Building a Dynaflite Super Decathlon
Reply
Old 08-24-2005, 04:40 PM
  #251
mRqS
mRqS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Building a Dynaflite Super Decathlon
Hi Ed
I did my first towings. I towed a 1/3 scale Polish glider Orlik. 4.5m of wingspan and 7.5kg weight (the red one on the picture below. the blue one is 1/2 scale with 7.5m of wingspan and 26kg of weight).
With zdz-40 and 20x8 prop my Decathlon pulled it without problems.
Just before towing in trial flight with bigger prop I did a ... torque roll
Really.
mRqS is offline
Old 08-30-2005, 11:08 PM
  #252
cruzmissile
cruzmissile's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Marek,
Congratulations on your first towing with you super Decathlon.
I recently had some extra funds to go and get some more items for my plane. I have been busy with another project that I just recently completed. I took a stock Park Zone Flyers P-51 mustang and put a 480 multiplex brushless motor, 40amp speed controller, micro receiver and servos by Futaba, and a 7.4v 1500maH Lipo battery. This thing screams through the air.
Anyway here are some photos of what I have been doing. The wheel pants took a while to do cause I only messed with them maybe 10min at a time. I have three metal gear high torque servos pulling 107oz of torque. plenty enough for this plane. I also installed 65oz torque servos for the ailerons. I had to mount the rudder servo on a higher rail to allow for the arms to rotate in such a small space, and I got my tail wheel assembly from dave patrick models.
ID:	317842   Click image for larger version
ID:	317843   Click image for larger version
ID:	317844   Click image for larger version
ID:	317845   Click image for larger version
cruzmissile is offline
Old 09-14-2005, 07:01 PM
  #253
t_josef
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great build guys....
I just ordered the dynaflight kit...And was wondering...
Has anyone tried a Zenoah g26 with this kit? Our local field has cubic inch restrictions, and I was wondering if this would be enough of a powerplant.
t_josef is offline
Old 09-15-2005, 03:04 AM
  #254
Blue_Moon_
Blue_Moon_'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: t_josef
lol, why?
Blue_Moon_ is offline
Old 09-15-2005, 05:08 AM
  #255
mRqS
mRqS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: t_josef
Hi
I'm sure it will be enough.
Manufacturer say's: 25-35ccm gas engine.
I've a 40ccm ZDZ in my Decathlon, which has plenty of power. I did a torque roll with 20x8 prop, so 26ccm should be ok for sport flying.
mRqS is offline
Old 09-15-2005, 06:36 AM
  #256
beepee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
t josef,
The G-26 will be fine. Spend as much time as you can working the tail weight down. The G-26 will not be enough nose weight to get it balanced. With that engine, the lighter the better, which means minimum ballast. I didn't do this and ended up with ballast on the nose with my Quadra 42.
Have fun!
Bedford
beepee is offline
Old 09-15-2005, 08:04 AM
  #257
mRqS
mRqS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: beepee
Have fun!
Bedford
Bedford,
what is final weight of your Decathlon and what is weight of Quadra engine?
My zdz has 1.5kg with Supersonic pitts muffler and balanced perfectly without lead.
It's a bit shorter than Quadra, so maybe there was an advantage of engine more in the front in case of my Decathlon? I had to install it on additional spacers.
I didn't weighted my Decathlon, so I don't know his weight yet. I think it's no more than 7kg
mRqS is offline
Old 09-20-2005, 07:17 AM
  #258
beepee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Marek,
I don't remember if I have weighed the Q42, but I would guess it is somewhere in the area of 2 kg. The airplane weighs somewhere around 7.6 kg. I might have done better, but during construction I expected it would end up nose heavy, which is my usual result. Boy, was I wrong.
Bedford
beepee is offline
Old 10-04-2005, 04:13 PM
  #259
WILDCRASHWILLY
WILDCRASHWILLY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This may have been asked earlier in the thread but I didn't see it. I wondered if a Fuji 50 EI would fit under the hood without butchering the cowl. I have an opportunity to get one at a good price however I think this may be too big for this application. The ZDZ40 is probably the ticket but the Fuji 50 can be bought at about $100 discount from a friend of my daughter's so I felt it was definitely worth considering. If not I'll save it for another project and go with a ZDZ.
Thanks in advance fo your opinions whether positive or negative.
WILDCRASHWILLY is offline
Old 10-04-2005, 04:29 PM
  #260
mRqS
mRqS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill
Finally I checked weight of mine (without fuel). It's exactly 7.4kg (16.3 lbs).
Regarding engine.
Even ZDZ-40 sticks a little over engine cowl.
It's installed up side-down.
Therer is spark plug cap sticking outside.
Someone here has a Decathlon with US, Fuji or ZG engine. If I remember, there was not too much out of engine cowl.
mRqS is offline
Old 10-05-2005, 10:43 AM
  #261
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Marek,
After going through this thread and seeing how you did yours, I think I'll duplicate your mounting technique and go with a ZDZ40. I may get a Christen Eagle and put the Fuji 50 on it. I really admire your set up and hope that I can build one that looks half as good as yours and cruzmissile's.
Old 10-05-2005, 11:20 AM
  #262
mRqS
mRqS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill
haha, thanks
In fact, it doesn't look too good in a close view (not fully finished cockpit, no rivetts, etc.)
If you stay with zdz I can help you with dimensions etc.
mRqS is offline
Old 10-07-2005, 10:28 AM
  #263
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Marek,
It will be during the winter along with some other projects I'm working on. I saved your call sign in my address book. I'll PM you when I start it. I will also continue to monitor this thread for further updates and mods. that everyone posts.
Old 10-24-2005, 12:04 PM
  #264
HelloScott
HelloScott's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why did you "regret" the Midwest Citabria kit? Is there a big difference between the two? I've got a buddy who's been trying to get me to buy his Midwest Citabria. He's just not into large airplanes. He wants about $150 for it. The same price basically as the Dynaflite Decathlon.
Scott
HelloScott is offline
Old 11-02-2005, 01:18 AM
  #265
tomerj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Struts
I am looking for a clever (Not necessarily scale detail) way to build the struts and make them easily removable. I am thinking of a safety fastener (I got one from home depot).
Has any one tried that?
Thanks in advance
TJ
tomerj is offline
Old 11-06-2005, 12:31 AM
  #266
mRqS
mRqS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cruzmissile tried to build a scale struts. It's especially ease, because these struts are decorative only. It can fly without them.
I used "factory" method to make struts in mine.
mRqS is offline
Old 11-21-2005, 04:19 PM
  #267
qballdmd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wonderful posts guys. I'm a newcomer still, so the tips here are great. I love the kit, but I'm doing a "stock build." I'm not going way out on the scale details because I'm still learning. What I would like to know is how to lighten the tail. I build it as shown, but are there ways to trim back? I want to use flying wires, and I want them to be good looking, but light. My engine will be the Saito 1.82 twin. I know I will have to modify the cowl slightly, but I'm ok with that. It is around 40oz, so my question is what can I do to lighten the tail, so less ballast is needed forward. I want make the most of the power I'll have and not use it up pulling aroung counterweight. Someone on this post hit the low 16lb weight. What are the secrets? Other than moving the servo tray forward, which is already cemented in place, can I make move the battery pack forward, to some kind of custom mounting? My fuse is all framed up (minus the front deck and covering) so I can still make changes.
qballdmd is offline
Old 12-10-2005, 02:59 PM
  #268
hy flyr
My Feedback: (27)
hy flyr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello guys,
Heres mine. Has a Brison 2.4, smoker and Airtronics radio.
I didn't have the cowl or wheelpants done when this was taken.
hy flyr is offline
Old 12-10-2005, 03:01 PM
  #269
hy flyr
My Feedback: (27)
hy flyr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whoops, should have downsized....sorry.
hy flyr is offline
Old 12-11-2005, 07:40 AM
  #270
mrbigg
My Feedback: (21)
mrbigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks really nice!
mrbigg is offline
Old 12-16-2005, 11:13 AM
  #271
mustangshooter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Excellent work hy flyer
mustangshooter is offline
Old 12-19-2005, 09:36 AM
  #272
t_josef
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a little time to work on my plane this past weekend. I have one wing section completed ~ along with the tail. I'm sure the left side will assemble quicker now that I'm familiar with it. (Big thanks to all that posted pictures...you all helped me (unknowingly) a great deal.)
I decided on a MVVS 2.15 for power. ~ It is sitting on the shelf waiting for a home.
t_josef is offline
Old 01-03-2006, 10:26 PM
  #273
Scottpuck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys... Great thread. i have started building a SD lately and thought I would tag my question on to this thread as it has been a great help to me!
I am about half way done with one wing and I am a little baffeled about the trailing edge. Unless I am missing something (the directions are pretty bad in this kit unfortunately), the trailing edge appears to be made simply by joining the sheeting together to meet the curve of the ribs. This however will leave a gap in the TE creating (what I presume to be) a week spot.
What are your thoughts on this? Am I missing a step somewhere? Is there a piece of balsa that is supposed to create the TE and then sheeted over? If not, did anyone re-enforce this area of the wing?
Cheers,
Scott
Scottpuck is offline
Old 01-04-2006, 07:23 AM
  #274
beepee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott,
I can only go by memory, but others may jump in that have ready access to the plans/instructions. Look at the cross section view of the wing on the plans. The sheeting extends past the ribs. After installing the first side (whether top or bottom), sand it down to match the ribs. The other side sheet should then lay nicely on the ribs and have a good mating surface on the opposite sheeting. This will create a good strong trailing edge.
If that doesn't make it clear (I am not the best at describing visuals), send me a PM with your email address and I will return some sketches.
Good bird, have fun!
Bedford
beepee is offline
Old 01-04-2006, 08:40 AM
  #275
RCVFR
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scottpuck,
Look at the plans again, I think you are misreading them. Beepee is correct, the top and bottom trailing edge sheeting meets back behind the ribs. The instructions are pretty clear about this step.
RCVFR is offline
Contact Us Archive Advertising Cookie Policy
