Curare 40??
Curare 40??
Hello!
Does anyone have an building instruction and/or drawings for the (old) Curare 40 kit?
I have the kit, but no papers....[]
Regards
Nokke
Regards
Nokke
AZ
RE: Curare 40??
If it was the Japanese MK kit, there were no instructions. Only several sketches on the main plans. You might be able to contact MK in Japan and see if they still have the plans.
Clair
Clair
RE: Curare 40??
Hej Nokke,
I believe the Curare 40 is similar to the Minare by Hanno Prettner.
Plans are available from:
http://www.vth.de/shop/shopfiles/tab...44&CID_Left=29
Hope this helps,
/Leo
Hope this helps,
/Leo
RE: Curare 40??
Hey Nokke:
Check the pattern section here at RCU. The Curare isd an old pattern bird. Someone there will be able to help you. Also I belive that MAN has plans for a curare, Maybe RCM. I hope this helps.
Mark Shuman
Mark Shuman
1 Post
RE: Curare 40??
I built a Curare 60 many years ago. From memory, it came with both instructions and good quality plans.
Curare was designed by Prettner and was a fantastic pattern plane.
Singapore Hobbies still sell several MK kits, including the Curare. You might try to contact them.
I think it is www.singahobby.com or maybe www.singahobbies.com
