If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    May 2002
    St. Charles, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    1/4 Spacewalker Servos
    What servos is everybody using on the Sig 1/4 Scale Spacewalker II? (Futaba/Hitec type).
    Join Date
    Feb 2002
    Fairfield Glade, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you're asking what size servos should you be
    using, I can tell you that, in my Space Walker II, I use standard servos for the ailerons (JR) and
    1/4 scale servos (Big Daddy) for the rudder and
    elevator. I've been flying this aircraft with a
    Saito 1.50 for about six years with no problems.
    Jerry
  3. #3
    Join Date
    May 2002
    St. Charles, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't know what "Big Daddy" servos are. Do you have a Futaba, Hitec number. What is the torque rating?
  4. #4
    Join Date
    Feb 2002
    Fairfield Glade, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Big Daddy servos may no longer be available.
    Hitec has a 1/4 scale servo, with an advertised
    torque of 139/174 ounces. This Futaba compatible
    servo's Hitec part no. is 31700J and is known as
    the Hitec HS700-BB.
    Look under Hitec's site at: www.hitecrcd.com
    Jerry
  5. #5
    Join Date
    May 2002
    St. Charles, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Jerry, that's just what I needed. The price on the 700BB isn't too bad either.
    Standard servos work OK on the ailerons?. I assume one per aileron, not two?
    I'm putting a new Zenoah G26 gas in mine. About the same cu. in as yours, but guess it will pull a little harder being a 2 stroke.
    I'm going to bash the kit a little and make it look like my Spezio Tuholer homebuilt I built in the 60s. Picture attached.
    George
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  6. #6
    Join Date
    Feb 2002
    Fairfield Glade, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, standard servo's will work for the ailerons,
    one per aileron. However, the kit instructions
    recommend a servo with at least a torque of 60 oz.
    per inch. Again, Hitec has a standard servo, no.
    HS475HB, rated at 61/76 oz, Futaba compatible no.
    33475J.
    Jerry
  7. #7
    NapaFloyd's Avatar
    Join Date
    Jan 2003
    Panama, PANAMA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 1/4 Spacewalker Servos
    George, I like you color sceme... do you have any other pics ?
    I have recently posted the following on this forum..
    I have the MAN plans for the Spezio TuHoler drawn by Cliff Tacie. Would anyone have construction articles that cover the plans. Plas call for a .60 engine. I am planning on a 25cc engine for it...
    Hightflight 1987 #4 had a article Review by Dick Garmhausen FS-37 but not sure if it was for these MAN plans I have.
    The Spezio Tuholer is also known as the Spezio Sport DAL 1.
    Floyd
    AMA 11982
    IMAA 19392
  8. #8
    Join Date
    May 2002
    St. Charles, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Floyd:
    I have lots of other pictures. I'll post some here.
    I also have the MAN plans for the Spezio (for sale if anyone is interested). I decided to kitbash the Spacewalker 2 instead.
    I had a Zenoah 23 in it to begin, not enough power. I now have a Moki 1.8 and it is plenty of power.
    George
ID:	770026   Click image for larger version.
ID:	770027   Click image for larger version.
ID:	770028   Click image for larger version.
ID:	770029   Click image for larger version.
  9. #9
    NapaFloyd's Avatar
    Join Date
    Jan 2003
    Panama, PANAMA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Coop.. would like some cockpit shots.. instruments and seats..
    also if you have some construction shots..
    My friend Eric and I have uploaded construction pics on these links
    http://www.*********.com/forums/show...721#post148721
    http://www.*********.com/forums/showthread.php?t=17714
    http://www.*********.com/gallery/sho...ry.php/cat/613 This is the link with construction fotos
    Floyd
    AMA 11982
    IMAA 19392
  10. #10
    Join Date
    May 2002
    St. Charles, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Floyd:
    I'll post some pics along with this reply. I have a lot. If you want more, email me and I'll send them to you. gecooper@hotmail.com
    My cockpit is pretty basic, no seats, just a panel. I don't spend a lot of time in details.....they all disappear in the crash [&o].
    I usually fly it once or twice a season. Burns a lot of fuel with the big Moki engine, but flies much better than with the small Zenoah. It takes a lot of power to push all tha drag through the air.
    George
ID:	910343   Click image for larger version.
ID:	910344   Click image for larger version.
ID:	910345   Click image for larger version.
ID:	910346   Click image for larger version.
ID:	910348   Click image for larger version.
ID:	910349   Click image for larger version.
ID:	910350   Click image for larger version.
ID:	910351   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
