Kitless
FL
Kitless
I recently finished my first kit, and I will be getting my next one this weekend. Since I am between kits for a few days, I get home from work/school and just wander around and stare at my empty building board with a sad look on my face. [][][][][][]
How do I solve the boredom?
RE: Kitless
Get a set of plans and scratch build. I'm doing that with a Sig Kadet Jr. I have the plans and instructions from a kit I built years ago, so I figure it's time to build another one. Since they don't manufacture this kit anymore, it will probably be the only one on the flight line
RE: Kitless
I saw your LT-40 build, looks great!
What's your next kit?
While you wait you can;
-go fly your LT40
-organize your build table and work area so it's ready for action.
-stock up on more tools and gadgets
-Prepare everything for your new kit like buying servos, cables, covering, wheels etc...
-watch southpark on TV and drink a cold beer
-go fly your LT40
FL
RE: Kitless
HAHAHAHA....its all done. Except the Southpark and drink part. lol What time is that on? 11pm?
Next kit is a Goldberg Chipmunk. Is a gift from a guy at the field. Says he's never gonna build it, so he might as well give it to someone who will.....ME!!!
When I fly this weekend, I'll pick it up. I will probably start on Monday. That'll give me something to do until the summertime. There's this thing I have heard other students refer to, it's called something like....studdie? or studdy? I am not sure about that.
Anyways, as long as I've got a plane to build, I don't need to worry about that studdie thing.
FL
RE: Kitless
ok i have several suggestions
1. fly an r/c simulator (thats what im doing until i have the money to build/fly
2. design your own
3. buy a set of plans that are way to advanced for you and study the constuction process
these should keep you hummin' for a while
2. design your own
FL
RE: Kitless
any model can be improved. Look over your LT and make improvements. Cut off bolts and axles that are too long, chip out excess glue, iron down seams again, etc.
Get some scrap wood and make wheel pants?
Polish the landing gear or clean it and paint it. Paint a spiral on the spinner. Paint the propeller.
Did you pin the hinges?
Lots of stuff to do. Read everything you can about building techniques, etc. Go clean your tools. Work on your shop. That's a never ending process and always a lot to do there.
Bake some cookies.
Bake some cookies.
CA
RE: Kitless
If you're anything like me, this will be a short-lived problem. I seem to find kits and plans I really like about twice as fast as I can build them. That means I buy about two projects for every one I have time to build! This, of course, can cause a whole new set of problems such as, "Which one next?", and "Where am I going to put this one?"
When you're wife asks about it, just explain that it's a collection like stamps or coins!
MO
RE: Kitless
Make and buy some tools is you have not already, find some aluminum "T" extrusion saw it up and make your self some sanding bars. Go look on Enco's web page, you can get some 1-2-3 blocks, mini angles plates, long scales a set of dial calipers very inexpensively Note: Enco stuff is not really good enough for use in a real machine shop but it is plenty good enough to make airplanes with. Go on to Microfastners web page and buy enough hardware to make about 20 planes with for about $60. Go an old leather coat?? if you do go buy yourself some lead shot and make some weight bags. If all else fails scrape up all the epoxy CA and whatever else got dripped on your work bench and repaint it
RE: Kitless
ORIGINAL: briansommers
[:-][:-] 55???
OH MAN ! THATS JUST TO MANY
[:-][:-] 55???
RE: Kitless
Good time to do some tests of techniques you've read about. Make some fiberglass or resin parts. Drink beer. Make some test wing sections to try different coverings. Fly a sim. Rig up a test pull-pull system. Watch South Park. Make some of your own balsa ply. Try some vacuum forming and make a canopy.
Scott
Scott
RE: Kitless
I've got a Sig Hog Bipe in the box just waiting to be put together. I just can't stand it anymore either, so I am going to move the kit to the garage (where I have to build), heat up the area with my kerosene heater, and dive in. Of course, am planning to wait a couple of days for the balsa to become acclimated to the colder climate....oh, and me too.
FL
RE: Kitless
On the chipmunk, it is early and I might changemy mind. But I am thinking either the stock look or something that has a lot of blue in it. I did my last one in red. So I am ready for a change of color.
