Somethin extra cowl
Somethin extra cowl
Looking for a cowl for the Somethin extra. Any one with a cowl from Fiberglass Specialties that can post a picture so I can see what it looks like. I have the engine on its side so the tuned pipe will exit under the plane.
Steve
Steve
QC, CANADA
RE: Somethin extra cowl
I don't think FS makes a cowl for this plane.
All the cowls I've seen have been 'home made' out of balsa blocks and a lot of carving!!
(And why would you want a tuned pipe on the SE? it's not built / designed for speed... Just curious... Not seen one.. yet.. )
They offer a cowl but have no pictures. I emailed them and there reply was no pictures. As far as the tuned pipe the engine and pipe were laying on the shelf. I see Morris hobbies sells the same engine for there planes and most of them are profile planes that are not built for speed so I figured I would try it. I know most tuned pipes work on the upper end of the rpm so I will use less pitch on the prop. But I might be wrong.
Steve
Steve
OH
The length of the pipe determines where it will boost the power. By running the pipe longer, you can get more torque down low to turn a larger diameter, more efficient prop.....or, alternatively, you can turn a low pitch prop faster. That's the setup I use on my SE with a YS .45 and a full pipe.
