Joining wing halves/ covering
Moderator
I'm building a Tiporare, and it's time to cover the wings. I'm planning to cover them in silkspan with dope. My question is about reinforcing the wing center. Should I glass it first with resin, feather the edges, and then put the silkspan over it? Or should I put the silkspan everywhere then glass? I do plan to follow the original instructions which said to do a wide layer and then a narrow reinforcing layer. But Hanson's instructions assumed the whole wing would be glassed, so I'm not sure how to proceed.
As much as it pains me to admit it, I have to agree with Shawn. I will add one detail though. Be sure to cut your fabric on the bias at + - 45. This will maximize the strength gained with the minimum fabric weight.
Scott
Scott
Cool, I have been using that resin for a while now and really like it. It does benefit from a post cure of 100 to 110F, especially if you use the slow catalyst. Did you figure the carbon gear out? I still need to order some fabric so let me know.
Scott
Sorry for the hijack Jester, you can have your thread back now......
Scott
My Feedback: (29)
Scott
Scott
