L-19 BirdDog 1/5 Scale Ikon N'west building question
Hi all
anybody out there who has built the L-19 Bird Dog /5 Scale from Ikon ?
I read the instructions. It sais build the wing upside down...but does not give any hint which
spar to use on the plan a guide and how to ensure all ribs are correctly alligned.
The ribs are semi-symetrical.
Pete
Pete
RE: L-19 BirdDog 1/5 Scale Ikon N'west building question
Pete hello.
I just finishing my L-19 1/5 scale from I´kon West.
It take me 10 month to finish the model,I finished the model with fiber glass cloth 3/4 onz. and epoxy resin.
You have 2 spar in the upper part of the wing ribs,you have to pin those over you plan(very flat).then you put the ribs very flat in the area of this two spars you have to put the first rib where the wing goes with the fuselage with the correct angle of diedral( I Put 2 degreess) remember you are working the wing upside down.When you finished putting all the spars you have to put the leading edge and the trailing edge the better way you could never make force every thing you have to correct, correct only Sanding remember that the trainling edge have enough material to fit perfect the front part of the rib.Im goig to picture my plane and send to you some photos another question you have let me know.I´m looking for the movement to set in the elevator, and the tail wheel klett that they said in the manual is to soft,probably because I sheeting all the stab and rudder.
