How much dihedral in an LT40?
WA
I've got my table built and my kit on it. It's time to start building but I'm still deciding how much dihedral to put in the wing. I'm very seriously considering just building it flat! Being high wing it has natural dihedral anyways. I've flown a little before and am putting in time on flight sims. I will also have an instructor. Let me know if you think the plane will handle better! Thanks!
RE: How much dihedral in an LT40?
When I built mine I used 1/2 the dihedral called for. My Father-in-law used the normal dihedral. I couldn't tell that much difference in the way they flew. If you are aware that you'll lose some self correcting / leveling capacity I would talk to your instructor, if he agrees I'd build the wing flat.
Just my 2 cents.
John
Just my 2 cents.
John
My Feedback: (27)
ID
i'VE FLOWN A NUMBER OF CONFIGURATIONS, IT MOSTLY HAS TO DO WITH YOUR ABILITIES, PERIOD. I F YOU HAVE EXERIANCE THE FLATTER THE BETTER. REMEMBER YOU WILL GET BETTER REALLY FAST IF YOU GO WITH A FLAT WING. HAVE FUN......GIZMO
I agree with gizmo flat is nice I still have mine with a flat wing and its still great fun to fly .It is usually the first plane out of the hanger after not being out to the field for a while it helps give the confidence level a boost.good luck Dave
I've built it with stock dihedral and flat, and am just now building it with about 2 degrees.
Just so you know, the flat wing will be more agile that the stock dihedral, but on the ground you will take a lot of ribbing because of the 'droopy' wing. It just looks that way.
By the way, when I built it flat, I bought new balsa and ran the center section sheeting all the way across. I think it made it stronger.
The flat wing will fly inverted more easily and will roll much better. The changes won't be extreme or dramatic, but they'll be there..
Right now, I'm building a new one with about half the dihedral in it. Just something to bore holes in the sky with.. it'll be fun whichever way you make the wing..
You might also consider putting in two ailerons and running flaperons. Just remember that those wings have to be super straight and the flaperons have to drop evenly. Try them out one mistake high, straight and level, the first time if you go that route.
Enjoy...
Just my $.02
Bob
Enjoy...
Just my $.02
Bob
WA
I'm only using a 4 channel radio so I'm pretty sure I can't do flaperons. I'm definetly going flat! I've also added Dubro plastic landing gear instead of the wire main gear. I thought about going tail dragger on it but like the idea of the front gear protecting my engine. The only other mod I hear people recomending is to add support for the vertical stab as it can break loose from what I understand. Time to go start the wing on my pristine sheetrock covered table! Any other mods you can think of that I should incorporate? Appreciate all the help!
WA
Oh I don't know. Low wing loading and slower flying are still bonuses without all the self righting capabiltiy of the dihedral. Got one wing almost done! Still have at least an hour left on it though then it's on to the next one. Should go much faster! I was a little disappointed with the fit on some of the parts though, especially the web braces? The 2" pieces that go between the the ribs. Mine were short. I had to add small balsa braces to augment them. Seems like I shouldn't have to do that but my wing still looks good.
Regarding my comments about the LT-40, you can very definitely fly it on four channels, even with the modified wing (whether you have all, part or no dihedral in it).
I was only suggesting that you use flaperons. I wasn't trying to insinuate that they were required. In fact, the wing I am talking about will have only one servo for ailerons.
Sorry if I created any confusion...
Bob
Bob
WA
Thanks for the input! I definetly appreciate it! Maybe flaperons are a mod in the future! Or on my next plane! Have a great weekend!
My Feedback: (27)
ID
Spokeman-you have it dialed. It will work very well and be lots of fun. Be sure to spend enough time with it to really get the most out of it and then move on to the next level. HAVE FUN, Gizmo.
