COVERING MATERIAL
IL
COVERING MATERIAL
A GUY IN OUR CLUB RECENTLY SHOWED A PLANE COVERED IN A IRON ON CLOTH LIKE COVERING WHICH YOU PAINT. I DON,T REMEMBER THE NAME OF IT OR WHERE TO BUY IT. CAN ANY ONE HELP ME ?
RE: COVERING MATERIAL
It may be one of 2 or 3 different types. The best (in my opinion) iron on material covering is Super Coverite. If that's what you want, get it quick from Tower Hobbies/Great Planes. They're doing a close out sale right now.
Get the Big rolls, and get a couple. The stuff will last on the shelf forever. I had a roll that took me 10 years to use up after I first opened the roll. The last foot was as good as the first.
Any of the tex's work well; Solartex from BalsaUSA, Colortex, Worldtex etc. You can also use Ceconite from Aircraft Spruce and Specialties which works very well and is probably the least expensive but most labor intensive as you have to put on an adhesive to the structure first. My favorite is Solartex--way superior to Coverite in MHO.
IL
THANKS GUY'S I THINK RODNEY IS RIGHT IT WAS SOLARTEX. I WILL TRY IT AND LET YOU KNOW.
PS CAN I PAINT IT WITH LATEX? DO I NEED TO USE PRIMER FIRST
You probably can paint it but there is a very large color selection out there...you'll probably be able to find the color you're looking for. I wouldn't recommend painting it. Since it's a flexable film the paint will tend to chip off after a while.
I've painted Solartex with just about every type of paint with good success. My favorite is no longer available--Petit's epoxy paint--but, if you are using gasoline most any inexpensive paint works well, even the cheap spray can stuff from the local thrift shop. I do not use primer and do not have any paint chipping or peeling problems. A top coat of some kind is very desireable on any of the cloth type coverings as the weave will hold dirt very well and make cleaning difficult as compared the the films.
