what retracts should i use in my topflight p39
MO
Robart designed a set for the GE TF P-39. We have quite a GE TF Warbirds at our field with Robarts but I don't know whether they like them or not.
My Feedback: (108)
Spring Air will work just great. You will need to check and make sure that you get the right nose wheel as far as mounting it to the plane. Spring Air is less plumbing and they have positive down locks with no air pressure. Good Luck, Dave.
