Straightening an aileron
RE: Straightening an aileron
Try over- twisting it past the correct position and applying the heat (gun or iron) and holding it till it cools.It should settle in to the correct position. You didn't mention if it were a built-up aileron or strip... It may take a second set of hands to achieve this. It worked for me !
Good Luck,
Ugo
Good Luck,
Ugo
My mistake !! I assumed this was an already built plane with MonoKote covering ! I'm gonna assume again that this is a "bare wood" aileron that came with a Kit... If so, Just soak the aileron in warm water and pin or weight it down till dry. Should be OK..Unless the grain is such that it will naturally twist back again. Give it a shot. Don't cost nothin' ! LOL !
Ugo
Ugo
