Sureflite Zero kit
GA
Sureflite Zero kit
Hey guys. I am in the process of putting together a sureflite Zero kit and am having problems lining up the firewall. The instrustions (short as they are) are missing the page describing this process. I am wanting to know how the firewall is suppose to be mounted as well as the orientation of the firewall.
If anyone has built this kit they will know what I am talking about. Its a simple kit and quickly built, but this step has me scratching my head. Any help you guys can provide will be greatly appreciated.
I can provide pictures if they are necessary.
Jason
Jason
RE: Sureflite Zero kit
Well, I haven't built the kit, but I'll make a suggestion. Besides, my response will kick this back to the top of the page so someone else may see it.
I'd use triangle stock on all four edges of the firewall, against the fuse sides, bottom and top to make it as strong as possible. I would set it up so that it has 1 or 2 degrees of right thrust, and 1 degree of down. I'm assuming you have the plans. That stuff is usually called out, or shown on the plans, or designed into the construction of the fuselage.
Dennis-
Dennis-
You are building an injected foam plane right???? I have not built the Zero, just the Spit, (4) 1/2a Cubs, (1) 25 sized Cub, (2) 25 sized Cessna's, P-39. On the Cessna's you spread epoxy all over the inside opf the fire wall/engine compartment and the ply wood fire wall slide into molded grooves. The Spit had a fire wall and beams that you epoxyed into place. It was a long time ago but I may have mixed up the planes here.
There has to be some one on here that has built the Zero that really knows how it went together.
Dru.
Dru.
My Feedback: (15)
Hi Jason, I have built 2 of the fly babys. I drilled 1/8" holes in the corners of the plywood motor mount,lined it up over the foam firewall and drilled 1/8"holes in the foam. I used 1/8" dowels to epoxy thru the mount and 2" into the foam.then epoxy your mount to the foam and dowels.This gives you a lot more holding power over just butting the mount to the foam. Jerry
GA
does anyone else know anything about this kit? I have tried contacting Sureflite about the Zero, but their email server is obviously not in working order.
