36” length but an additional 50% for the 48” plus you need to buy at least 10 sheets because the LHS cuts it to order. I always splice sheets when I need that length.
Old 10-18-2019, 07:12 AM
  #339
FlyerInOKC
FlyerInOKC's Avatar
About the same as here. Anything new to report Vince to get us back on topic?
Old 10-18-2019, 09:48 AM
  #340
mkjohnston
Hi Mike, Mikes hobby shop go out of business in OKC? I was up there back in june and he told me that he was going to close shop at the end of June. I havent venture out that way since when but was just wondering.
thanks
Michael Johnston
Old 10-18-2019, 09:56 AM
  #341
mkjohnston
Hi Vince, your building technique is outstanding! thanks for sharing!
Michael Johnston
Old 10-18-2019, 10:25 AM
  #342
VincentJ
VincentJ's Avatar
Thank you Michael!
Old 10-18-2019, 10:29 AM
  #343
FlyerInOKC
FlyerInOKC's Avatar
thanks
Michael Johnston
I'm afraid Mike's Models is no more, Mike up and retired. I really miss him too. He was going to try and sell some stuff out of his house by Horizon won't sell to anyone without a brick and mortar store. There is a shop on the south side but he is mostly R/C cars. It took him over 2 weeks to get two rolls of Monokote in.
Mike
Old 10-18-2019, 10:38 AM
  #344
VincentJ
VincentJ's Avatar
Builder's tip:
It just occurred to me that I had forgotten to mention a certain step while gluing in the remaining sheet of balsa on the aileron surface that I think you will find useful. As you know the top portion of the aileron was sheeted, but the bottom surface was left uncovered. After the hinge blocking was installed I spread Titebond glue on all of the rib surfaces in preparation of the bottom skin. I did not apply Titebond along the trailing edge of the aileron's sheeting, instead I used a thin bead of epoxy. Try this the next time you join the top and bottom TE on your aileron or flap and you will find that the epoxy will give you a very rigid edge that the Titebond glue won't be able to do.
Old 10-18-2019, 10:59 AM
  #345
FlyerInOKC
FlyerInOKC's Avatar
Now that is a good idea!
Old 10-18-2019, 01:25 PM
  #346
VincentJ
VincentJ's Avatar
You may have been wondering how I was going to be able to install/remove the drive shaft ...note the hole directly in front of the servo hatch.
A picture is worth a thousand words...
The right aileron was cut free from the wing, the remaining hinge blocks were fitted and glued in place.
Old 10-18-2019, 07:55 PM
  #347
FlyerInOKC
FlyerInOKC's Avatar
Nice job!
Old 10-19-2019, 10:01 AM
  #348
VincentJ
VincentJ's Avatar
Making sure that everything is lining up as it should before I start drilling.
Old 10-19-2019, 11:26 AM
  #349
VincentJ
VincentJ's Avatar
Note that I drilled for my hinges before I beveled the leading edge. One side of the bevel done.
You can see my scribe line that guides me.
Hinge hole detail.
Hinge pin fully seated.
Finally, both ailerons are done. That was a bit of work!
Nice tight hinge line gap.
Old 10-19-2019, 05:44 PM
  #350
FlyerInOKC
FlyerInOKC's Avatar
Great! hat is the way to do a hinge gap!
