4* 40 dimensions needed
I have never built a 4* 40 so I don't have the plans for one. I am doing some graphics work for a fellow flyer and I need some dimension from the 4* plans. I need the dimensions so I know what size to make the graphics that I'm doing. If anybody out there has the plans for a 4* I would greatly appreciate it if I could get the following dimenions. (also see the attached graphic):
"A" Wing span, base of fuselage to wingtip
"B" Wing chord, leading edge to trailing edge
"C" Horizontal stabilizer span, fuselage to stabilizer tip
"D" Stabilizer chord at fuselage, from leading edge to trailing edge
"E" Stabilizer chord at tip, from leading edge to trailing edge
"F" fuselage length, from front to rudder hinge line
"G" fuselage height at wing leading edge, from fuse bottom to bottom of canopy line
"H" fuselage height at wing trailing edge, from fuse bottom to bottom of canopy line
"I" vertical stabilizer height
"J" vertical stabilizer chord at fuselage, from leading edge to trailing edge
"K" vertical stabilizer chord at tip, from leading edge to trailing edge
"L" rudder chord, at top of rudder
"M" rudder chord, at bottom of rudder
"N" height from bottom of fuselage to bottom of horizontal stabilizer, at rudder hinge line.
I know that these are a lot of dimesion but I really do appreciate any help I can get.
Thanks in advance.
Thanks in advance.
