Reload this Page >
Tiger 60 moving forward ! but s l o w l y
Reply
Old 06-22-2004, 02:44 PM
Walfam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tiger 60 moving forward ! but s l o w l y
just some small questions that this group will answer in a NY Second.
first. Can I install my servos in the wings prior to covering and then cut the hole for the sevro after I get the covering on?
second: was reading a post where they said to install your hinges first and pin them prior to covering. This make sense to me, but most of the books say put you hinges after you cover the wing? either way works???? I do know that if the hinges are already in the wing when you
cover the wing you are going to have to cut out for the hinges in place. little extra work but if it is necessary then do it.
third: I am getting ready to put the fuse together tonight it looks simple enough but I want to check fit and function ....... the instructions do a good job here on a whole on what to look out for ... with that said, should I match the wing to the fuse before i cover the wing ? or after?
Fourth: I have worked out an awesome detailing on the aft fuse and tailfeathers that works so nice with the existing detailing on the wing and behind the canopy.... When I get it do
I will get some pics going. We are planning to get a digital camera shortly..... and then I can
send so pics.
Thanking youall in advance.
Walfam is offline
Old 06-23-2004, 12:17 AM
bojangle
bojangle's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tiger 60 moving forward ! but s l o w l y
If you are using "CA" hinges, you make the slots first and trial fit the hinges then you remove them for covering. You have to cut away the covering to re-install and glue the hinges.
The "pinned" hinges are best installed before covering. Some install toothpicks through the hinge leaves.
Check the wing to saddle fit before covering. You may have to sand the saddle a bit for a good fit and alignment.
For the dual aileron servos, make the mounting box, cut holes in the ribs for the servo leads. Most put in a string before covering to pull the leads through, I install 1/2" paper tubes.
Bob
bojangle is offline
Old 06-23-2004, 08:34 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Walfam
No. The servo is higher than the covering, so it would hold the covering up like a tent pole. You could slit the covering and align the slit over the servo, but why go through all that hassle?
Just remove the servo (tie a string to the servo wire and pull it through so you can use the string toguide the wire back), cover the wing, and slit the covering at the servo opening when done (See pic)
second: was reading a post where they said to install your hinges first and pin them prior to covering. This make sense to me, but most of the books say put you hinges after you cover the wing? either way works???? I do know that if the hinges are already in the wing when you cover the wing you are going to have to cut out for the hinges in place. little extra work but if it is necessary then do it.
Pinning hinges is seldom necessary. Cover the plane first, then follow this "How To" for installing the Hinges (If you're using CA Hinges):
http://www.rcuniverse.com/magazine/a...TOKEN=55428108
If you really want to pin them afterward, push a pin into the bottom of - let's say, the elevator. When you feel the pin hit the hinge, press slowly until you feel the pin just break through the hinge and stop pushing. Then, using a pair of side cutters, cut the remaining pin off so there's just a little stub protruding. Push that stub until it jus goes under the surface. Now the hinge is pinned, and the only thing showing is a pin-hole on the underside.
Make sure that the bottom and sides of the Fuse are straight and square, AND STAY THAT WAY! Especially at the rear! With a Goldberg design, I like to nail down the bottom of the fuse to the workbench (Yes... NAIL DOWN - with small finishing nails - pins aren't strong enough). Add the sides and top, and MAKE SURE they are Square! (The tail has a habit of twisting to one side or the other)
Cover after the fit. If you're getting anxious, you could cover the wing first as the fuse will get most of the sanding.
MinnFlyer is offline
Old 06-23-2004, 08:53 AM
Walfam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man these guys are good!
thanks
Walfam is offline
Old 06-23-2004, 08:54 AM
Walfam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks
Walfam is offline
Old 06-23-2004, 02:10 PM
Walfam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I one more question, when you are sanding the wing saddle to match up, how does one insure that the
wing is level to the plane. What i mean is if you were looking down the front of the plane the left and right wings would be
level to the fuse. I know the dihedral makes it difficult otherwise one could just use a right angle to the fuse ???
My fear is sanding one side two much over the other. Can levels be use or what is that magic trick you guys use?
Walfam is offline
Old 06-24-2004, 09:31 AM
conradj87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you could measure the distance from the wingtips to the center of the fuse. If they're both equal its level.
conradj87 is offline
Old 06-24-2004, 11:28 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is really not that critical. As long as it looks square, it'll be fine.
What IS important is that the Stab and wing are parallel to each other.
So just sand the wing saddle till it looks good (Don't worry about getting ALL of the gaps out. You can do that after it's covered by using the Silicon technique)
Just make sure that when you epoxy the Stab and Fin to the Fuse, they align perfectly with the WING.
