Engine for Sportser Bipe
TX
I am re-covering a Sportser Bipe. I had been running it with a Magnum 52 2-stroke. Plenty of power for this plane. During the re-cover I will be able to play with the possibilities of mounting a different engine more easily. I would like a 4 stroke for this. Has anyone run one of these with a 4-stroke? I have a Saito 65 that may work with it but it seems to be be a lot heavier than the Magnum I was running.
Your experience with this fine plane and engine combos welcomed!
Adam
Adam
TX
RE: Engine for Sportser Bipe
I am thinking that in the re-cover maybe to locate the rudder and elevator servos further back to compensate for the weight increase. On paper (specs) the Saito is only a tad heavier than the Magnum+exhaust, wish I had a Magnum out of a plane right now to compare hand in hand.
The Saito will require pretty extensive modding (hole in firewall etc) but this is the chance. I'll try and figure it out over the week.
Planning on using an OS .40FSR when I get around to building mine. I seem to have a thing about using engines from the same time period as the kit although it kind of bit me in the ass when I put an OS .25FP in my Super Sportster 20. Should have gone ball bearinged.
Flies ok but could use more oomph. The MACS muffler helps.
TX
I went out and got some motor mounts today, I am going to try and shoe-horn the 65 in without moving the firewall first, if I can I will move the rudder and elevator servos back in the fuselage. Something I would be happy doing anyway as in the current position they make a very large wire bend, this could be eliminated.
