what kit
what kit
I'm looking for info what a good first kit to build.. I have built many AFRs but want to try to build a 40 or 60 size plane this winter.. Would like any help full info on what you guys may think...I was thinking of SIG somethin Extra or a great planes extra 300... Thanks for the help........Kurt
[email protected]
[email protected]
My Feedback: (27)
WI
RE: what kit
You can't go wrong with a Goldberg TIger II. Many others will also recommend a Sig 4*40/60 as well.
Woops - should have read the whole post. I'm considering the SSE as a 3rd pland / 2nd kit as well.
RE: what kit
Kurt both kits are good kits. Both fly well. I would however reccomend the Somethin Extra. Simply because it is a SIG kit and I have one. It is designed with a low time builder in mind. The instructions and plans are very well thought out. There is nothing wrong with the GP kit. I just feel for a first kit the SE is just more beginner freindly. Good luck with either one. BTW you can use the gear from your trainer in the SE. I would not reccomend it for the GP kit. Just another point to consider.
Mark Shuman
Mark Shuman
RE: what kit
I would second the Sig SE. I've built numerous GP kits (although not the Extra). they are great but, I believe the SE would be a better first build kit. it is simple to build.
Having the 2 piece wing also (in my opinion) makes it easier to cover.
David S. - Tampa, FL
RE: what kit
ORIGINAL: flightexpress
Mike have you built a GP 300 extra. Why would think the SE would not be a good kit for a first build
