Good covering jobs!
#380
RE: Good covering jobs!
Here's my Great Planes Venus II ARF. I converted it to electric and re did the covering job. It's all MonoKote. I drew the blue stripes in AutoCAD and cut them on our laser cutter at work.
My brother who is a professional photographer and owns his own business took the photos.
#381
CO
ORIGINAL: krproton
Good work
#384
Link to fstevenj's original message: http://www.rcuniverse.com/forum/fb.asp?m=6133073
How did you get the color scheme on your Ultra Sport? Did you cover the whole model in the white first, then trim it with the black, yellow, and red? Or, did you make patterns and then cover whole areas at once? I've never covered a model before, but I am in the process of building a kit. I would certainly like to learn how to do all this stuff.
NorfolkSouthern
By the way, it looks very attractive.
ORIGINAL: fstevenj
Here is mine. Ultra Sport 40+ with OS70. Maidened last week.
NorfolkSouthern
#386
Here's an "oldie"...a Bob Dively Nuthin' Honey sport bipe.
I've had this in the box for years and decided to build it this past Fall. Ultracote covering, ST 45 with pipe and Mac's header. Guidance by Futaba with digital servos.
I wanted to do the "Good n Plenty" candy motif but the inve$tment in vinyl graphics was re-directed to other projects, lol...
PM
PM
#387
This is my recently finished Great Planes Ultra Sport Plus
Sorry for the low quality image, it is a scanned picture, I don't have a digital camera.
#390
Seeing as how I haven't contributed to this thread in a while...Here's my GP Extra 300 I built and covered earlier this winter/spring. Probably have 30 or 40 flights on her by now. Flys fantastic with a Saito 125 up front. Hitec 475 all around, with a 645MG on the rudder. I tail mounted the servos which left all sorts of room in the plane for a smoke system. Only lead added was a 1/2 oz to the left wing for lateral balance. It's all covered in Monokote, including the lettering (machine cut there, I'm not that good with a #11!).
#391
this is also a Great Planes Ultra Sport Plus (see a real nice covering job a few post above this one for what the plane looks like with a decent mk job)
my first covering job ever...
came out ok i think...
#392
Maybe this would be a good place to ask about Solartex. I'm a long-time builder but have not used this material before. I have used 21st. Century fabric.
Is it necessary to seal the edges with clear dope? It was helpful with 21C fabric.
The instructions say it is fuel-proof and can be cleaned with soap and water. Balsa USA suggests "polyurethane for easy cleanup." Anybody have experience with this?
John Agnew
John Agnew
#393
1 Post
Hi John,
I have found Solartex much easier to use then any of the film coverings. It is wise to seal any joins with clear nail polish or the like. It isn't mandatory to spray a light coat of clear on Solartex as it is sealed but the clear makes it much easier to clean off the oil residue if you are running a nitro motor. With petrol (gas), or electric there would be no reason to finish with clear.
Cheers,
Colin
Cheers,
Colin
#395
GA
This is my morris hobbies hot hots. It is covered in monokote, powered by an O.S. 46 FX, and is equipped with a futaba 6 channel FASST system.
#396
Our "Old School" covered Four Star 40 Pylon Racer.
SIRS, Inc.
SW of Bloomington, IL
N40° 25.682" - W089° 05.809
May 10th, 2008, Saturday – 8:30AM – all day
SIRS Four Star Pylon Racing Series
four plane heats means first place takes four points, second takes three points and so on...
scoring takes place on three levels..
A. individual for the day's event...
B. individual, cumulative for the duration of the "series"
C. Points for club participation...
each club member's points garnered for the "season" will be added to all other club members points...
the club with the most points takes home bragging rights for the season...
SIRS, Inc.
#399
I use Ultracoat just love the stuff! The best tip to keep your covering jobs looking good and shiney is to use a iron sock on the iron. Any iron puts swirl marks into the plastic film that never comes out a sock will prevent this.
#400
two of my planes goldberg clipped wing cub in white and purple ultrakote and an ace staudacher covered in white, yellow, black and grey ultrakote, powered by a webra 61. Was a nice plane till I nose dived it into the ground [:-]
