Lanier 80" Cap 232
RE: Lanier 80" Cap 232
hi, if you have the kit, of the lanier cap 232, could you give me the lenght of the canopy as I have I think a plane given to me which I think is a lanier kit, and needs a new canopy. but the lenght and witdh of the canopy would confirm it for me and then I could order the canopy from Lanier.
thanks MGA
thanks MGA
My Feedback: (54)
mga;
Mine is in storage at the moment, but there are definite qualities of the lanier kit. One- The wing span is 81 inches. Two- the stab-elevators and fin-rudder are full flying surfaces and not removable. Three- all elevator and rudder servos are designed to be installed in the tail. Four- the cowl is installed via a cowl ring with two lower bolts installed from the front (engine side) and the two upper bolts are installed from inside the fuse. The canopy and hatch have two big round punchouts glued to the front to lock the deck in, instead of pins. Hope this helps.
Steve
Steve
I have the big round punch out, I ordered the canopy from Lanier and got it today. It fits perfectly. Now since I do not have the plans, could someone give me the measurements of the CG, that would help greatly. also would a First Place 2.4 40cc fly this plane. I have lightened it up a great deal. right now I do not know the wieght.
Thanks MGA
Thanks MGA
would someone have the throw measurements for the Lanier Cap 232 Kit 80" As I do not have the plans would like what is the good measurement for the first flight or the recommended one. Thannks
MGA
MGA
