Preparing balsa for paint
Hello Guys,
I have a King Kobra (balsa sheeted foam wing) that I would like to paint. I want to use Dupont base coat clear coat, but obviously I have to prepare the basa surfaces first.
What type of primer should I use and should I seal the balsa first?
I have painted several cars so I understand how important it is to prepare the base first. My problem is I don't have the slightest clue on how to prep balsa wood. Also wouldn't a lacquer based primer dissolve the foam under the balsa on the wing?
Thank for the assistance.
RickP
RickP
RE: Preparing balsa for paint
Check out the Harry Higley book, "There Are No Secrets". He details an excellent way to put a good base on the raw balsa before you prime and paint. It uses epoxy finishing resin to harden the balsa and give you a good base for primer and paint. If it's done right, it's quite light and very durable.
bax
bax
