Building a Dynaflite Super Decathlon
Reply
Old 07-29-2012, 08:13 PM
  #1626
WILDCRASHWILLY
WILDCRASHWILLY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Building a Dynaflite Super Decathlon
As a side bar, I found some tape at a local Tractor Supply Co. It's called tarp repair tape, (very soft and very pliable), and comes in several different colors. It's a little heavy to use as hinge tape on electric or most models under a 60 size but I think it will do well on giant scale. It looks like a real heavy version of Blenderm tape that the foamy guys use as hinge tape. I will probably place it on the bottom of the Decath to seal the hinge gap.
ID:	1787457   Click image for larger version
WILDCRASHWILLY is offline
Old 07-29-2012, 08:33 PM
  #1627
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thought I would post a little bit about how I install hinges. First, I find a metal jar lid and place about a spoon full of petrolium jelly in it. I then turn my covering iron on about 2 or 3 heat setting and place the metal lid on the shoe. As a result the vaseline melts and as you cans see, I bend the joint a few times working the lube into the joint. This will help isolate the hinge joint from any epoxy that might get on it. When done I wipe off the excess epoxy from the hinge before it completely hardens. I normally leave the vaseline on the knuckle as it is a good lubricant for the hinge. But, You don't have to. When finished, find a suitable top for your jar lid and save the vaseline, "(which re-solidifies when the heat is removed)", for the next project. I had some in the jar lid for a couple of years and used numerious times. I finally replaced it with fresh vasiline for these pictures. Also, I smear a little vaseline on the covering around the hinge area to keep epoxy from sticking to the covering and allowing for easy clean up prior to it completely curing.
ID:	1787470   Click image for larger version
ID:	1787471   Click image for larger version
ID:	1787472   Click image for larger version
ID:	1787473   Click image for larger version
ID:	1787474   Click image for larger version
Old 08-04-2012, 10:08 AM
  #1628
smithfj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's basically the way I do it too. The only difference is I took a coat hangar and fashioned a frame around the vasaline lid ( mine was metal) and bent a base on the wire for the lid to set level allowing enough room for a small candle to heat the vasaline. I also use the same method on my Dubro butt style hinges both regular and large scale type. When done I just grab the wire frame with pliers and pour it right back into the container. Either way is slick.
Frank
smithfj is offline
Old 08-04-2012, 01:13 PM
  #1629
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice ideas. I think I will be able to maiden mine Sunday if the weather holds up. Wildcrashwilly,  You are doing a very nice job on yours.
It's looking really good
ED
nh4clo4 is offline
Old 08-05-2012, 07:03 PM
  #1630
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got mine maidened today, the g38 has plenty of power, and it flew really nice. It flies like a scale plane. Rolls are smooth, loops are smooth, and very stable. It came in at 17 lbs, no extra weight with the g38. The rear servos are in the stock location, and the batteries and throttle servo are on the cg. I think the stock cg location is a little too far back, as it needed seven clicks of down elevator.. I will get some pictures later this week.
Ed
There are some build pictures on page 56.
nh4clo4 is offline
Old 08-07-2012, 05:36 AM
  #1631
futabaflyer83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After a break that lasted too long I am back and building. As with everyone else I have been struggling to find the best way to get everything under the hood in the fuel tank area and still be able to service it later. It is coming together now.
ID:	1789984   Click image for larger version
ID:	1789985   Click image for larger version
ID:	1789986   Click image for larger version
futabaflyer83 is offline
Old 08-07-2012, 05:42 AM
  #1632
futabaflyer83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is starting to look like an airplane now. Hope to maiden her before the year is over. The winters in florida can be a bit windy and it is nice to have a big bird to fly during those months.
ID:	1789988   Click image for larger version
ID:	1789989   Click image for larger version
ID:	1789990   Click image for larger version
ID:	1789991   Click image for larger version
Old 08-07-2012, 06:08 AM
  #1633
minkiehuoise
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that looks like about where i am. i am getting ready to starting to cover mine ,have the batterys and switches in but havent been doingto much as it has been to hot here.
your plane looks good,wayne
minkiehuoise is offline
Old 08-07-2012, 06:51 AM
  #1634
futabaflyer83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! I have not built a plane in years and I really enjoy it. I just need some time off work to do the important stuff, like build and fly,
Old 08-07-2012, 07:30 AM
  #1635
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lookin' good, I spent since July 2011 and could have had it ready sooner, but life keeps getting in the way
ED
nh4clo4 is offline
Old 08-07-2012, 05:32 PM
  #1636
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures, I have the struts left to make, probably will wait for winter now. Actually flew really good, I was worried with all the negative comments about it not being a good flier,
ID:	1790147   Click image for larger version
nh4clo4 is offline
Old 08-13-2012, 01:49 AM
  #1637
Kolbboer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Nice work, lokks great!
I had maiden flight yesterday, and i must agre its a great flyer. And the Zenoah 38 hadplenty of power for mee (i am flying on the wing, not only the propeller)
Helloto all of The Dynaflite Super Dec builders,theplane is wery nice to fly. Look forward to the maiden fligt when youhavefinished thebuilding
Maiden flight: http://www.youtube.com/watch?v=QvqYuCDdWhg
RGS
Jan
Kolbboer is offline
Old 08-13-2012, 02:47 AM
  #1638
orthobird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow, what a beauty. good job!!
orthobird is offline
Old 08-13-2012, 09:22 AM
  #1639
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kolbboer,
What prop are you running on the g38. I have an 18-10. And just keeps going at an idle, if there is wind no problem, but no wind and it just keeps floating.
Thank ed
Also thanks for the comments, I see you can get seagull 120 wheel pants for 17.00 fiberglass and painted red. I think I will try those.
nh4clo4 is offline
Old 08-13-2012, 12:03 PM
  #1640
Kolbboer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ed,
Its a Biela 18x10.
I have heard that this brand is a little bit heavier for the engine to turn, than many other brands with same pitch and diameter, i have also the sameexperiense in the past with othermodels that i have in my hangar.
things to do now is to mount the painted wheel pants and the musicwire mod on the landing gear.
Going to try som different props soon. I can keep you posted on this.
Jan
Kolbboer is offline
Old 08-18-2012, 05:12 PM
  #1641
rmadsen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JUST AN UPDATE: I built mine about 3 years ago (and posted to this forum a lot back then) but don't fly it too much. I probably have 20 flights on it. As expected the plastic cowl finally bit the dust. It held up well at the joints since I used fiberglass reinforcements. But the air intake up front started cracking badly and the holes around the mounting screws just expanded too big. I knew all this was going to happen. Its just a matter of time. So I finally ordered the fiberglass cowl from Fiberglass Specialties this evening.
Some folks recently quoted my posts of using heavy wire reinforcement on the stock LG. It wasn't my original idea, but I have been extremely pleased. I've had a few harder-than-desired landings and very little deformity so far.
I run a Saito 1.80 which is plenty of power but a horrible muffler design. Quick take offs on grass with extremely huge round loops all while the muffler loosens and melts into the plastic cowl.
Any hints how to keep the muffler tightened?
rmadsen is offline
Old 08-20-2012, 05:42 AM
  #1642
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ron,
Can you give me a rough idea what you paid for the cowl. I'm useing the plastic cowl on mine and like you, I expect it to crack and fail over time.
I covered one of the wings yesterday and hope to get the other one next weekend. At that time my covering will be complete. I used ultracoat for some white, and black & white checks on the bottom. The ultracoat worked perfectly and was easily applied. In fact, both wings are covered on the bottom. All I like is the top surfaces on the one wing and a little trim work (star burst pattern), for the rest of the plane. As I may have mentioned before, the upper surfaces are Monocrap. This stuff is awful. At one point yesterday, I seriously considered ripping all the monocoat off of the plane and putting in an order for Ultracoat. But against my better judgement, I'm sticking with it on this job. This will be my last plane to use monocoat other than some trim lines or something like that. I have used Ultra for years and never had an issue of any type. On my 3D or sport planes I will continue to Ultracoat but earlier in this thread, some of the guys have sold me on the coverite cloth covering. That is what I'm going to try on my scale type planes in the future.
Did not update any photos this weekend so I'll catch them up next weekend. I won't be able to work on it during the week, pesky side activity called a job you know. Actually glad to have one this day and age.
Old 09-04-2012, 07:23 PM
  #1643
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nh4cio4
Thanks for the complement ED. It looks okay from thirty feet but up close is pretty bad. Worked on it some more this week end. I know, I sound like a broken record but the Monocoat was a big mistake. I cut out stars and stripes on yellow Monocoat. I installed the trim with acetone. When I misted the acetone and placed the trim on, it looked really good. However, after curing all night the next morning I discovered the trim was extremely drawn up in to wrinkles and overall just looks terrible. I plan to fly it like it is for now but, when the dead of winter gets here, I'm going to rip that crap off and go back with UltraCoat since the white and the Black & White checkers are Ultracoat. I may rip it all off and try some of that Coverite some of you told me about. Hate to do that as the Ultracoat portion of the covering is perfect. We'll see how I feel about it st the time. I have some other builds waiting in the wings that I want to start including a scratch build that I have not decided on a name yet. In fact, I havn't even drawn out the plans yet but I did buy a DLE55 the other day so I'll draw some plans around it. It will be some kind of Stick only it won't look like a stick. Anyway, I digressed enough. Decath pics below.
ID:	1798586   Click image for larger version
ID:	1798587   Click image for larger version
ID:	1798588   Click image for larger version
ID:	1798589   Click image for larger version
Old 09-04-2012, 07:30 PM
  #1644
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed, your plane looks great! I wish mine looked half as good. Still have to paint the cowl. I've purchased two different greens from the rattle can dept. at Lowes and unfortunately niether one matches good. Someone told me to try John Deer Green so I'm going to drive over to the John Deer Tractor dealer and see if they have a can.
Old 09-04-2012, 07:31 PM
  #1645
dumorian
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm confused? I used Monokote over Monokote on mine with the Monokote trim adhesive and it all worked great. It was surprising to me how that little bit of damp film of adhesive activated the glue and made it bond.
What do you think went wrong. Was it a mix of coverings or the use of acetone?
Sorry... I don't mean for this to sound like rubbing it in as I would be really upset with the same results. So, I'm trying to figure out exactly what not to do... yeah, I make plenty of mistakes and would like to avoid this one.
Yes, I feel really bad for you.
dumorian is offline
Old 09-05-2012, 05:04 PM
  #1646
rmadsen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm pretty sure acetone will completely dissolve Monokote if you use enough. So over night it probably ate away at both the original covering and the trim layer (were it was sandwiched and not able to evaporate) yielding the wrinkles you can see in your pics. Acetone is not the same as trim adhesive. My guess is that a complete recovering will be a good winter project.
For my stars I used the "Windex" method and, 24 hours later, heat to bond trim to the covering followed by a heavy outline using clear nail polish. They have held up very well so far. Just spray windex (not an imitation) on the back of the trim, put in position and squeeze out all air bubbles using your favorite credit card. Next day, cover with paper and iron just enough to activate the adhesive. I was amazed that this actually worked.
rmadsen is offline
Old 09-05-2012, 05:24 PM
  #1647
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I own a sign company, so I used mono kote and then sign vinyl for all the decals, I know cheating.
For painting the cowl, thai is why  I went with black and white easy to match. Colors are more difficult.
Good luck matching the paint.
ED
nh4clo4 is offline
Old 09-05-2012, 06:20 PM
  #1648
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dumorian,
The acetone was misted onto the green with a mister bottle. I've had success with this method on Ultra but the mono obviously has a different chemistry. I do think the acetone was a mistake with this covering. The heat activation is so poor on the monocoat I didn't think I would be able to heat the trim enough to stick it.
Ron,
I tried the windex method first but could not get any adhesion with a test strip even after about 20 hours. Perhaps this not enough time. Testing the acetone on a test piece actually worked however my test Pc was solid. The wing was open bay behind the green which may be a contributing factor.
BTW guys don.'t worry about my taking a statement as rubbing it in or negative. Obviously I am having an issue here and something you say might cause a light bulb to come on and help me to understand where I screwed up.
Ed,
Another mistake I made was the green. Should have stayed with colors that have worked for me such as red, blue, black, or white. I tried the green because I wanted to be a little different some of my other planes.
All good advice guys, keep it coming might help or others that have seen where I have failed.
Old 09-05-2012, 06:34 PM
  #1649
nh4clo4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Willy, I used DuPont chroma base for my cowl, it is an automotive base/clear. I have to custom mix a lot of colors to match client logos and signs. I would be able to match most colors, but when you do for a living, you want your hobby to be easier. Some hardware stores can, can a custom color in an aerosol for you. Check with a hardware hank or ace. My local hardware hank offers that service.
It may be worth a try.
Ed
nh4clo4 is offline
Old 09-10-2012, 06:48 PM
  #1650
WILDCRASHWILLY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the advice Ed,
I gave up on the green and yellow monocoat. I tried to improve the finish trying different techniques but could not help it. I ordered blue ultracoat and should have it by the end of the week. I'm going to rip that green stuff next weekend and start the recovering process for the upper areas. I've already cut Ultracoat stars out for a white starburst pattern. The lower trim on the fuse and bottom of the wing is already Ultracoat and had an excellent finish. All green will be replaced with deep blue Ultracoat. Maybe the blue will be easier to match than the tree was. Ultracoat may have had a paint to match but I coyote to check. I had ordered a supply of Ultracoat for a couple of small glow powered planes I plan to build. I also have a design and scratch build gas unit I'm drawing some plans out for and it will be Ultracoat. Sometime in the late winter or spring I'm going to try cloth on a Top Flight SR9 kit I have. No more Monocoat for this man. I learned my lesson.
Reply
Display Modes
