TF P-47 flaps
TF P-47 flaps
building my second TF Jug ...with flaps...inst. say "hook up flap linkage" yeah...the servo is mounted with the arm inside the wing and the pushrod is inside the wing, exiting thru a hole in the TE....I cannot figure out how to adjust the pushrod for travel and balance with the linkage hidden...any master builders that can help me.....
flaps
hook up the flaps to the control rod, and have the threaded end of the rod at the servo, this way any adjustments can be done at the servo, or just extend the flaps down, and make small adjustments and retract. the flaps are the smae way as on my cessna kit. nice
TF P-47 flaps
Hornet; thank you....it appeared to me that the adjustment was just hunt, punch and hope....On my TF P-51. the servo is mounted like the ailerons, on the outside...very easy to set up, but not hidden in a scale manner..
