PSI for sheeting a foam wing
Reply
Old 10-07-2019, 03:14 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PSI for sheeting a foam wing
When you stack weight onto a foam wing for sheeting, does the PSI get split between the two sides, or do both sides get the full amount? For example, if I put 200 pounds onto a 200 square inch wing, would the resulting pressure be 1 psi or 1/2 psi on all the sheeting?
jester_s1 is offline
Old 10-07-2019, 07:31 AM
mgnostic
mgnostic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Presuming that there is an even weight distribution across both the upper and lower surface there will be one pound on each square inch on both the upper and lower surface. The force will follow the direction of gravity so this assumes that both surfaces are parallel and perpendicular to gravity. For practical purposes as long as there is enough force to hold the sheeting in contact with the foam, at least as long as you don't exceed the crush strength of the materials, then you have enough.
mgnostic is online now
Old 10-07-2019, 08:31 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The problem is that the weight distribution is never equal when doing weights. The only way to get uniform pressure is to vacuum bag.
speedracerntrixie is offline
