Sig Somethin' Extra Questions, Please visit...
My Feedback: (8)
HI
I just ordered the kit, waiting for it to come in...
Well i'm doing my research like i'm suppose to and found a few things.
First of all i hear that sig did something with the wings that apparently a lot of people don't like... I think i sort of understand what you guys are saying, but is it possible someone can post pictures of what you're talking about... Oh and since we're posting pictures, maybe i'll see some cool colour schemes?
another thing is engine, i have an Evolution 46, and a saito 65, i think both will underpower the plane, so i might get a 46fx... Now will the FX hover the plane? please let me know
last... i've never covered a plane before, any tips/tricks/advice? is this plane hard to cover?
BTW i'm thinkin to make this plane white and hot pink... muahahahaha
thanks for your help guys...
RE: Sig Somethin' Extra Questions, Please visit...
First of all, good choice of airplanes. I've built three and always take one of them with me to the field. I made them all as light as possible and put .46 FX on two of them with tuned pipes. Neither will hover but the third one does with a .50 SX. I one put a Rossi on one of them but that was just a ridiculuous amount of power so I got rid of it.
Either of the engines you mentioned would work well. The .65 will definitely be enough to do a hover.
The gripe I hear most about the wings is the two J hooks with rubber bands holding holding the wings together. I've never had a problem but I did make darn sure the J hooks were secure on the inboard wing ribs. Some people recommend using rubber gaskets to hold them together fearing a rubber band won't do it.
HOT PINK!?!?! Booo. But hey, at least you didn't go the ARF route.
My Feedback: (8)
HI
Hahaha thanks for your input... Hey i've seen an extra 300 white and hot pink, looked sweet... but please dont get me wrong, i'm not sweet in anyway.... yeah looks like i'll put that saito in there, since i already have it... I guess i'll find out the wing problem when i get the kit... i was also looking at the fx, but if my saito will do it then hey i'll throw her in there...
thanks again
thanks again
My Feedback: (16)
FL
I have the Evo .46 on my SE and it overpowers the plane, in my mind. I fly it at about 1/4-1/3 throttle and can do lots of things, but to go verticle, I have to go up on throttle. If you really want to have a ton of power, go with the .65. My favorite thing to do is to just go up on a windy day, cut back the throttle, and see how long I can hold it the same spot. I've thought about buying a wing kit and adding several bays on to see if I can make it even better up there, that way, I'd have a fuse, with two sets of wings,one 3d and the other a big floater (maybe even add flaps for really slow flying). I use the J-hooks with a zip tie.
Hunter
Hunter
MO
From what I've read, there are plenty of people who have had no problem at all with the j-hook/rubber band method. I add a second rubber band and a zip tie. I fly mine with a OS 46 AX, plenty of power, wont quite hover, but then again, it's not really built for all out 3-D. You'll love the plane
I have a SE with the Evo .46 NT. It hovers and has power to pull out. It will fly out of sight straight up, so no problems there. I'm using an APC 11x4, which gives decent top speed with great vertical. Just watch your top RPMs and be careful to not over rev the engine with that prop.
xX911gt2Xx wrote:
The SE is a very nice aircraft.
The wing thing you mentioned can be one of two commonly discussed issues:
1) The method of keeping the wing attached (J-hooks and rubberbands). IMHO this is a non-issue. The suggested method works great, no problems whatsoever.
2) If the wing is built using the alignment tabs at the rear of the wing-ribs, it will end up with a very slight wash-in. One could argue that the wash-in will create tip-stalling tendencies but anobody who has flown a SE can tell you that this is not the case.
Covering the aircraft is not a problem as all surfaces have single curvature. The trickiest part for a beginner probably is the turtledeck which has a slight double curvature to it. It's best covered using two or more pieces of covering material.
As for the engine, a 46FX with a low pitch propeller (i.e. 12.25x3.75) will hover the aircraft. If you are considering buying a new engine IMHO the optimal two-stroke engine for the SE probably is the Irvine 53.
Good luck with your SE!
/Red B.
...First of all i hear that sig did something with the wings that apparently a lot of people don't like...
/Red B.
I herd nothing but praise for this 2 stroke in the hundreds of messages I searched
through in the last week or so. If I had not gone with the Irvine it would have been
a Webra 50. If I had needed to stay under 100.00 I would have gotten the TT.46
2 stroke.
I was leaning hard to a Magnum 52XLS for 79.00 at Tower, however in all the messages
I searched through I kept reading about a week transition from low rpm to high. This is
probably easy to fix with a good carb cleaning and sealing but I didn't want to chance it.
Good luck.
My Feedback: (10)
MB, CANADA
Good choice. I flew mine with that combo. I used 12x4 and 12x5 props, and yes, it will hover with power to pull up and out. I originally had an Irvine 46 in mine but changed that over to a Kougar and put in a .53 for the power bonus.
The rubber band method is definitely a non-issue. Just change it with some frequency and don't rely on one thats starting to tear. And btw, you'll probably chew thru a few props tho if you don't increase your clearance by either going to taller landing gear or increasing your wheel size. I had little problem with 11" props but did with 12".
Rather than try to repeat what I originally wrote, here is a thread on the one that I built. I too use a rubber band on the J hooks, but add a zip tie for the security. Have never had a problem. Also, do not take much stock in the time it took me to build. I spent several months working on other planes. Mine has an OS46fx and I would think that your choice in engines should be fine.
http://www.rcuniverse.com/forum/m_19...tm.htm#1914644
My Feedback: (8)
HI
Hello everyone thanks for the replies... I will be using my Saito 65 it looks like... I will also probably use either an 11x5 or a 12x4... I've used 12x6 on my saito before but i think it's overpropping it a little bit... Looks like i have nothing to worry about with the wing, but we'll see when i get the kit... it comes in tomorrow! can't wait...
Later guys
Later guys
Actually I used the sleeves, but opted for metal pushrods. I have never been a fan of the nyrods. I have had them expand and contract depending on the temperature.
MD
I have been workin on mine of and on for 6 months so far. Im using pull-pull on rudder. It has a magnum .46 with a tower pipe. Im putting on the stock scheme only in blue. Im also using normal 3004's i will post some pics its close to being done!
IL
I used sullivan golden rods on mine and pull pull on the rudder. I also modified the rudder and tail fin abit. Cut off the top half of the tail fin and fixed it to the rudder as a counter balance. Can you say snap roll.... it snaps blistering fast compared to my stock SE.
Powered mine with an OS50sx.... nice.... your saito should be fine.
Also.... look into the dubro curved plastic landing gear. Won't add enough weight to talk about.. will give good ground clearance... and looks good.
Regardless of the landing gear used... I'd recommend beefing up the landing gear block in the fuse with some hard wood keyed into the fuse sides...
I'll see if i have some pics to post.
IL
Think I figured it out if anyone is interested in seeing my SE. Other mods include adding flying wires to the tail and moving the elevator servo aft mounted external by the stab.
My Feedback: (82)
OH
In the process of building my first Sig Extra .Not a fan of the j-hook thing,I bought two 3/4 in. screw type heater hose clamps.I notched the servo tray so that the clamps would go all the way around the Paper tube. Now all it takes is a twist of a screw driver,and wings are securly fastened. Just as a little extra peace of mind,I epoxy the tube in the plane,and the ones in the wings. Very little effort secures the wing halfs,and I,m sure they will never come off. I used all sullivan control rods. Time will tell--
amelia-air: I'm about to start building my SIG SE soon. I've got the kit, but right now I'm working on the Venus 40 ARF. Do you have pictures that you could post showing your solution?
tycho
tycho
My Feedback: (82)
OH
ORIGINAL: tychoc
tycho
tycho
Back in 1999, after building my first SE I liked it so much I blew the plans up 150% and got this monster. It turned out very nice but I couldn't taper the wings because I didn't have the outline of the ribs after building the kit. It flew great with a Supertiger 3000.
I bolted the wings on by the way, no rubber bands were gonna hold those wings. Also back then I couldn't find proper aluminum wing tubes so I used a shower curtain rod with a broomstick through it. LOL... at the time it really was an experiment but since then, I've been wanting to do it again.
