Telemaster 40 NG conversion
WA,
Hi Troop.........
Need some memory refreshment, if you will.
I am converting my Telemaster 40 from conventional to tricycle gear. The squeals of delight from the other guys at the field as I would shove the throttle in and then taxi in fast circles has convinced me that I need more stick time before I go back to a taildragger.[X(]
I've installed a Dubro nose gear and need to hook it to the rudder servo. Should I use a Ny-rod, cable & sheath, or wire pushrod? I'm leaning towards the Ny-rod.
How much angular travel should I allow for steering?
And lastly, how many degrees of negative angle of attack should I have at rest?
Any help will be appreciated.
Olderndirt
Olderndirt
RE: Telemaster 40 NG conversion
Hello Olderndirt,
Let's see if I can help[8D]
I would use a wire pushrod in a sheath similar to the one DuBro makes. Works for me!
You don't want anything that will flex or bend too easily.
On the servo/nosegear control horns, use the very shortest throws. A lot of throw will make the plane very squirrely on the ground.
On my planes, I try to use 0 degrees negative angle. Keep it level with the ground-IMO.
Hope this helps,
Scott
Hope this helps,
Scott
WA,
Scott........
Thanks for the poop.
By wire pushrod, do you mean a sheathed wire cable such as the one on my throttle?
Squirrely? You outa see it now! [sm=spinnyeyes.gif][sm=spinnyeyes.gif]
"Give it some left rudder!" "That's all I got!" "Next time it comes around, see if it'll lift off!" "RUN!!!!"
Rich
Rich
If you keep the throws down, you'll be able to make nice straight takeoff runs with a little practice
Scott
WA,
ORIGINAL: GoldenAge
No, You can find these at your local hobby shop. It's a solid (music) wire in an approx. 1/8" plastic sheath or tube similar to what you see in many push pull control linkages for rudder and elevator.
Scott
Scott
Rich
(Olderndirt)
