PICA T-28 HIDDEN FLAPS LINKAGE SETUP? HELP
VA
Hi
I am building a Piac T-28 1/5 scale,i want to know how to set up the flaps linksage..since i have never done the flaps so have no idea,one thing i want to keep the linkage hidden just like the ailerons, could some body tell me whats the best way to do this,your input will be highly appreciated....thanks in advance
Salman
Salman
RE: FLAPS SETUP? HELP
If this is your first scale project KISS (keep is simple stupid).By having the works exposed you can get a better idea of how this stuff works. Scale projects never end you just quit workin on them. My Pica Mustang has flaps but I did them as per the plans. Have Fun
VA
I have already set up the linkage for ailerons as hidden,which i think is a cheaper,easier and simpler way of doing it as oppose to shown on the plans,what i have done is planked the underside of the wing and control sufaces completely and left the top open so that i can test and make sure every thing is working,but i went through a lot of trial and error proscess to figure out everything so far....i was looking for some ideas that will make the process easier for a hidden flaps linkage....this is my seconed kit the first one is a 40 size GP P51 with retracts and completely glassed with panel lines and rivets...
