Mini Telemaster, what are these pieces?
My Feedback: (76)
MT
I just finished building and covering my first kit, a Mini Telemaster from Hobby Lobby. Along with quite a few balsa scraps, I have these three hardwood pieces left over. There are 1/8" and 1/32" ply pieces and a 1/8" dowel. I've searched the drawings and instructions numerous times, but I can't identify where they belong.
Can someone tell my what these parts are before I put this thing in the air?
RE: Mini Telemaster, what are these pieces?
Hi, I just got done assembling a mini also. I noticed by your picture that you used a gear redux motor, The 1/8th inch ply is for using a brushless motor. The 1/32nd ply is to be cut in half crossways to make covers for the LG blocks on the inside of the model. And it looks to me that you got an extra piece of wing hold down dowel. So it looks like your ready to fly.
My Feedback: (76)
MT
Thanks for the reply, after 10 months I almost gave up waiting.
I hope your telemaster does better than mine did. First 2 flights ended in crashes for similar problems--it would turn to the right much better than it would to the left. Never figured out exaclty why (flimsy pushrods, warped wing...?). I trashed the original wing and built another one (same airfoil) with ailerons, without dihedral, and with only a 36" span. I had 5 or 6 great flights with the new configuration, and then, near as I could tell, the motor mount tore loose on a low pass (over asphalt no less) and the plane rolled quickly upside down and nosed in @ full speed. I cut the damage clean off from the front of the landing gear block up to the bottom of the 'windshield' and just finished rebuilding the nose last night. I'm ready to go at it again this weekend.
