How much CA do you use?
Just curious, I'm building my second kit ever, and this is my first kit that isn't interlocking.
I built my first kit (a PT40) several years ago and have either arf'ed or had others build for me, now that I have the time I am starting to build more kits because its enjoyable.
So how much CA should you use on a joint? So far I've been using it on the full joint / joints, is this ok or should you space it out in drops?
RE: How much CA do you use?
A lot depends on the joint - there are a lot of different types.
First off, I rarely ever use thin CA (Except of course for CA Hinges, where it is a MUST)
So if it's a 1/4" stick that's being end-glued to another 1/4" piece, just a tad on the end is enough.
If I were gluing two 1/4" pieces together lengthwise (Let's just say 18" long) but there are only two joints like that in the kit, I would probably just run a thin bead of medium CA along one piece and join it to the other.
But if there were a lot of joints like that (EG. Cap Strips) I just use a drop of Medium CA at each end, and one in the middle, then I fill the rest of the joining area with wood glue (Just to save CA - it's expensive)
I do the same with doublers... A few strategic drops of CA to hold it, and wood glue in most of the area.
My Feedback: (-1)
I mostly use the thin CA on most of my joints like the ribs and spars. I just hold or clamp things tight then just use A drop or two so the joint is covered. I also use those small tips on the bottle so I only use as much as I need. I use medium when I'm sheeting or need more time to get things set. The thick I use when I need more time.
It all just depends on the plane I'm building too, sometimes I just have to use what type is needed, the plane itself dictates what I'm going to use. I use thin at about to to one over the medium.
FL
Is thin CA weaker tha med? I use medium whereever possible, however in some situations, its much easier to assemble the joint and flow the CA into it.
Also, a related question - I bought some "Flash" brand CA glue from Horizonhobby (Medium). It seems to take much longer to dry than my instacure brand did. However, the nozzle rarely ever clogs. I just take off the cap and it comes right out everytime.
Once, dried, is this flash glue as good as the insta-cure?
My Feedback: (-1)
I haven't found one being any stronger then the other but it probably will depend were it's used. To date I have never had A glue joint come apart on any completed model except on ground contact.
I have found different brands have different cure times though. When I can I try to get ZAP but it isn't carried by my local hobby shop. The stuff he carries [can't remember the name] is very fast. He also had an off brand I tried but it wasn't very good at all. The price was right though but it was very slow.
Thin CA. If I'm gluing, say a rib to the leading edge, which will be a joint of no more than an inch, a single drop is usually enough. If you put it at the top of the joint it will flow down the joint and penetrate the entire length.
If you add a drop to a joint, you can usually see how far the CA "wicks". You do not have to saturate the joint.
I too have seen differing cure rates depending on the manufacturer, and Jet does take longer. I've also never seen a difference in strength between brands or medium/thin.
Dennis-
Dennis-
Anyone notice that CA cures much quicker if:-
1. The parts you are joining are misaligned
2. One of the parts is your finger
Or is it just me?
Terry
Or is it just me?
Terry
very true redback..
Well I've used about 1/2 of a 2ox bottle of medium CA building a 2M glider...
At first I used alot but as I've gone on through the kit I'm using less and less, just have one more outer wing panel to do and I'm done.
