Laser-cut kit
My Feedback: (182)
RE: Laser-cut kit
The only downside to a laser cut kit is the burned edges of the pieces. Should you want to go with a light colored covering the edges do need to be sanded a slight bit. That is a touchy situation as you can change the shape of the part easily if you aren't VERY careful. Other than that I can't think of anything bad about laser cutting...the fits are VERY precise.
