My first ride
OK
My first ride
It finally finished my trainer after about 9 months of "winter work" and 3 roll of monokote here is my PT40.
So far I have about 13 flights on it. Flight 13 I stuck it in the tall grass on landing but only broke the prop and
bent the front gear back a little, very VERY fortunate. Now for the crazy part. I acquired a Bud Nosen Citabria
Champion the other day. To me it looks like a very challenging box of fun. Has any body out there tackled one
of these before? I know there are going to be pitfalls, just don't know where yet. The kit is in incredible condition
and is very complete. All ready have the Kinko copies of the plans and I'm starting to want winter to hit again!
SuperHoggie
SuperHoggie
OK
RE: My first ride
I'm semi aware of the challenge with a Nosen kit. My teacher/trainer buddy is an experience flyer that hates to build and has already asked if I would build a plane for him. I'm not quite comfortable with that yet, but love to build and think through a set of plans. I'm thinking I'll learn a lot with this kit.
SuperHoggie
SuperHoggie
1 Post
RE: My first ride
I built one of these Citabrias back in the late 80s.
From what I recall, the kit wan't the best quality so I replaced a lot of the timber that came with it.
The plans show it as being designed for a .61 engine but that is indicative of the age of the design rather than todays reality. Back when it was designed, .61 were mongst the biggest glow engines you could buy. I reinforced mine a lot and built it around a G38 gas engine.
The plane came out quite nice and this was a good combination. I don't remember the weight but it's a big plane and can handle a bit of weight if you build some strength into it.
I covered mine with solartex (red and white) and then sprayed it with clear dope.
Best of luck with your build
RE: My first ride
SuperHoggie,I have built a couple dozen of the Nosen 1/4 scale Citabrias.Build it light and use a .90 2 stroke or a .120 four stroke,also a g-23 is a good engine.Make sure that you use aircraft ply on the 'FC' formers.The last kit i got from A&A had light ply and the wood altogether SUCKED!Replace what is needed.Really the plane isn't that difficult to build at all,the hardest part is the fuse sides,after that it is all fun!lot easier than building a Cub.With some practice,hehe,you can build that fuse in one night,it is that easy to do.I just built one and clipped the wing down to 86 inches,made it a one piece wing and used 1/8 ply for dihedral braces,very stong wing.If you need any help just gimmie a yell,i'm right here,,,,Slade
MN
RE: My first ride
Superhoggie, I did a thread on the "Champ" a while back with lots of pics. Do a search for 'Nosen Champ' and it should come up. A couple of good suggestions are in previous posts here (ply and replace some wood). My avitar is the finished Champ. Watch the CG and do a 'taxi test' to see if the tail comes up before you take-off. Mine flys well with a Homlite 25cc conversion.
Nice covering scheme on the PT !!
bipeguy...
bipeguy...
RE: My first ride
Nice job on your first endevor,as far as the Nosen I agree with the others the wood is "Floor Sweepings". The plans are fine and Nosen's fly well but must be light. If you like to problem solve thsi wood be a good project. Good luck. Mike
OK
RE: My first ride
Everyone,
I appreciate the link info on my Nosen.
Yes, the ply is like that of glued grahamcrackers.
Thanks for the compliments on the PT, I have about 80ish hrs in her.
As far as the nose gear goes the reason for turning it around is because after a couple of miracle hard landings/soft crashes, the spring was starting to crush into the fuse.
Im afraid if I lower the thing to far it may never stick to the ground on landing!
Any thoughts
SuperHoggie
Any thoughts
SuperHoggie
