Bridi Killer Chaos Build Thread
My Feedback: (75)
CO
First, I would like to say thanks for everybody that posted a reply to my Bridi Killer Chaos(Kaos) question thread, this is my first true builders kit that I'm going to tackle, it's not my plane, but a friend and mentor of mine at my club, he had this kit for over 2 years and has no time to build it, so I'm going to build it for free, as a payback for all the help he has giving me. I'ved built other kit planes for me, but not this complex, it will be be a good chalenge for me for sure, but I want to do it right for him and build a reputation as a good plane builder, I'm looking at building planes just from plans, since I can't find kits (not ARFS) of what I want to do, I think this build will help me with my goals.
If anybody has any input or experience on building this plane, please feel free to post, this will be a learning experience for me and for anybody who would like to tackle this plane, I'm a bit intimidated 'cause it's not mine and I want to do a super job, but I'm commited and prepaired to replace the kit if it fails.
I have progess pictures of the left wing panel in the works, should I keep posting this thread and progess build?, I need motivation so I don't screw up.
Joe[8D]
Joe[8D]
My Feedback: (40)
NH
RE: Bridi Killer Chaos Build Thread
By all means, let's see the pictures. Maybe I should clear the bench, dig out my Killer Chaos kit, see if I can keep up with you. First question is, what engine? I would think maybe 91 two-stroke offhand, but open to discussion.
My Feedback: (75)
CO
Pictures will be on the way, I have a few of the left wing panel buildup. The plane will be a tail dragger with dual ailerons and I think the owner wants to put in a 90 2 stroke. It will be a slow build, so I'll post as I go along.
Joe[8D]
Joe[8D]
My Feedback: (75)
CO
Ok, he we go, no turning back on this, I'm comitted[:@], this should be a fun experience for me. First two pictures, the plane box with the plane instructions, just a bunch of wood with no pictures on the plan or box whatsoever, not even the instructions, and the plan on the work bench. I almost backed out of building this plane, but where else would I get the experience of building a Builders Kit!
My Feedback: (75)
CO
Left wing panel on the board, it's built upside down, the instruction sequence kinda sucks[:'(], so I'm doing it my way, I added 3/8 inch cap strips to the leading and trailing edge of the ribs to secure alignment, since they are sloted for some resome, so I took advantage of it, but it was not called for in the book, I placed the top spar in place and glued everything together at the same time.
My Feedback: (75)
CO
Some of the ribs are about 1/8 inch shorter than the others, So I put a straight board on the trailing edge and trimed them up, added the leading and trailing edge at this time, the wood cut in this kit is really bad, I had to replace two ribs due to they are too thin or termite damage[:@]
My Feedback: (17)
ORIGINAL: Joe Ortiz
From what I see so far it looks great! I’m pleased to see from the landing gear block rib doublers on your bench that you plan to keep the beauty and function of the trike landing gear. Nothing worse that taking one of these beautiful and timeless designs and making them into silly looking tail draggers. It is really too bad they stopped scoring take off and landings in Pattern competition.
My Feedback: (75)
CO
From what I see so far it looks great! I’m please to see from the landing gear block rib doublers on your bench that you plan to keep the beauty and function of the trike landing gear.
8178, I wish I could have kept it as a trike, just to make it easy, but the owner want's a tail dragger with dual ailerons. I'm going to build it to his specs, I can back out any time on the build, but I'm not, good chalenge, I just want the experience, it will come in handy when I start building from plans.
GA
Joe - You've got the right idea about the rib slots. I used 1" aluminum 90 deg. angle stock suspended between two short 2x4's layed on their sides at the root and tip of the wing plans. Use one aluminum strip for the leading edge, and one for the trailing edge. Makes a very good wing jig.
My Feedback: (75)
CO
The next picture the leading and trailing being sheeted and the landing gear block in place.
My Feedback: (75)
CO
Rajul, since there is no specs in the manual, I expect it to be between 60 and 64 inches, the kit is challenging, but I expect to complete it, even with all the problems I running into, this will be my entry to the scratch building world.
Witch Sullivan gear you had in mind?, I'm open to sudgestions.
Joe
Joe
OOOOHHH!
Im gonna do that! Never did like the aileron servos in the center of the wing.
Have to mention: Just got hold of another Tower Kaos kit to stash with the rest of my kits.
ORIGINAL: Joe Ortiz
Some more sheeting and mocking up the servo rails.
My Feedback: (75)
CO
Fubar, thanks for the comments, as I said before, this is my first builders kit, and I'm enjoying the challenge, it's not mine, so it's super special to me that it's done right, so far it's coming out good, besides some set backs of non fitting parts, I'm learning how to fabricate what I need and read plans and do modifications to make it work, I want to scracht build a plane one day.
Joe
Joe
My Feedback: (75)
CO
This is the top side of the left wing panel. I will build some kind of servo extension tube, in case it need replacement, hopefully not. I will add 1/4" triangle stock to the landing gear block for reinforcement, looks like I will add shear webs that it's not called for, I don't want this wing to fold.
Joe
Joe
GA
Joe,
That wing doesn't need the shear webs unless you're putting them in strictly for peace-of-mind.
Correctly built, as you are doing, that wing will take anything you can give it. (well ---anything in the air anyway.)
I've built several, and flown the fool out of them with no wing calamities.
AZ
The tri stock reinforcement of LG blocks is an excellent idea. I added the tri stock after replacing both original LG blocks that cracked and split for some unknow reason. No problems since.
I just looked at mine(red transparent monokote). Apparently the Utter Chaos plan calls for shear webs, as mine has them.
I always used to let my landing gear blocks extend over 3 ribs and put the vertical part on the other side of the rib. Using 3 ribs distributes the landing load over a longer area.
In the old, original Bridi Koas kits from the 1970's, all the ribs had two 1/4 inch diameter holes for a jig. You bought two 1/4 inch steel rods at Ace, slid the ribs on and laid the assembly across 2 hair spray of spray paint cans, something to keep the rods supported and parallel. You built the wing, then slid the rods out. I built 3 of them this way, starting in 1971.
Bridi never used dihedral braces on any plane. You butt glued the wings together and used 6 ounce fiberglass cloth and 30-minute epoxy for strength. I never has one fail.
I recently test flew a Tower Kaos ARF for one of the guys. Brought back memories. They were the top pattern plane in those days. Nearly everyone had one. They are still hard to beat for a sport flier. The thick airfoil tends to keep the speed more constant in maneuvers and the tapered wing rolls better than a straight chord one. The long fuselage also made the plane groove better in maneuvers-not be so pitch sensitive. When I started flying a Kaos, my flying got a lot better and it wasn't me. I may have to buy one for old times sake.
Nice job on your construction, by the way. You are going to like that plane.
Moderator
My Feedback: (58)
Joe, sorry for my late response. here's the link for the Sullivan tail gear http://www2.towerhobbies.com/cgi-bin...&I=LXFV47&P=ML
My Feedback: (75)
CO
Thanks for the link Rajul.
Joe[8D]
My Feedback: (75)
CO
I made a block for the wing holdown screw, the slot will go through the rib retainer that was installed when I was assembling the wing.
My Feedback: (75)
CO
An update, I made a servo extention tube and added shear webs, I won't sheet the top untill I join the wings together, this way I have something to grip.
